Welcome to the North American Subaru Impreza Owners Club Thursday February 20, 2020
Old 05-07-2012, 09:49 PM   #51
blu-rex
Member#: 310090
so I've tried to search around but haven't really had any luck with finding the info i needed. i have an 06 wrx and was wondering what i need or might need to change to run a full sti longblock. are the sensor all the same and would i have to do any wiring or run a different ecu. if there is a thread out there for this i apologize in advance and would appreciate if someone could post it. thanks
blu-rex is offline   Reply With Quote
Old 05-16-2012, 03:17 AM   #52
padilla
Member#: 169758
2015 STI
World Rally Blue
We'll it happened. I spun a rod bearing and warranty won't cover it. So I have a plan to swap a 2011 sti(ej257) engine in my 2011 Wrx(ej255) one thing is will I need a Sti Ecu or can my wrx ecu work? Also what about the harness on the Sti engine, will it plug right in or will I need to do some modifications? That's all I need to know. Thank you.
padilla is offline   Reply With Quote
Old 05-16-2012, 10:53 AM   #53
BMXspears
Member#: 79339
2002 EJ257 6spd WRX
Midnight Black
I would assume since the STI has avcs on both intake and exhaust cams while the WRX only has it on one cam, that the wiring is different. The ecu probably will not plug right in either.
You could get service manuals for both cars on eBay and compare the schematics.
BMXspears is offline   Reply With Quote
Old 05-16-2012, 05:46 PM   #54
padilla
Member#: 169758
2015 STI
World Rally Blue
I was afraid of that. Will I have to get a full body harness? Ill check on that eBay thing right now.
Old 05-16-2012, 07:06 PM   #55
BMXspears
Member#: 79339
2002 EJ257 6spd WRX
Midnight Black
If you find out that the wiring is different, yes.
Old 05-19-2012, 04:31 PM   #56
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
Vanilla just swap the short block use your heads and ecu so you debt have to change the harness and everything g
robbieshonda is offline   Reply With Quote
Old 05-19-2012, 05:33 PM   #57
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Sorry phone auto corrected padilla
Old 05-20-2012, 11:38 PM   #58
Imprezid
Member#: 320777
2005 STI
Im currently workin on a swap. Great into! Will come in handy
Imprezid is offline   Reply With Quote
Old 04-07-2013, 10:45 PM   #59
Awd turbo
Member#: 350462
2000 Rs coupe
Awd turbo is offline   Reply With Quote
Old 04-09-2013, 01:40 PM   #60
Awd turbo
Member#: 350462
2000 Rs coupe
Will an 08" &components fit an 00rs? I know 06/07's do
Old 04-22-2013, 12:58 PM   #61
metalheadx86
Member#: 354158
2008 Impreza
I just purchased a 2008 impreza and would like to swap either a ej255 or ej257 into it. Don't know where to start other than buying the block...
metalheadx86 is offline   Reply With Quote
Old 07-25-2013, 02:45 PM   #62
eweisner
Member#: 363336
Ok...I must be missing something. I can't seem to find any info on Phase II swaps. I'm working on dropping a 2.2L Impreza A/T in place of a 2.5L Legacy L M/T. Not finding much.
eweisner is offline   Reply With Quote
Old 08-11-2013, 08:07 PM   #63
shaun1579
Member#: 365090
Thanks for sharing
shaun1579 is offline   Reply With Quote
Old 08-13-2013, 04:38 AM   #64
percyrr
Member#: 276254
On ly side, i just bought an engine from 08+Sti Ej25, i'm using Motec M800 with cable throttlebody, car is starting well with 0.6boost, but flutters after 6krpm, one of the AVCS is missing ... I'm trying to find if it is AVCS related, or tuning problem, if i stay under 0.8bar boost, car is doing fine, above that it's anyone's guess... Any help guys?
percyrr is offline   Reply With Quote
Old 08-27-2013, 10:21 PM   #65
wphan0809
Member#: 362798
2004 wrx
WR Blue
It sounds like your throttle cable is too tight you might want to check that.
wphan0809 is offline   Reply With Quote
Old 09-03-2013, 03:04 AM   #66
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
My04 Wrx has been running a Wrx ECU and engine harness an an 05 sti longblock with top feeds and Wrx mani and cable tb. I want to set it up more correctly since its apart right now for some front end work. What engine harness, ECU, and etc. do I need to run this either with an sti ECU, for avcs, or stand alone. I'm real curious as with my Wrx tgvs intake mani and top feeds with 800cc inj what I can do to clean the setup a bit and make it more 'correct'. Thanks.
srREXed is offline   Reply With Quote
Old 09-03-2013, 03:06 AM   #67
srREXed
Member#: 72234
2004 WRX SRR
EJ257-35R-6MT
Also, should I source a jdm sti engine harness and ECU? And if so which ver should I try to source? And my 16bit USDM ej20 is running this all.
