07-16-2001, 11:19 AM | #1 |
Member#: 2035
Can an OBD-II scanner reset the ECU?
Do any of the aftermarket OBD-II scanners allow you to reset the ECU, or can you just read and clear codes? I'd really like a better way to clear the ECU than just disconnecting the battery...
Thanks, JulianH
07-16-2001, 05:18 PM | #2 |
Member#: 1109
Vehicle:1999 Suzuki Samurai Blackish |
Unbolt the cover for the ECU under the passenger side floormat. Pull the 3 plugs from the ECU and leave them out for about 10 minutes.
It will leave your ECU as naked as the day it was born, and you get to keep your radio presets! Resetting those takes longer than bolting down the plate again! |
07-16-2001, 08:47 PM | #3 |
Member#: 3334
i'm not sure on this but there is a constant power supply going to the ecu and it can't be too good for it if you unplug the harness with out unhooking the battery first.
07-16-2001, 10:43 PM | #4 |
Member#: 689
NESIC
Vehicle:2005 Outback 2.5 XT Champagne Gold Opal |
There should be no problem with disconnecting the ECU at the connector, as long as the ignition switch is OFF. Just don't do it when the main relays are on and the ECU is driving big loads. Common sense.
I like this method because I get to keep my radio presets, and the alarm (remote door locks) still works. -WaC Wayne |
Does anyone have an OBD II scanner for a 99 2.2 L | shoracer | Texas Impreza Club Forum -- TXIC | 6 | 08-18-2005 12:54 PM |
Anyone in JAX have an OBD-II scanner? | hobbzz | South East Region Forum | 4 | 02-21-2003 12:45 PM |
Anyone got an OBD-II scanner I could use? | scotty305 | Southern California Impreza Club Forum -- SCIC | 2 | 12-20-2001 05:41 AM |
For those of you with an OBD-II scanner. | tmat3 | Normally Aspirated Powertrain | 0 | 11-21-2001 11:54 AM |
Anyone here have an OBD-II scanner? | blaster88 | Mid Atlantic Impreza Club -- MAIC | 2 | 05-31-2001 11:48 AM |
