Welcome to the North American Subaru Impreza Owners Club Tuesday April 13, 2021
Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 07-21-2019, 12:05 AM   #1
Casttawayy
Member#: 504462
Default Wanting to Purchase a GC8 WRX STI. (Common Problems) (Aftermarket Support)
Thinking about Importing a GC8 WRX STI, sedan, what are common problems? and where would I buy most aftermarket parts if I chose to mod it? Not much I can find by a basic web search. But looking at if I do purchase it, I'll probably stick to Coilovers, Wheels, and maybe look into simple power mods, Exhaust/Intake/Headers/Tune ETC not looking to go crazy, but wanting to turn a few bolts for fun on the weekend.
Casttawayy is offline   Reply With Quote
Old 07-21-2019, 12:23 AM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
most of the stuff is the same as the gd or the gg(wagon) 2002-2005 wrx the suspension stuff is the same as the wagons so you can use that
Old 07-21-2019, 12:28 AM   #3
Casttawayy
Member#: 504462
Thank you! I'll take this into account.
Old 07-20-2020, 10:53 AM   #4
nikau
Member#: 516603
2000 MY00 GC8 WRX
I don't have an STI just a WRX, but following issues/maintenance items I've had:
  • MAF sensor goes bad, at least on the 99/00 models
  • knock sensor goes bad
  • power steering reservoir leaking (oring between reservoir and pump)
  • power steering cooler drawing in air (just need better hose clamps)
  • air con tensioner pulley bearing dry (i put in a new bearing)
  • cv boot tear
  • plastic turbo t-piece leaking (replace with brass one)
On the to-do list;
  • valve covers leaking
  • coolant crossover pipe leaking
nikau is offline   Reply With Quote
Old 08-15-2020, 09:04 AM   #5
feliz
Member#: 517506
97 impreza brighto
for the price of an import an 02-06 WRX donor car and a clean US GC8 body should be considered. in fact you can run a turbo on a MAF NA ecm and tune. just not huge boost and injectors, etc.
feliz is offline   Reply With Quote
Old 08-21-2020, 01:17 AM   #6
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
That would be a sad substitute for a GC/GM STI using the MAF NA ecm. No where near the same power as the stock STI or power potential.
If you are deadset on a JDM STI, good luck. They are rare. If you want an awesome 2001 coupe with a 2007 EJ255 drivetrain swap, I have a friend who is looking to sell his. LMK.
speedyHAM is offline   Reply With Quote