Old 12-24-2014, 01:54 AM   #68
Truslide
Member#: 227079
Hi Everyone,
I'm seriously having trouble finding out what I would need to drop an 08+ STi Engine with fully functioning AVCS into my 06 Legacy GT? Just blew the motor and want to go with the newer version. Also, is that compatible with the auto trans? (It's my sister's car lol)
Truslide is offline   Reply With Quote
Old 12-24-2014, 11:17 AM   #69
MMY MSL
Member#: 335135
2007 WRX
WRC blue
Originally Posted by Truslide View Post
Hi Everyone,
From what I remember when I was researching putting an 08+ sti drivetrain into an 02 Forester the 08+ STi's use a new CAN bus ecu that requires readings from a number of different sensors throughout the car (speed sensor in wheels, DCCD g sensor, and immobilizer, etc) to function properly, so while it might be possible to jury rig those sensors into another car it's no small undertaking. As for just using the engine maybe you could, but without the ECU it's not going to run dual AVCS, which is the big difference from the 04-07 STi.
Another consideration that I lost sight of for a while was OBDII emissions testing, which we in Oregon have to worry about. If the car has any ECU other than it's original with the original VIN burned into it you automatically fail emissions. If the ECU is for a car other than the car it was intended for (a corvette ECU in a 96+ miata) then you fail automatically.
Easiest thing for you to do hands down would be just buy an ej257 shortblock from flatironstuning.com for $1800 (you can use an 09+ STi short block if you want) IF the heads on the Legacy GT are still good. If not then tear down the motor and see if it's repairable through a builder.
Honestly unless you were doing a decent turbo upgrade at the same time simply swapping an STi's ej257 wouldn't make any difference from the ej255 you already had in the GT and blew up from what I've seen across the interwebs. The power output differences in modern EJ257s and older EJ255s are subtle and come down to dual AVCS and the VF48.
Do a shortblock if you can and upgrade the turbo and tune it (16g, VF52, 380xt) then just drive and enjoy. That's my two cents as a studied novice.
MMY MSL is offline   Reply With Quote
Old 01-11-2015, 10:33 PM   #70
Raymond hoag
Member#: 410695
This is a little off the subject but can you tell me if a 255 long block from an 07 model xt will work in an 04 model?
Raymond hoag is offline   Reply With Quote
Old 01-15-2015, 09:03 PM   #71
Raymond hoag
Member#: 410695
Can I swap an 06 or 07wrx engine into an 04 xt
Old 01-20-2015, 11:36 AM   #72
DRC Saabaru
Member#: 411344
2005 Saab 9-2x Aero
I just bought a 2005 9-2x (WRX) and it spun a bearing on the drive home
Can anyone give me some insight on my best course of action? Right now I'm thinking about an ej255 or ej257 short block hybrid. Will I be able to run everything from an 05 WRX on that block without any issues (I will be lowering compression of course)? I would have it tuned conservatively with the td04 and a Walbro 255 fuel pump. Would I still need bigger injectors and would my wiring harness match up? I am extremely new to Subarus (I only had it for a day) but I have experience working on plenty of other brands, but if this proves too complicated I might just put in a new ej205 short block and be done with it. Thank you guys for all the info!
DRC Saabaru is offline   Reply With Quote
Old 01-30-2015, 05:11 AM   #73
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Actually read like the first 3 post
domestic_abuser is offline   Reply With Quote
Old 02-12-2015, 09:22 PM   #74
tt383lt1
Member#: 402788
hi im doing a 04 sit swap into my 03 wrx. what do i need to do to get the avcs to work right?
ia performace avcs wiring kit
where do i buy the ecu to get it to work? will a stock 04 sti work with the avcs?
and im actually have no sensors from the sti im building the block from scratch.
ej257 block
je pistons
turbo tuff i beam rods
stock crank
b25 heads off of a 04 sti
thanks
tt383lt1 is offline   Reply With Quote
Old 02-13-2015, 02:02 PM   #75
MMY MSL
Member#: 335135
2007 WRX
WRC blue
My memory when I was researching swapping an EJ255/57 into my old Forester was that you needed:
-AVCS ECU
-Matching immobilizer and key
-Ignition with antennae for chipped key
-Roll connector that fits your car (the 04 STi had a single stage airbag and the 05+ had a dual or something, I can't remember the exact reason but for older Subaru's they tended to be single, so the 04 STi was the only choice or an 06-07 WRX IIRC)
-AVCS wiring harness and harness merge from I-wire or someplace like that
-Drive by wire throttle body
-Drive by wire gas pedal
-AVCS oil lines, they aren't all the same as the non AVCS heads
My personal opinion after looking over the possibility of using AVCS on that project for over a year or two was that the added wiring and cost to include AVCS was no where near worth the very minimal gains that AVCS seemed to show vs a long block EJ25 swap or a hybrid EJ20/25. I compared dozens of dynographs on EFI Logic and Cobb's dyno databases and really could not see an appreciable difference anywhere, and considering the extra parts and wiring adds about 1500 in cost it's money better spent elsewhere IMO.
What all has the EJ25, and what is needed for my swap? Karas Newbies & FAQs 2 10-05-2009 12:31 AM
99 ej25 swapped with 05 ej25 aaronthehic Subaru Conversions 0 08-23-2009 07:33 PM
tranny swap guide sk84fun21 Transmission (AT/MT) & Driveline 4 03-10-2008 11:10 PM
EJ25 to EJ25 swap, first time, good tips and tricks to know? Patrick Olsen Subaru Conversions 8 11-27-2006 11:14 PM
Trunk Lid Swapping Guide? f4phantomii Interior & Exterior Modification 5 04-06-2004 08:52 AM
