Welcome to the North American Subaru Impreza Owners Club Thursday February 27, 2020
Old 12-30-2016, 02:24 PM   #5326
cmpequeno
Member#: 87036
2002 Impreza Outback
Red
cmpequeno is offline   Reply With Quote
Old 01-20-2017, 05:11 PM   #5327
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
My 2007 OBS w/ 5MT. It's lifted on FXT suspension w/ rear spacers, converted to sedan track, and has the complete set of 97-99 Outback body spacers installed. This summer I will be installing a Forester dual range 5MT w/ 4.44 FD, Suretrac R160, and 215/65/16 Grabbers.
03SubyWRX is offline   Reply With Quote
Old 01-21-2017, 12:05 AM   #5328
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
Where did you locate the dual range forester tranny? I'd love to complete my lifted 05 Baja with one of those
Buck Rogers is offline   Reply With Quote
Old 01-21-2017, 01:11 PM   #5329
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
JDM Racing Motors in Montreal. Great group of guys and they always treat me well when I drive up to buy parts from them.
FYI, my 03 Forester dual range came with 4.11s, but I installed 4.44s into it because I wanted the extra oomph.
Old 01-22-2017, 01:09 AM   #5330
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
Thanks for the info, not an unreasonable drive from were I live
Old 01-31-2017, 12:12 PM   #5331
powder007
Member#: 130729
2004 WRX
JBP
I have an 04 WRX that i'm going to lift on King Springs soon. Looks like they give 1.4 front/1.5" rear. What should i be looking at for struts as i know being lowered has probably put my struts close to being bad by now after about 160k miles on them.
Also i want bigger tires. I found some Yokohama Geolandar A/T-S in 235/60-16 for a good price. I'm wondering what it would take for these to fit as they come out to 27.1" diameter and 9.25" wide. I'm guessing a small spacer would be necessary or an offset wheel as the tires are 1.2" wider than stock essentially. But if i have to go with a different wheel i'll end up going with a different size tire and try to offset it so i can get a 245 on. How many have gone with this wide of a tire in this diameter? How likely am i to run into rubbing issues?
powder007 is offline   Reply With Quote
Old 01-31-2017, 01:47 PM   #5332
Chuckls
Member#: 280696
Here's whatcha do:
FXT struts
2inch spacers from ADF.
15x7+48 Method 501VT Spec
215/70/15 geolander
Chuckls is offline   Reply With Quote
Old 01-31-2017, 02:01 PM   #5333
powder007
Member#: 130729
2004 WRX
JBP
Originally Posted by Chuckls View Post
Here's whatcha do:
FXT struts
215/70/15 geolander
I want this setup. Just have to know if someone's tried something similar.
FXT Struts
King Springs
16x7 Konig Helium +40mm
235/60-16 Geolandar
Any input?
Old 02-01-2017, 12:36 AM   #5334
mountain_rex
Member#: 462182
Default Not mine, but still awesome
Captured at a NorCal Rally X event
mountain_rex is offline   Reply With Quote
Old 02-01-2017, 07:38 PM   #5335
cartwheels4amile
Member#: 190405
2002 Impreza WRX
http://i.imgur.com/tLkzBN7.jpg
Just got the L Presidente lifted up on Forester struts. Gotta install the trailing arm brackets to center the rear wheels and then get it aligned. Looking forward to hitting some dirt!
cartwheels4amile is offline   Reply With Quote
Old 02-02-2017, 01:48 AM   #5336
landcrush
Member#: 462064
clean rides
landcrush is offline   Reply With Quote
Old 02-06-2017, 10:09 AM   #5337
Bald_Wrex
Member#: 236005
2017 Outback 3.6R
WGM
2017 Outback 3.6R Limited
17 x 8 Motegi Racing MR118
Falken Wildpeak AT3W 245/65R17
Gorilla black lug nuts
Primitive Racing snow shield
Primitive Racing engine skid plate
Primitive Racing transmission skid plate
Primitive Racing rear diff skid plate
Rola 52" roof basket
Bald_Wrex is offline   Reply With Quote
Old 02-06-2017, 03:52 PM   #5338
theoutbackdream
Member#: 301179
2013 WRX Limited
Thinking about getting a 2" ADF lift for my impreza. Will I need anything else other than the spacer?
theoutbackdream is offline   Reply With Quote
Old 02-06-2017, 03:59 PM   #5339
powder007
Member#: 130729
2004 WRX
JBP
Ordered my parts yesterday. King lift springs, KYB GR-2's and 16x7 gunmetal Vision 425 Bane wheels. Once the lift is installed i'll head to the tire shop and have them test fit a couple sizes and if the 235/60's clear then i'll go with them. If not, then i'll go with BFG K02's or Toyo Open Country AT II's in 215/70 and possibly use some spacers to get flush.
