#1 |
Member#: 197511
SWIC
Vehicle:1999 2.5RS Black |
![]() I am going to start up my swapped rs this weekend. As of now I have safc and sitc piggy backs. Seeing how it is a 97 forester it is the bastard late g motor. I know the 20k get bad wrap for spinning bearing because of low octane fuel and not pulling enough timing. So my question is how much should I retard the timing to make it safe for 91 octane. I will be getting it tuned next month (have to drive to phx, AZ)but I want to start driving her. It is completely stock so I should not need to mess with any a/f numbers. Being that is a forester late 20g(20k) it already has a less agressive timing curve than say a sti 6s ecu. (250hp vs 280). So all you g,k gurus school me on this
and yes i am ready to be flamed for not getting a pro-tune immediately. ![]() ![]() ![]() ![]()
#2 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
![]() so you are using the G ecu right...
if your worried i would direct connect the wastegate and take her easy det under low load is not an issue should be fine with 91 |
#3 |
Member#: 197511
SWIC
![]() yea it is a g ecu but it uses the k style plugs so I am not sure how much more aggressive the ecu is. Am i correct in thinking that using a knock light and the sitc I can simply retard the timing until there is no knock at the given rpm?
#4 |
Member#: 133923
NWIC
Vehicle:03 Legacy GT wagon I love goooollllllllddddd |
![]() the late ej20g with 20k style electronics makes the least power of that year range (for turbo models). its got a td04 which is a small turbo (still larger than the usdm td04 though AFAIK). the real problem is with the jdm ej20k sti ECUs like the 6S ecu that i have, runs 17lbs boost stock, which is quite a bit from the factory. so if you get an ECU from a plain ej20k wrx (one that had a td05 for example) then you could push your current setup further but not so far as a vf22/vf23 jdm ej20k sti (which would have bigger injectors, fuel pump, shim under bucket, etc)
#5 | |
Member#: 104824
Vehicle:1996 EJ20G OBS Black |
![]() Quote:
#6 |
Member#: 133923
NWIC
![]() the late ej20g and plain ej20k is shim under bucket very similar to the USDM 1998 2.5RS and USDM 1998 forester. they are similar in valve train features but the jdm has slightly larger ports and better valves and cam profile for the turbo model. the v3/v4 STi is shim under bucket and sodium filled valves, overall tougher valvetrain which can endure higher and more sustained revs (within reason). hence why the factory fuelcut on a v3/v4 sti is 8250 and for the plain wrx its lower like 7800 or something
marnix/matt/jaxx could provide more specifics |
#7 |
Member#: 51480
International
Vehicle:1984 AM5, 1984 AF1, 1994 BC4, 2015 Outback |
![]() The head castings are identical to all MY97-98 DOHC heads including USDM EJ25D, JDM EJ20G, EJ20H, EJ20K and EJ20R. The differences are in valves (solid or hollow/sodium cooled), valve springs and shim arrangement (under - or over bucket) and cams. This all has influence on rev limit and power range.
Considering the rs182 is using a EJ20G out of a Forester, he should also consider that the engine has a higher compression ratio (9.0 vs. 8.0) compared to a EJ20K meaning he will have to be even more conservative regarding timing under boost. When using the ECU that came with that engine, however, the engine should be fine on 91 gas as the maps are far less aggressive as the EJ20K's. Still, when driving, start carfefully and monitor knock. |
#8 | |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
![]() Quote:
Maybe that's what the sitc is? (I hate when people throw out random abbreviations that aren't in common usage). Obviously sitc is some sort of timing controller, but exactly what that is isn't clear to me... |
#9 | |
Member#: 177
NWIC
![]() Quote:
ej20k=vf22 ej20ksti=vf23/vf24 all have the same injectors |
#10 |
Member#: 51480
International
![]() Eh no, not the late EJ20G they have the dark grey tops, same as all pre-1997 EJ20G (except some STI versions). Only the EJ20K had the yellow top injectors.
