Welcome to the North American Subaru Impreza Owners Club Sunday April 11, 2021
Old 02-05-2015, 03:26 PM   #626
xXOli450Xx
Member#: 362238
Originally Posted by BillyMagnum View Post
need this oem ac compressor line bracket! anyone know a number or where to get it? Searched to no avail....as I keep finding parts that don't look like it. 97 ej20k
03 wrx should be the same
xXOli450Xx is offline   Reply With Quote
Old 02-15-2015, 11:00 PM   #627
chemtek
Member#: 310710
2008 Impreza WRX
Anyone know the part numbers for the gaskets for the oil filler tube and head breather lines on the valve covers on a EJ20G version 2 STI?
Tnx
chemtek is offline   Reply With Quote
Old 02-16-2015, 01:28 AM   #628
BillyMagnum
Member#: 219892
AP1 S2K Life Now
17' PRD WRX CVT (Sold)
Not sure what 03 would be any ideas?
BillyMagnum is offline   Reply With Quote
Old 02-16-2015, 07:49 PM   #629
xXOli450Xx
Member#: 362238
I was wrong 03 wrx don't have the same bracket sorry
Old 03-20-2015, 11:33 PM   #630
mixdnuts
Member#: 147357
1997 JDM Fozzie S/Tb
Forester
JDM V1 valve cover gaskets
US Part Number: 13272AA063
Spark Plug Gasket:
US Part Number: 13293AA030JDM V1 valve cover gaskets
Spark Plug Gasket:
Ok found this and am wondering if anyone knows if this would be the same as the EJ20G used in a 1997 SF5 (JDM Forester ST/B) I have been plagued with valve cover gasket leaks since importing it. I have changed both sides using gaskets from an EJ25 kit I had laying around. Totally gooped those with RTV and it lasted about a year but they are leaking again.
mixdnuts is offline   Reply With Quote
Old 03-21-2015, 10:05 PM   #631
WelDun1
Member#: 249130
1999 Ver5 STi RA
Im looking for the Clutch Master Cylinder Part # For a Ver5 STi
WelDun1 is offline   Reply With Quote
Old 03-29-2015, 07:07 PM   #632
panel
Member#: 352704
1965 Vw panel bus
with an EJ20 Turbo Swap
Anyone have the p/n for the oil pick up? 1990 EJ20T Turbo Forester
panel is offline   Reply With Quote
Old 03-30-2015, 12:39 AM   #633
BillyMagnum
Member#: 219892
AP1 S2K Life Now
In need of valve cover gaskets for my 97 ej20k....anyone? Please!
Old 03-30-2015, 12:41 AM   #634
BillyMagnum
Member#: 219892
AP1 S2K Life Now
The pickup itself or the oring? Just change your oil pan to a 2.5 one and get the killer bee one! That's what I'm gonna do! Oem Subaru dunno the # tho.
Old 03-30-2015, 08:12 AM   #635
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Same as USDM EJ25D of same model year.
Marnix is offline   Reply With Quote
Old 03-30-2015, 09:56 PM   #636
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
/\ This. Some guy on the forums argues with me that there are like 7 different versions for the 97-98 ej25d, every time I give this advice. Also, be sure to use oem on the valve covers. They fit perfectly and seem thicker so they compress tighter and resist leaking.
2slofouru is offline   Reply With Quote
Old 03-30-2015, 10:20 PM   #637
panel
Member#: 352704
1965 Vw panel bus
'O' ring only sorry.............anyone ?
Old 05-05-2015, 05:34 PM   #638
d_rieco
Member#: 393973
05 fxt
need the part number for a coolant temp sensor on a ej20k
d_rieco is offline   Reply With Quote
Old 05-07-2015, 07:02 AM   #639
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Same as any other EJ from same year.
