Welcome to the North American Subaru Impreza Owners Club Tuesday April 20, 2021
Old 02-24-2011, 02:41 AM   #451
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
Originally Posted by mike-tracy View Post
Man, what a noob. 11044AA355 (that's for 1)
I saw that one too but wasn't sure if it would work on the EJ20G since it said it was for EJ20K.
kimokalihi is offline   Reply With Quote
Old 02-24-2011, 04:19 AM   #452
mike-tracy
Member#: 135290
2000 Impreza
BRP
I used the EJ20k STI headgaskets (one of the part#s that doesn't come up in the US part system) on my closed deck EJ20G block - all the passages, bore, etc line up perfectly. So they are interchangeable in that they can be fitted to either block.
mike-tracy is offline   Reply With Quote
Old 02-24-2011, 04:39 AM   #453
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Oh I was talking about this one 10105AA120.
That is not a head gasket.
11044AA355 fits both EJ20G and EJ20K but is composite gasket and weaker than the 11044AA463 EJ20K MLS part.
Marnix is offline   Reply With Quote
Old 02-24-2011, 05:51 AM   #454
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
11044AA463 this is not in the system so how do I get them?
Old 02-24-2011, 08:37 AM   #455
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Japanparts.com is a good source.
Old 02-24-2011, 09:43 PM   #456
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
Thanks I will contact them and see if they can get them because it's not in their system either.
Old 02-25-2011, 07:10 AM   #457
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
They are but they use their own part numbering system, but just write them an email.
Old 03-14-2011, 08:03 PM   #458
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
Hey Marnix, do you have the part number for the cam retainer bolts? One of mine had to be drilled out after the bolt head stripped. I checked the junkyard but all they have is SOHC and those don't have cam retainers.
Thanks!
Old 03-14-2011, 10:23 PM   #459
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
/\ get some for the 96-98 ej25 dohc n/a, same bolts
2slofouru is offline   Reply With Quote
Old 03-15-2011, 01:03 AM   #460
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
Do you have the part number for that engine? I guess I could call up the dealer and see if they can look it up and order it. I'm sure they won't have it in stock.
Old 03-15-2011, 05:25 AM   #461
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Front cam cap bolt 808106180
Rear and center cam cap bolt 10993AA000
Old 03-15-2011, 08:19 AM   #462
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
Sweet, thanks!
Old 03-15-2011, 08:20 PM   #463
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
They're in stock! Incredible! And my head gaskets are in along with all my other seals and new oil pump, woot woot! Marnix you rock.
Old 03-18-2011, 12:17 AM   #464
Bookem74
Member#: 174481
98 Legacy GT-T
96 wrx, oil pressure sending unit, and is it the same as usdm of same years?
Bookem74 is offline   Reply With Quote
Old 03-18-2011, 01:24 AM   #465
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
If you mean oil pressure switch, yes. You can use it from any USDM EJ-series engine.
Old 03-18-2011, 09:26 PM   #466
Bookem74
Member#: 174481
98 Legacy GT-T
Yes, and thank you. Also does anyone know if is it a normally open switch? I pulled the wire off and no check engine light came on, looks like I'll be doing an oil pressure gauge while I'm at it to be safe.
Old 03-19-2011, 01:53 AM   #467
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
It's only for the warning light on the dash, there is no signal to the ECU.
Old 03-26-2011, 02:56 PM   #468
wrongear
Member#: 265592
Default 1989 Differentail axle shaft seals
I need a part number(s) for the axle shaft seals at the rear differential of an '89 model, R160. Sorry, I don't know which model; Legacy?. It was a junk yard find, and I didn't notice a front differentail; Probably had the small 4 cylinder in it. 4 door sadan, I think.
The seals' dimentions are 52 X 32 X 9 (plus an extension lip) . These seals are pressed into the differential. There may be a drivers side / passenger side. They will be used on a manual trans with a limited slip 4.11 setup. The orginal was a 4.11 open, and a auto trans.
Thanks for the help.
wrongear is offline   Reply With Quote
Old 03-27-2011, 03:29 AM   #469
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Same as any contemporary USDM R160 diff (Loyale 4WD or Legacy AWD).
And WOW this thread finally got stickied after four years
Old 03-29-2011, 08:35 PM   #470
Poke Her
Member#: 245632
Originally Posted by dr3w View Post
NGK PFR6G
If you cant find those you can use BKR6E's aswell.
Are quite a few people running the BKR6E's? I only ask because my cost on the PFR6G's is somewhere around $7 per plug, whereas the BKR6E's are under $2 a plug.
