Brakes & Suspension Forum sponsored by The Tire Rack |
12-21-2003, 03:20 PM | #1 |
Member#: 36618
Vehicle:1984 project justy wrb |
HELP: how to install rear strut bar for sedan
can someone show me how to install the rear strut bar on a 02-04 wrx
if possible pls add some pics with the explaination cuz i am really dumb with instructions thanks
12-21-2003, 03:42 PM | #2 |
Member#: 10757
Vehicle:2013 BRZ Limited 6MT DGM |
12-21-2003, 03:46 PM | #3 |
Member#: 25399
Vehicle:2003 Impreza WRX Black |
Search and you will find answers.
Summary: -remove rear seats -remove top nuts from strut tops -place strut tower brace brackets through hole next to strut top into trunk area -attach bar to strut brace brackets showing in trunk -line up 3 holes with strut top studs -put strut top mount nuts (new ones ideally) on studs and tighten to 14ftlbs, don't break them -tighten up bracket to bar bolts in trunk -put seat back -be careful driving til you get used to it, especially in the rain |
12-21-2003, 03:47 PM | #4 |
Member#: 36618
hey calvin thx
so installation is the same for the 04s as the older impreza??? |
12-21-2003, 03:50 PM | #5 |
Member#: 10757
Yes
Calvin |
12-21-2003, 03:51 PM | #6 |
Member#: 36618
thx guys
when u say "tighten to 14ftlbs" whats that mean? also i installed the front bar already but on the passenger side i think horn is in the way so i couldnt put the boils all the way in |
12-21-2003, 03:56 PM | #7 |
Member#: 10757
You need to use a torque wrench on those nuts and torque them to no more than 14.2ft-lbs. As for the horn on the front passenger strut tower, you need to relocate it. Those nuts need to be tightened down or they will allow your shocks to move around inside the shock tower and possibly cause damage. If you aren't sure about what you're doing, find someone that does. You can do more damage than good.
Calvin |
12-21-2003, 05:57 PM | #8 |
Member#: 10279
Vehicle:2005 Lotus Elise Yellow, #94 SS |
Here's another page with instructions:
http://www.oakos.com/wrx/installs/RSTB/ In case you can't get a torque wrench to those strut top nuts (there's not much room): 14ft-lbs is not much at all! Be gentle tightening them, or your next search will be for keywords "strut top stripped". |
12-21-2003, 07:08 PM | #9 |
Member#: 36618
ok thx guys
so where should i relocate my horn? |
12-21-2003, 07:36 PM | #10 |
Member#: 15106
coolray- there should be another bolt in vicinity of the
strut bar where you can tighten it down to. as long as the horn's mounting tab is grounded, you can mount it anywhere that the cord can reach. |
12-21-2003, 07:42 PM | #11 |
Member#: 36618
i just put the horn on top of the strut bar stand and tighten it that way
cuz before the 2 horn's nuts was in the way so i couldnt boil the strut bar nuts all the way down but now the 3 strut bar nuts are able to go all the way down since i put the horn on top of the stand instead of the other way around btw what do u mean by "horn's mounting tab is grounded" THanks a lot guys i know i am a pain in the ass |
12-22-2003, 09:25 AM | #12 |
Member#: 11620
Vehicle:1997 GF4-STiV3 clone |
Cooray,
You need to stop boiling your nuts. That sounds painful! 'Grounded' means that the tab is touching bare metal on the chassis so that it makes an electrical circuit. FWIW. Your strut bar installation will no just about bugger all for performance. I hope you like the look and don't break anything on the install. Cheers. |
whiteline rear strut bar for sedan? | dubya-R-ex | Brakes, Steering & Suspension | 2 | 07-15-2006 04:42 PM |
White Line rear strut bar for sedan.. | WRXBob | Private 'For Sale' Classifieds | 2 | 11-24-2005 08:49 AM |
GT SPEC Rear Strut Bar for Wagon and Sedan | RavSpec | Vendor 'For Sale' Classifieds | 15 | 03-01-2004 12:55 PM |
Whiteline sedan rear strut bar for sale | Willman67 | Texas Impreza Club Forum -- TXIC | 6 | 08-01-2002 01:32 AM |
Rear strut bars for WRX sedan | Dave99 | Brakes, Steering & Suspension | 15 | 07-12-2002 11:53 PM |