#11 | ||
Member#: 133923
NWIC
![]() Quote:
werent there different variations (i heard up to 3 variations) of yellowtops? some say 440 some say 480 |
#12 |
Member#: 51480
International
![]() There are different yellow tops on the MY99> engines, they're supposed to be 440cc whereas the earlier yellow tops (EJ20K and EJ20R) are 550cc.
#13 |
Member#: 832
RMIC
![]() Straight inlet td05 was never a factory thing. Starting with v3, all STi's and 5MT Sedans got IHI VF series turbos while all the others got td04s. Straight inlet td05 are an aftermarket thing.
#14 | |
Member#: 133923
NWIC
![]() Quote:
I knew about the VF series stuff but thats more good info, thanks |
#15 | |
Member#: 197511
SWIC
![]() Quote:
Wow I as at work all day and I come home to a **** load of posts lol Thats awesome. The SITC stands for super ignition timing converter. It is an apexi product that has now been discontinued but it still in wide use. Basicly it intercepts the cranks position senor and cams position sensors and allows you to advance or retard your timing up to 15 degrees either way at 5 different rpm levels. The knock light I am running is a turboxs knock light. They swear that it doesnt interfere with the stock sensor reading but maybe a different sensor is a good idea. Thanks to everyone for all the input! I know these late g's are confusing to alot of people. It is great to have some suby gurus to clear stuff up for newbies ![]() It sounds like I will go ahead and run this on 91 as is for a while and just take it easy. thanks everyone Jason |
#16 |
Member#: 197511
SWIC
![]() One more thing.... I have heard various hp numbers for this motor ranging from 190 to 265 but 250 comes up the most. Is the 250hp number correct? I would like to think it is at least more that a usdm wrx
#17 |
Member#: 184977
South East
Vehicle:99 Impreza RS '13 BRZ |
![]() so theres a difference in the WRX 20K and the forester engine??...hmmm..thats something new
#18 |
Member#: 197511
SWIC
![]() I think they are the same? I am pretty sure the wrx wagons came with the late g as well as the forester. Mine has a 4w ecu. Not sure how that compares with the wrx guys.
Also I was not aware that the g had a higher compression ratio than the k either I was under the impression that the internals were the same. Im glad I posted before I threw on a 6s ecu and a vf23! |
#19 | |
Member#: 832
RMIC
![]() Quote:
![]() Since we're going back into the dark ages of tuning these cars, the J&S Safeguard was a popular aftermarket knock sensor in it's day. Not only did it sense, but it also automatically retards when it gets knock, much like the stock ECU is supposed to do. |
#20 |
Member#: 177
NWIC
![]() there is still disagreement on the ej20k yellow sidefeeds
i believe they are 480cc @ 3 bar |
#21 |
Member#: 133923
NWIC
#22 |
Member#: 51480
International
![]() No could be they are 480 cc; I only know they're bigger than the grey tops and the only other engine they were in besides all EJ20K, is the TwinTurbo EJ20R.
#23 |
Member#: 832
RMIC
![]() IIRC i_c_the_light actually had a set tested and posted teh results. Though it could have been for the greys. Wouldn't hurt to search if people really care. I don't.
#24 |
Member#: 51480
International
![]() It would be nice to test a grey top and a yellow top simultaneously to see the difference between them.
#25 |
Member#: 2036
Vehicle:2000 Intrepid silver |
![]() New version has headphone output and knock-finder LED's to show which cylinders are knocking.
Google "knock amp interceptor" |
EJ20K VS Late Ej20G | Cbgrandtheftauto | Pre-2002 Factory Turbo Powertrain | 64 | 12-14-2018 05:27 PM |
Late ej20g cams | Cbgrandtheftauto | 1993 - 2001 Impreza Specific Parts | 4 | 03-11-2010 02:49 PM |
wtb: ej20g passenger side timing cover | blueGC | Private 'Wanted' Classifieds | 4 | 02-26-2009 09:08 PM |
Are you Late, Early, or on Time? | Ferg | Off-Topic | 36 | 12-08-2005 03:04 PM |
it's late... i think it's time for another... | Handsdown | Off-Topic | 3 | 09-17-2004 02:01 AM |
