Welcome to the North American Subaru Impreza Owners Club Sunday April 18, 2021
Old 04-22-2007, 05:00 PM   #126
STIspain
Member#: 61850
1998 Imp Type R/Evo6
White/White
another EJ20K/EJ20R (EJ20RDWCJE) request
EJ20K heads part number
EJ20R heads part number
EJ20K cams part number
EJ20R cams part number
EJ20K vavlespring part number
EJ20R valvespring part number
EJ20K valves part number
EJ20R valves part number
Thanks
STIspain is offline   Reply With Quote
Old 04-22-2007, 06:28 PM   #127
Lachlan
Member#: 19470
1981 Brat GL
Valves:
Originally Posted by Marnix View Post
Non-RA EJ20K valves:
13202AA350 VALVE-EXH
13201AA340 VALVE INT
Lachlan is offline   Reply With Quote
Old 04-23-2007, 10:37 AM   #128
JDMWREX
Member#: 121445
1994 JDM RHD WRX
Default rear diff
Can you get me the part# for the front rear diff seal?
thanks
JDMWREX
JDMWREX is offline   Reply With Quote
Old 04-24-2007, 02:45 AM   #129
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
thanks
JDMWREX
I need a bit more info, R160 or R180 diff? If R160, then same as any USDM R160 diff, if R180 then same as USDM STI!
Marnix is offline   Reply With Quote
Old 04-24-2007, 02:51 AM   #130
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
LH 11063AA742
RH 11039AB132
LH 11063AA752
RH 11039AB162
EJ20K cams part number (non STI)
13032AA240
13035AA240
13038AA240
13053AA240
EJ20K cams part number (STI)
13032AA390
13035AA390
13038AA390
13053AA390
EJ20R cams part number (MY97)
13032AA240
13035AA240
13038AA240
13053AA240
EJ20R cams part number (MY98)
13032AA390
13035AA390
13038AA390
13053AA390
13217AA160
13217AA150
See thread
Intake 13201AA320
Exhaust 13202AA330
Especially the cams are very interesting. Other point of notice: the standard EJ20K and EJ20H valves are the same as the EJ20D and EJ25D valves; only the EJ20K STI and the EJ20R have different valves.
Old 04-24-2007, 02:18 PM   #131
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
are there numbers for the RA stuff? i know at least the cams are different.
also, are there part numbers in there for full(assembled/everything included) Sti RA K heads? ive seen complete heads brand new before.
Hurley 2.5 WRS is offline   Reply With Quote
Old 04-25-2007, 02:43 AM   #132
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
There are no part numbers for complete assembled heads, but I will check again.
All EJ20K cams listed in de JDM Catalogue are in the post above.
Old 04-25-2007, 11:45 AM   #133
99WRXEJ20
Member#: 34545
1999 GC8
74f
how about a ej20g/h valve spring?
and the knock sensor for the g motor?
thanks
99WRXEJ20 is offline   Reply With Quote
Old 05-01-2007, 04:55 PM   #134
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
a few things.... FIRST and foremost this thread needs to be sticky!
2nd the 1st post should have a master part number list so instead of someone trying to scroll around trying to find a part number its on the first page
3rd of all! I need a part number for the IAC gasket OR a gasket that would work and could be modifyed
scobaru is offline   Reply With Quote
Old 05-01-2007, 05:27 PM   #135
GripGC8
Member#: 110653
87 FC3S
napa has gasket sheets..just go buy one, trace the IAC into the gasket sheet..then cut out with an exacto knife.
GripGC8 is offline   Reply With Quote
Old 05-01-2007, 10:45 PM   #136
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
cool I can do a throttle body plate too
Old 05-03-2007, 12:49 PM   #137
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Originally Posted by rob View Post
EJ20G PCV hose that connects to the block.
-Rob
3rd time's the charm. Marnix, can you dig this one up?
