Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 07-19-2008, 12:25 AM   #1
shadymilkman129
Member#: 53651
Cert Suby tech
specialist for hire!
Exclamation Problem starting after 6 speed swap.... Please help
First off I have a stage 4 car and upgraded to a 6 speed and a 6 speed exedy clutch and flywheel. However i have the stock wrx 5 speed starter in when I tried to start it. IT would not start and gave me the following codes:
P0183 Fuel temperature sensor A circuit high input
P1086 Tumble generator valve #2 (LH) position sensor circuit low input
P0328 Knock sensor circuit high input
I did do the tgv delete suring the swap, however I kept the rods in and the sensors connected. I also noticed that I found a ground with read and green wires (with 2 ground ends) that were not grounded to anything.
I did not change the fuel pump, I know p0183 occastionaly pops up after a walbaro install but mine has been installed for quite some time.
Do I need to change over to the sti starter? Also whats with the fuel sensor and the tgv sensor having low imput? Help would be greatly appreciated, and if anyone could direct my twoards a grounding schemetics sheet for an 02 wrx that would be awsome. Once again your help would be greatly greatly appreciated...
shadymilkman129 is offline   Reply With Quote
Old 07-19-2008, 01:54 AM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I'm pretty sure you posted this in the wrong forum. Do you have a WRX to begin with or is this a WRX swap into a RS?
Old 07-19-2008, 02:08 AM   #3
shadymilkman129
Member#: 53651
Cert Suby tech
ITs a 6 speed sti tranny swap into an 02 wrx with utec, stage 4. I also decided to put in a 3 inch hard turbo inlet pipe and delete my tgv's as well. I put everything back together and now I get these codes. I just dont understand why. I rest my cars ecy deleted the codes and it happened agian, no start. Int he beginging it was trying to turn over, but buy the end after multiple more tried I ddint even hear the ulternating trying. Furthermore, I remeber when i would turn my key onto the on position i could usualy hear the warlbaro fuel pump, now i dont...
Does anyone know what causes high and low circut inputs?
Old 07-19-2008, 02:12 AM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
OK, see, the problem with that is that you posted in the Normally Aspirated Powertrain forum.
I reported your post to the mods, they should kick it to the correct forum for you.
Old 07-19-2008, 02:16 AM   #5
shadymilkman129
Member#: 53651
Cert Suby tech
gotchya, sorry about that. Thank you.
Old 07-19-2008, 11:22 AM   #6
sidewayz
Member#: 5810
2001 S366 2.5RS
where did you find this "ground" ?
sidewayz is offline   Reply With Quote
Old 07-19-2008, 02:26 PM   #7
shadymilkman129
Member#: 53651
Cert Suby tech
IT was just loose behind the intercooler near the starter.
Old 07-19-2008, 03:33 PM   #8
sidewayz
Member#: 5810
2001 S366 2.5RS
there is no ground back there with those colors.
Those color wires are usually a power wire in a Subaru
There is a ground at the starter bk/yl
and a small ground on the pass side of the pitchstop.
http://ken-gilbert.com/wrx/mans/7%20-%20WIRING.PDF
Old 07-19-2008, 06:59 PM   #9
parkes
Member#: 166898
1994 T leg SS
ABM
Do the little things, put a 6 speed starter there see if it helps, or compare product codes between the 5 speed and the 6 speed starter, chances are if there diffrent the starter is diffrent
parkes is offline   Reply With Quote
Old 07-19-2008, 07:22 PM   #10
shadymilkman129
Member#: 53651
Cert Suby tech
Checked the denso number and there the exact smae starters, even counted the number of teeth. Im guessing i was missing the ground from my starter. I just need to find if the ground should bolt to the bottom bolt of the starter near the brass twist, or the top bolt which is a direct connection to the poisitive batter lead....
Also where to ground the other end to. I appreciate all the help guys
Old 07-19-2008, 07:28 PM   #11
parkes
Member#: 166898
1994 T leg SS
ABM
1 ground, starter to battery
Old 07-19-2008, 07:38 PM   #12
shadymilkman129
Member#: 53651
Cert Suby tech
So nothing gets attached to the lower bolt? just the leas to the battery on the top bolt and the 2 wire white plug>?
Old 07-19-2008, 07:51 PM   #13
novacivic
Member#: 117980
2005 sti
wr blue
do not hook the ground to the positive lead the ground goes on the mounting bolt for the starter
novacivic is offline   Reply With Quote
Old 07-20-2008, 11:54 AM   #14
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Bad ground. Like the guy above said, the ground wire actually attaches via one of the transmission bolts that holds the starter in place.
dwx is offline   Reply With Quote
Old 07-20-2008, 02:46 PM   #15
shadymilkman129
Member#: 53651
Cert Suby tech
Ok so dont hook a ground up to either of the bolts that are on the starter, hook it up to one of the bolts holding it into the bellhousing? Ill try that and see if the starter works... I have no idea why my fuel pump is not working though. I tried plugging in the two green wires, I could hear the fans kicking in, but no fuel pump action... Is there a fuse for the fuel pump anywhere?
Old 07-20-2008, 09:29 PM   #16
Draco-REX
Member#: 63834
07 STI
Your PM box is full so I can't reply. My thread doesn't apply to this, the wires I was talking about were in the steering column. Wish I could help more.
Draco-REX is offline   Reply With Quote
Old 07-20-2008, 10:43 PM   #17
mannac
Member#: 161038
2014 FiST
The fuel pump relay should be way on the passenger side to the right of the ecu but up where a bunch of wiring meets. The main relay is there (brown) and the fuel pump relay should be green right next to it.
mannac is offline   Reply With Quote
Old 07-21-2008, 03:03 PM   #18
shadymilkman129
Member#: 53651
Cert Suby tech
Should I reset the relay? the other codes are gone now, except for p1086. I found that the plugs under the rear seat were unplugged. I plugged them back in changed the #11 fuse that was blown for the fuel pump, i tried agian the fuel pump kicked on for a second and blew the fuse agian. I put a 20 amp fuse in it pumps fine but just turns over and over. How and I reset the fuel pump relay? Im going to check to see if my spark plugs are still firing but i doubt thats the issue...
weird problems after 6 speed swap. Alaskan EJ20 Alaskan Impreza Club Forum -- AKIC 12 11-06-2008 05:30 PM
weird problems after 6 speed swap. Alaskan EJ20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-17-2008 08:23 PM
weird problems after 6 speed swap. Alaskan EJ20 Transmission (AT/MT) & Driveline 3 08-15-2008 08:20 PM
weird problems after 6 speed swap. Alaskan EJ20 Electrical & Lighting 2 08-15-2008 06:24 PM
Problem with clutch after 6 speed swap scooby2.0t Transmission (AT/MT) & Driveline 33 03-10-2008 03:47 PM