Old 06-02-2015, 06:32 PM   #640
isaiahkaid
Member#: 422623
Default Please Help Need Clutch
hey guys, i have a 1999 RHD impreza wrx sti ver 5. i imported it from japan last year adn yesterday my clutch went! i have been trying to look for one around where i live in canada but i cant find one. i am looking for an exedy organic stage 1 kit, my issues however have been not being able to find one specifically made for MY car! i can only find ones for the impreza outback l 2.2L or the impreza rs 2.5L. I have an ej207 an that is turbod so would i blow the clutch if i bought one for either of those models? the other option is 2002 USDM wrx but im not sure if it will fit! Has anyone successfully put a USDM WRX clutch into a 1999 ver 5 GC8 STI???? Any help would be much appreciated im trying to get my car back on the road asap!!!!!
isaiahkaid is offline   Reply With Quote
Old 06-02-2015, 06:32 PM   #641
isaiahkaid
Member#: 422623
Old 06-02-2015, 07:53 PM   #642
GC8-STI
Member#: 152391
2000 Impreza
Diamond Grey Metallic
I have a V2 STI engine and I changed the flywheel and used a clutch for EJ205 the clutch fork rubbed the pressure plate a little so I just ground the for a bit where it rubbed and it has worked fine.
GC8-STI is offline   Reply With Quote
Old 06-03-2015, 11:03 AM   #643
Nemesis_911
Member#: 209140
1998 Sti RA V-Ltd
World Rally Blue
Is there any part number for an entire gasket and seal kit that would fit the EJ20K?
I'd like to change every single one, but I already have the MLS STI head gaskets waiting to go in, so at least those are not a worry. Is there a kit where I could get everything else required however or do I need to buy them individually?
Nemesis_911 is offline   Reply With Quote
Old 06-03-2015, 08:18 PM   #644
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I had to get the entire oem ej25d kit and sell the headgaskets that came with it because I had to buy the jdm mls ej20k headgaskets separate.
Old 07-11-2015, 02:27 PM   #645
oxen914
Member#: 425482
1975 Porsche 914
I have an EJ20R JDM motor in my Porsche 914 (I think). Is there an easy way to determine what motor it is? There is a 6 digit numeric code (980650) under the intercooler, does that mean anything? The motor is an EJ20 and it does have twin turbos and the valve covers have "4 cam 16 valve" on them. My real needs are my water pump isn't working, so I need to replace it and the timing belt. I was hoping to get a kit, but I don't know what will fit/work on the motor. Any help would really be appreciated!
oxen914 is offline   Reply With Quote
Old 08-04-2015, 08:29 PM   #646
Hawk296
Member#: 14555
1995 Impreza L
Baja
So is it 13270aa061 or 13270aa081? They are both listed for 97' ej25d depending on early or later in the year. I'm trying to get some for my 97' ej20k and dont know which ones to order. Did the Ks get the same end of year change as well?
Hawk296 is offline   Reply With Quote
Old 08-04-2015, 09:10 PM   #647
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I have 97 ej20k heads and the large gaskets separate are 13270AA085 and 13272AA082. I have them for backup next time I need to pull the covers. Not sure of the part number of the total kit
-just did a quick search from an ebay subaru parts seller-
The 13270aa081 has both of the gaskets I have and the oval type spark plug hole gaskets look the same. The kit you don't want has the square type spark plug hole gaskets.
http://www.ebay.com/itm/OEM-Subaru-V...29f0b3&vxp=mtr
Old 08-04-2015, 09:25 PM   #648
Hawk296
Member#: 14555
1995 Impreza L
Baja
Thank you, I already have the spark plug gaskets, but somehow forgot to order the large gaskets.
I started this project years ago and just now picked it back up. as I try to piece this old engine back together I'm finding a lot of little things missing. It's kind of a pain, but the engine itself is in pristine condition otherwise so I'm moving forward.
Old 10-10-2015, 08:27 PM   #649
rocketman442
Member#: 135219
Rear main seal and coolant temp sensor part number for a 95 sti ra?
rocketman442 is offline   Reply With Quote
Old 10-11-2015, 01:12 PM   #650
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Same part numbers as normal usdm impreza non turbo
EJ20G & EJ20K Parts awdeclipseguy 1993 - 2001 Impreza Specific Parts 17 06-15-2009 07:04 PM
EJ20G Gasket Part Numbers... scoobydorift Subaru Conversions 13 02-14-2005 10:43 PM
Official XT Oil Filter Part Number thread BrysImpreza Forester Forum 8 10-29-2003 11:23 PM
NAPA Part numbers- can we have a nice thread with numbers listed? Tex-WReX2 Service & Maintenance 5 12-15-2001 09:21 AM