Thanks,
Rob
rob is offline   Reply With Quote
Old 05-04-2007, 02:30 AM   #138
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Will do for you tonight!
Old 05-05-2007, 12:38 AM   #139
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
The hose which connects to the block:
807519082 HOSE-19X27
It's the same for EJ20G, EJ20K, EJ205 and EJ207.
Old 05-05-2007, 02:31 AM   #140
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Yay, thanks for that.
Old 05-07-2007, 06:04 PM   #141
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Hi Marnix,
Turns out to be the wrong part number, or not the hose I am looking for.
I was looking for hose number 2 below, but while we are at it, might as well get the numbers for all 3 and the plastic 3-way junction piece if possible.
Old 05-08-2007, 12:00 AM   #142
Lachlan
Member#: 19470
1981 Brat GL
I need to find the right intake sprocket part number for the EJ20K (it's plastic if that helps)
Old 05-08-2007, 02:31 AM   #143
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
@ rob: I'm sorry to hear that. I checked for the later EJ20G and EJ20K, not for the early EJ20G!
Here's the parts you need:
1) 807415202
2) 807519162
3) 807515872
T-piece) 11821AA230
Sorry for the inconvenience.
@ Lachlan
13044AA020 SPROCKET COMPLETE, CAMSHAFT INTAKE, RIGHT (RESIN)
13044AA005 SPROCKET COMPLETE, CAMSHAFT INTAKE, RIGHT (METAL)
Old 05-08-2007, 02:34 AM   #144
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
1) 807415202
2) 807519162
3) 807515872
T-piece) 11821AA230
@ Lachlan
No worries. I am very appreciative of all the help.
-Rob
Old 08-31-2007, 08:48 PM   #145
black05wrx23
Member#: 68642
05 wrx
black
hey guys I need some help Identifing these valve cover gaskets. If you recognize them and know what part number they are please let me know I would really appreciate it.
http://i10.photobucket.com/albums/a1...g?t=1188607679
black05wrx23 is offline   Reply With Quote
Old 09-08-2007, 08:05 AM   #146
STi_v4_Wagon
Member#: 120368
04 Forester XT
Anyone know the part number for an EJ20K oxygen sensor? Also is it worth the extra money to go with an OEM one or should a bosch one do?
Thanks!
STi_v4_Wagon is offline   Reply With Quote
Old 09-11-2007, 12:39 AM   #147
turboL
Member#: 111735
97 Impreza L
Rust and White
searched the thread, couldnt find em. EJ20G Piston Rings, BBBC.
turboL is offline   Reply With Quote
Old 09-14-2007, 03:54 PM   #148
johnkaldar
Member#: 51047
1999 gc8 RS/sti-ra
What part number for ej20K water pump? and timing belt tensioner?
johnkaldar is offline   Reply With Quote
Old 09-20-2007, 07:56 PM   #149
bluesubby
Member#: 80247
What's The Part# For Ej20g Valve Cover Gasket Set
bluesubby is offline   Reply With Quote
Old 10-04-2007, 12:38 AM   #150
suberboy
Member#: 1531
2008 GRB
Red
if i remember correctly the 98RS has the same IAC gasket... so it may have the same throttle body gasket too.
also i agree that a sticky dedicated to the part number list would be really nice. maybe a spot for each engine series in the sticky and over time we could highlight what is available through US/Canadian dealers.
-noah
suberboy is offline   Reply With Quote
EJ20G & EJ20K Parts awdeclipseguy 1993 - 2001 Impreza Specific Parts 17 06-15-2009 07:04 PM
EJ20G Gasket Part Numbers... scoobydorift Subaru Conversions 13 02-14-2005 10:43 PM
Official XT Oil Filter Part Number thread BrysImpreza Forester Forum 8 10-29-2003 11:23 PM
NAPA Part numbers- can we have a nice thread with numbers listed? Tex-WReX2 Service & Maintenance 5 12-15-2001 09:21 AM