In my past experiences, platinum plugs haven't dealt with higher octane fuel to well.
Poke Her is offline   Reply With Quote
Old 05-02-2011, 05:04 PM   #471
fantasticfour
Member#: 215453
Looking for the part number for coolant hose that runs from the top coolant tank (mounted to the intake manifold) to the coolant cross pipe on the short block. Thanks in advance.
fantasticfour is offline   Reply With Quote
Old 05-06-2011, 08:01 AM   #472
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
I posted the other day about 20K shims. I ran across them in "My Documents" of all places
For anyone interested...
Buckets 13228AA020
Shims:
13218AD000 1.76
13218AD010 1.78
13218AD020 1.80
13218AD030 1.82
13218AD040 1.84
13218AD050 1.86
13218AD060 1.88
13218AD070 1.90
13218AD080 1.92
13218AD090 1.94
13218AD100 1.96
13218AD110 1.98
13218AD120 2.00
13218AD130 2.02
13218AD140 2.04
13218AD150 2.06
13218AD160 2.08
13218AD170 2.10
13218AD180 2.12
13218AD190 2.14
13218AD200 2.16
13218AD210 2.18
13218AD220 2.20
13218AD230 2.22
13218AD240 2.24
13218AD250 2.26
13218AD260 2.28
13218AD270 2.30
13218AD280 2.32
13218AD290 2.33
13218AD300 2.34
13218AD310 2.35
13218AD320 2.36
13218AD330 2.37
13218AD340 2.38
13218AD350 2.39
13218AD360 2.40
13218AD370 2.41
13218AD380 2.42
13218AD390 2.43
13218AD400 2.44
13218AD410 2.45
13218AD420 2.46
13218AD430 2.47
13218AD440 2.48
13218AD450 2.49
13218AD460 2.50
13218AD470 2.51
13218AD480 2.52
13218AD490 2.53
13218AD500 2.54
13218AD510 2.55
13218AD520 2.56
13218AD530 2.57
13218AD540 2.58
13218AD550 2.59
13218AD560 2.60
13218AD570 2.61
13218AD580 2.62
13218AD590 2.63
13218AD600 2.64
13218AD610 2.65
13218AD620 2.66
13218AD630 2.67
13218AD640 2.68
13218AD650 2.69
13218AD660 2.70
13218AD670 2.72
13218AD680 2.74
13218AD690 2.76
13218AD700 2.78
13218AD710 2.80
13218AD720 2.82
13218AD730 2.84
13218AD740 2.86
13218AD750 2.88
13218AD760 2.90
13218AD770 2.92
13218AD780 2.94
13218AD790 2.96
13218AD800 2.98
13218AD810 3.00
13218AD820 3.02
13218AD830 3.04
13218AD840 3.06
13218AD850 3.08
13218AD860 3.10
13218AD870 3.12
13218AD880 3.14
13218AD890 3.16
13218AD900 3.18
13218AD910 3.20
13218AD920 3.22
13218AD930 3.24
These are for the 20K STi with shim under bucket. Thanks again to Marnix for the part numbers
Cbgrandtheftauto is offline   Reply With Quote
Old 05-11-2011, 02:45 PM   #473
flipn0y
Member#: 157288
1995 STi
Dark Blue
I'm looking for the part for the back of the head where the valve cover sits. It looks like a half moon shaped rubber piece. There are a total of 4. Two on the rear of each head where the valve cover meets the top of the head.
flipn0y is offline   Reply With Quote
Old 05-11-2011, 06:08 PM   #474
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
11051AA070
elislider is offline   Reply With Quote
Old 05-11-2011, 08:23 PM   #475
flipn0y
Member#: 157288
1995 STi
Dark Blue
Thanks for the speedy reply but i have another question then
what is the difference between the following
"gskt rocker cover no. 2"
13293AA030
"Gasket rocker cover #20"
13293AA051
Just need this cleared out
EJ20G & EJ20K Parts awdeclipseguy 1993 - 2001 Impreza Specific Parts 17 06-15-2009 07:04 PM
EJ20G Gasket Part Numbers... scoobydorift Subaru Conversions 13 02-14-2005 10:43 PM
Official XT Oil Filter Part Number thread BrysImpreza Forester Forum 8 10-29-2003 11:23 PM
NAPA Part numbers- can we have a nice thread with numbers listed? Tex-WReX2 Service & Maintenance 5 12-15-2001 09:21 AM
