Welcome to the North American Subaru Impreza Owners Club Thursday April 15, 2021
Old 09-02-2014, 10:48 PM   #601
BillyMagnum
Member#: 219892
AP1 S2K Life Now
17' PRD WRX CVT (Sold)
Originally Posted by 2slofouru View Post
I have a pic off the net of the routing of the lines, will try and find it. Mine is now an aftermarket 3 port. I ran the jdm 1S ecu for a long time with 93 octane fuel zero problems, ran like champ.
I am now using a powerfc as well, its been untuned except for boost duty cycle adjustments and preliminary idle setup. I ran it on my previous ej20k setup and am still running it with my modded ej20k heads/ ej257 bottom end setup and it runs smooth but I need to tune it to get the most out of the build. It can build boost quickly and go into boost cut if the outside temps change a lot.
Ok great thanks! Atleast I know I can install it and drive it to get tuned
BillyMagnum is offline   Reply With Quote
Old 09-07-2014, 01:46 AM   #602
Ron1691
Member#: 400940
1974 VW
can any one assist me in finding out the part number to which maf sensor i need .. i have a 1996 gc8 ver 3 ej20t with yellow side injectors .. =C any help is welcome
Ron1691 is offline   Reply With Quote
Old 09-09-2014, 05:25 AM   #603
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
22680AA270 or 22680AA271.
Marnix is offline   Reply With Quote
Old 09-09-2014, 05:43 AM   #604
flyerpope
Member#: 207024
87 GL-10
Originally Posted by flyerpope View Post
Can I get a part number for the MAF on a 1992 JDM EJ20g?
Sent from my iPad using NASIOC
Still looking.... Any help?
flyerpope is offline   Reply With Quote
Old 09-12-2014, 02:42 AM   #605
mike-tracy
Member#: 135290
2000 Impreza
BRP
22680AA160
Same MAF as many/most 90s USDM Subarus
mike-tracy is offline   Reply With Quote
Old 09-12-2014, 02:57 AM   #606
flyerpope
Member#: 207024
87 GL-10
Thank you! I got one out of 92 legacy from the junkyard. R60 with top if air box! 15 dollars
Old 09-12-2014, 01:09 PM   #607
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
This thread is so full of win, thanks to Marnix for creating it and spending so much time helping everyone and its also great that we can all chip in. Having the part numbers in the thread for future reference is such a great help.
2slofouru is offline   Reply With Quote
Old 09-21-2014, 03:25 PM   #608
flyerpope
Member#: 207024
87 GL-10
In need of a part number for a 92 JDM WRX oxygen sensor. The one I got one the down pipe had 2 blades but no connector. Help please
Old 10-01-2014, 10:03 AM   #609
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
MY92-93: 22690AA131
MY94-96: 22690AA260
Old 11-04-2014, 01:50 AM   #610
Flip C
Member#: 55331
Does anyone know if the Ej20K ignitor (22438AA140) is replaceable via a USDM part?
Also are the Ej20K inter-cooler stays the same to a USDM part - if so what?
Flip C is offline   Reply With Quote
Old 11-08-2014, 12:38 AM   #611
Flip C
Member#: 55331
Ok So any 90-98 Legacy uses same ignitor.
Intercooler stays look to be same as GD. Havent tested yet.
For a simplified EJ20K list - http://worldconspiracy.org/EJ20K.txt
I will be cleaning that up more asap.
Old 11-18-2014, 02:18 PM   #612
BillyMagnum
Member#: 219892
AP1 S2K Life Now
Used the search thread with no luck...theres random blobs of info everywhere.
I have a 97ej20k...looking to upgrade injectors from stock about 1 size cc up to go with my new fuel pump and other mods. Are the sti injectors bigger/will they fit? If so whats the part number? Is there an aftermarket anyone recommends? I'm not sure what Size injector I have now. They are stock though.
Old 11-18-2014, 07:44 PM   #613
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
/\ Your injectors likley are 480cc and the newer usdm sti sidefeeds won't directly fit. If you want to use the 550cc usdms (for example), you'll need to buy an adapter kit that has sleeves and o rings to make the newer injectors fit. I was upgrading from my 480cc injectors to 1000 and had to use the adapter kit on my 97 ej20k rails. There are a few sellers who have them, my adapters came from five 0 motorsport.
