Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 11-27-2015, 06:42 PM   #3076
yertle
Member#: 71910
2005 WRB WRX - Stg 2
2013 DGM WRX 5-dr
Our 5-speeds don't seem to love abuse. First gear is usually pretty notchy in the morning (with no synchro) and rev matching seems to help with other shifts. Not sure if that's your idea of babying or not, but that's what I meant.
yertle is offline   Reply With Quote
Old 11-27-2015, 10:47 PM   #3077
vicious_fishes
Member#: 158864
2003 SOHC destroker
I heel/toe every braking shift and doubleclutch every overtaking one. It's just force of habit.
We're a bit off topic now however...
vicious_fishes is offline   Reply With Quote
Old 12-05-2015, 01:58 PM   #3078
4wdwrx
Member#: 72042
2002 V7 Impreza WRX
The Blue Mammoth
I have used the cocktail long time ago, It would grind when the mixture separates.
I recommend using Subaru S Gear. I get them from the local Subaru dealer, only thing is, I had to bring my own container.
4wdwrx is offline   Reply With Quote
Old 03-13-2016, 10:40 AM   #3079
The Rig
Member#: 206870
Hi guys from over here in the U.K.
Just used redline in my 5 speed , I managed to drain 0.6 litres out via dipstick tube , which leaves about 3.3 litres of castrol syntrax in there , I then added the redline , 0.9 litre bottle .
Hopefully it cures the crunch in 2nd and 3rd with this mix ? How you all getting on with the cocktail ?
Cheers
The Rig is offline   Reply With Quote
Old 03-13-2016, 09:14 PM   #3080
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
Default Bartender: One Scotty's cocktail please.
drain it all out and use proper gear oil. its been proven most cocktails eat the brass baulk rings.
Titter is offline   Reply With Quote
Old 03-14-2016, 04:38 AM   #3081
The Rig
Member#: 206870
Well im glad i didnt use 4 litres of redline line, only the 1 bottle ha
I still have 3.4 litres of castrol in there so hopefully the blend i used isnt too bad
but will bare in mind the above when coming to refresh the oil again
cheers
Old 03-14-2016, 10:02 PM   #3082
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
redline is fine. its the synchromesh thats the bad one.
Old 08-16-2017, 08:44 PM   #3083
gosefroba
Member#: 397332
2015 WRX
ISM
Thoughts on using it with the new gen WRX. Third gear has started to grind in mine
gosefroba is offline   Reply With Quote
Old 08-16-2017, 09:47 PM   #3084
Superorb
Member#: 135252
2002 WRX Wagon
How many miles do you have?
Superorb is offline   Reply With Quote
Old 08-16-2017, 10:20 PM   #3085
gosefroba
Member#: 397332
2015 WRX
ISM
36k changed the fluid at 30k to redline 57904. Started grinding maybe 300 miles ago
Old 08-17-2017, 09:30 AM   #3086
Superorb
Member#: 135252
2002 WRX Wagon
Soooo if the grinding started not long after switching to Redline...
That's pretty low to have grinding problems too. I have 120k miles on my 02 with no grinding anywhere.
Old 08-17-2017, 11:18 AM   #3087
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Well, there's your problem right there. You are using the wrong Redline product.
You are using the 75W90.
Originally Posted by Redline
This product is not designed for use in most manual transmissions or transaxles in passenger vehicles, since the extreme slipperiness may cause synchronizer mesh issues that lead to shifting problems
You WANT the 75W90NS.
Samurai Jack is offline   Reply With Quote
Old 08-17-2017, 06:03 PM   #3088
gosefroba
Member#: 397332
2015 WRX
ISM
Sorry thats the one I used in the transmission. I did my diff and trans fluid at the same time and looked at the wrong invoice
Looking back I bought 1 qt of 57904 and 4qts of 58304
Old 08-18-2017, 12:23 PM   #3089
Samurai Jack
Member#: 21145
2002 Enemy of Aku
So, gotta ask - are you sure it's not your shifting?
I had much better shifting when I switched to the Redline 75W90NS in my 5MT.
I had even better shifting when I went from 100% Redline 75W90NS to 50% Redline 75W90NS and 50% Redline Lightweight Shockproof
Old 08-20-2017, 05:37 PM   #3090
gosefroba
Member#: 397332
2015 WRX
ISM
I have tracked the car a few times and have autocrossed it a lot. I have a few instances where I have slammed on the brakes in both autocross and track driving where the shifter falls halfway between gears and makes awful sounds (assuming the syncros being eaten).
The clutch is 100 percent depressed. Even if I go very slowly from 5th to 3rd its gonna grind. I have everything minus the Castrol Hypoy C, which is coming tomorrow. I will update with results once I swap the fluid.
Old 08-23-2017, 07:58 PM   #3091
gosefroba
Member#: 397332
2015 WRX
ISM
UPDATE: Changed the fluid and went on a 30 min drive with a lot of 5th to 3rd gear shifts. ZERO grinds seemed to have done the trick
Old 11-20-2017, 12:31 PM   #3092
Wild_bill_
Member#: 471864
So whats the present day mixture look like compared to what it was 10,5,2 years ago? Anything change?
Wild_bill_ is offline   Reply With Quote
Old 03-09-2018, 01:28 PM   #3093
STefanoA
Member#: 483140
2002 Impreza WRX STI
Blu
Hello guys, greetings from Italy. I used grimmspeed cocktail mix in my STI 02. I'm very happy !! My STI Scratched a bit in all rots and very much in IV and V. I was already ready to spend 1800 Euro for gearbox gears. Put the mix after a while, all went well. Thanks Grimm
STefanoA is offline   Reply With Quote
Old 12-07-2018, 05:02 PM   #3094
vrios969
Member#: 493613
2006 WRX Wagon
Originally Posted by njskatchmo View Post
2qt 80w90 Castrol HypoyC(NOW labeled Axle Limited Slip 80W-90 by Castrol in North America) NO stupid PM's on this either
i cant find castrol or axle limited slip ANYWHERE!! Any alternatives to this fluid ?? Or where Can i find it?
vrios969 is offline   Reply With Quote
Old 02-17-2020, 03:40 PM   #3095
Jeaux-D
Member#: 511424
Default 4th Gear Grind: Not any more
First Subbie, bought 2 weeks ago. 2002 WRX, 124,500 miles. While test driving, out of respect, I was pretty gentle (last time that happens). After monies exchanged grease-monkey fists I put her through the paces but couldnt 100%. 4th was grinding up-shifting and down shifting; worse when down-shifting. I could kinda float her into 4th from 3rd but 5th to 4th may as well just thrown rocks in the gear box. Did my reading here, Amazon'd my **** (HEAVY Shockproof), followed the recipe, and within 10 miles 3 to 4 was at nearly normal shifting: 5 to 4 I could at least float her into gear. Just did a 300 mile run and EVERYTHING SHIFTED ON POINT!!!! Up and down, all gears, whenever I needed (NOT RACING CONDITIONS) but at a Daily Driver pace it was slicker'n cat **** on linoleum. Dont know what kinda Voodoo Magic Mike jizz this is but at the time of this writing itll give me some time to save up for a tranny rebuild.
Jeaux-D is offline   Reply With Quote
Old 06-05-2022, 04:15 PM   #3096
designfate
Member#: 114502
Edit: nvm I went with Motul
designfate is offline   Reply With Quote
Old 09-22-2023, 03:55 PM   #3097
Colossus127
Member#: 535580
Worked great for my 03 Bugeye!
Colossus127 is offline   Reply With Quote
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 27 03-10-2018 09:32 PM
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 04:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 10:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 04:29 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 08:36 AM