Old 02-06-2017, 10:44 PM   #5340
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
Looks great!
Old 02-06-2017, 10:58 PM   #5341
Chuckls
Member#: 280696
2005 Forester Struts and springs
ADF 1inch strut top spacers
2inch trailing arm spacers
Loyale Fabrications adjustable front endlinks
Yakima Qtower (Soon to be doing the 08+ Landing pad mod_
Load warrior basket with 400w PA system and speaker mounted on top
http://i.imgur.com/DYwEezh.jpg
Old 02-07-2017, 12:42 PM   #5342
powder007
Member#: 130729
2004 WRX
JBP
Looks awesome Chuckls.
Old 02-07-2017, 01:41 PM   #5343
powder007
Member#: 130729
2004 WRX
JBP
Your Outback looks really good too Bald_wrex.
Old 02-08-2017, 09:57 PM   #5344
theoutbackdream
Member#: 301179
2013 WRX Limited
I'm planning to get the ADF 2" lift for my impreza. Do I need to buy the multi link spacer kit as well?
Old 02-10-2017, 10:39 PM   #5345
theoutbackdream
Member#: 301179
2013 WRX Limited
Still need to get tires wheels and thinking about a 2" adf kit.
http://i.imgur.com/CLotFw4.jpg
Old 02-11-2017, 04:12 PM   #5346
MH1787
Member#: 423245
2015 Wrx
World Rally blue
Do it, I am so happy I got mine. Mine is a 2015 wrx and it is the best decision I made. You should get the multilink rear kit(needed to run larger tires otherwise the wheels sit to far back to go much larger) I would recommend getting the whole kit as well as the extra 3/8 in the rear. Mine sits perfectly level with this set up and still retains all/most the handling I had before.
MH1787 is offline   Reply With Quote
Old 02-11-2017, 04:56 PM   #5347
theoutbackdream
Member#: 301179
2013 WRX Limited
Were you the one who posted your WRX on reddit awhile back?
Anyways...
is the multilink rear a must? IE: Can I run a stock size tire, or similar? I'm thinking about buying a used set of 16" wrx wheels. I've never gotten an answer yet and tried searching around with no answer.
Good to know though! Thanks!
Old 02-11-2017, 05:02 PM   #5348
MH1787
Member#: 423245
2015 Wrx
World Rally blue
Anyways...
No not mine on reddit. I don't have any pictures on the Internet of mine. Can't figure out how to post pics on this forum. It is not a must no. The only thing it does is re-center your rear wheels. I would seriously recommend getting it though. Without it you could run stock size yes but it will look funny with the wheels being more toward the front. I would talk to the guys at ADF, they were so much help to me when I was looking, great product also.
Old 02-11-2017, 06:12 PM   #5349
theoutbackdream
Member#: 301179
2013 WRX Limited
Gotcha...
So it's not really used as a preventative measure? I read somewhere that the multilink spacer was either 1) only for recentering the wheels 2) A must to prevent CV damage.
Old 02-12-2017, 09:44 AM   #5350
MH1787
Member#: 423245
2015 Wrx
World Rally blue
Gotcha...
Not to my knowledge no think it would be safe. I was under the impression that the back can handle more lift/drop then the front. But either way ADF told me that 2in would be within the limits before I had to start dropping lots of other parts, but I am no expert on any of this, far from it. Also how do you post pictures on this website I could never get a straight answer out of anyone? Thanks
Chamois, or just plain Sham? Lifino Interior & Exterior Modification 8 10-02-2013 09:01 PM
SOA gotta love 'em or just plain hate 'em kalbo-1 Warranty Issues & SOA Problems 1 01-19-2004 09:29 PM
Hot or Not or Just Plain Ok.... n20x3whitewrx Member's Car Gallery 28 07-29-2002 11:05 AM
McRae: Dedicated or just plain nuts? SubaruStu Motorsports 2 03-20-2002 10:55 AM
Jinxed? Or just Plain UnLucky??!! silverSurfer General Forum Archive 6 06-30-2000 11:27 PM