The ej20k sidefeeds look similar to the newer usdm versions but they aren't. The ej20k uses the phase 1 style and the usdm wrx sidefeeds are phase 2 style.
Old 11-20-2014, 04:09 PM   #614
BillyMagnum
Member#: 219892
AP1 S2K Life Now
Got a link to the adaptor kit you picked up? I checked 5 0 but couldn't find anything.
Old 11-20-2014, 07:48 PM   #615
chemtek
Member#: 310710
2008 Impreza WRX
chemtek is offline   Reply With Quote
Old 11-20-2014, 07:54 PM   #616
chemtek
Member#: 310710
2008 Impreza WRX
Old 11-20-2014, 11:47 PM   #617
WelDun1
Member#: 249130
1999 Ver5 STi RA
If you are looking for an adapter like 2slofouru is talking about, these Carl Davey Phase 1> 2 Injector Adapters are the only way to go. In fact, they provide most of the harder to find conversion parts for JDM Ver1-6 STi. Depending on what kind of #s you're after, the Ver5/6 STi yellow side feeds should be sufice for 300hp, but if you want more than that I would just go with some DW850cc side feeds and call it a day. Its pointless to upgrade your injectors more than once. Most ppl realize that after the second time LoL its better to run a bigger Injector on a lower DC anyways.
Im running DW850cc & DW300 pump and im good for about 400-450whp with my mods...
WelDun1 is offline   Reply With Quote
Old 11-20-2014, 11:56 PM   #618
chemtek
Member#: 310710
2008 Impreza WRX
The issue with the Carl Davey kit is that he has retired from the business. I emailed him and he sent me to www.asperformance.com which is a vendor who is going to carry on supplying his kit.
I couldn't find the kit on their website but sent them an email and was informed kit shipped to Canada would be 48.
As far as the other kits I linked, they do the same thing. Supply O rings and adapters to switch from phase1/1.5 to phase 2 injectors.
Old 11-21-2014, 07:42 AM   #619
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
/\ Exactly, which is why I mentioned five 0 where I bought mine. Another company actually sells them for less than the price five 0 sold mine for claiming they gave me a "discount".
Old 11-21-2014, 10:15 PM   #620
WelDun1
Member#: 249130
1999 Ver5 STi RA
Mustve been recently cuz I ordered the top feed kit from him about 8 months ago, and then returned it a month later after I decided to stay with the side feeds.
Old 11-23-2014, 02:40 PM   #621
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Here is why you need the adapter kit, phase 1 (ej20k) is yellow.
Old 12-08-2014, 08:17 AM   #622
suby25
Member#: 52822
2015 WRX
Gents, does anyone know the part number for the lower coolant line that runs between the turbo and the block for an EJ20G (V1 STi RA, if it matters)? Mine is leaking and I need a new hardline (attached to engine), banjo bolt, and washers. Bolt "B" and the attached hardline are what I'm trying to find.
suby25 is offline   Reply With Quote
Old 01-23-2015, 09:17 AM   #623
BillyMagnum
Member#: 219892
AP1 S2K Life Now
need this oem ac compressor line bracket! anyone know a number or where to get it? Searched to no avail....as I keep finding parts that don't look like it. 97 ej20k
Old 01-23-2015, 05:17 PM   #624
Trevor.v
Member#: 394575
Hey guys I have a 94 wrx that will be getting an ej20g engine, been looking through this thread maybe not close enough as well as using the search button but I want to know which sensors will be the same between the 2 and which are different for wiring perposes. I'd rather not strip it down to bare block and have to transfer everything over from the old engine. Any input would be great!
Trevor.v is offline   Reply With Quote
Old 02-05-2015, 03:25 PM   #625
xXOli450Xx
Member#: 362238
anyone know what is the part number for the restriction pill/hose for a v4 sti
xXOli450Xx is offline   Reply With Quote
EJ20G & EJ20K Parts awdeclipseguy 1993 - 2001 Impreza Specific Parts 17 06-15-2009 07:04 PM
EJ20G Gasket Part Numbers... scoobydorift Subaru Conversions 13 02-14-2005 10:43 PM
Official XT Oil Filter Part Number thread BrysImpreza Forester Forum 8 10-29-2003 11:23 PM
NAPA Part numbers- can we have a nice thread with numbers listed? Tex-WReX2 Service & Maintenance 5 12-15-2001 09:21 AM
