Welcome to the North American Subaru Impreza Owners Club Wednesday October 17, 2018
Go Back   NASIOC > NASIOC Technical > Normally Aspirated with bolt-on Forced Induction Powertrain
Old 03-02-2004, 09:41 PM   #1
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Default WRX Fuel pump into 98 RS
This is a quick question I thought would best be asked here since I couldn't find the answer. Does the WRX fuel pump swap directly into a 98 RS? I read some past posts that made it seem that the 98 and 99-01 RSs have different fuel pumps, and also came across different part numbers for the walbro pumps for those years.
I have a WRX pump, but don't want to bother wasting my time with an install if it won't work.
jonathan
ilmaestro is offline   Reply With Quote
Old 03-02-2004, 10:02 PM   #2
Homemade WRX
Member#: 33782
96 3MI Racing LLC
search FIRST, then PM!!!
I installed a walbro fuel pump ment for a 02 WRX into my 94..so it should be fine for you
Old 03-02-2004, 10:09 PM   #3
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Yep. WRX pumps are a direct swap.
Heres something even cooler, the Legacy Turbo pumps,
Here's a quote from Legacycentral...
GD/GG WRX stock fuel pumps are specified to flow at least 130 liters per hour at 43.5 psi with a 12 volt power supply.
BC/BF Legacy Turbo stock fuel pumps are specified to flow at least 150 liters per hour at 43.4 psi with a 12 volt power supply.
Wedge is offline   Reply With Quote
Old 03-02-2004, 11:05 PM   #4
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Hah. Cool thanks guys. Gotta love being able to use a $20-30 part
jonathan
Old 03-03-2004, 07:33 AM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
I'll second the direct P&P placement comment. Works like a charm!
Jay Storm
www.sourcemotorsports.com
2006 WRX fuel pump fitting onto a 98 Impreza L 2.2?? silver06wrx Pre-2002 Factory Turbo Powertrain 1 04-08-2007 10:35 PM
wrx fuel pump in 98 impreza L? rufracer Normally Aspirated Powertrain 6 04-08-2007 12:59 PM
VF39 and STi Fuel pump into 03 WRX.. bolt right up or problems? Dakken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-18-2005 01:09 PM
wrx fuel pump into 00rs gas tank watcher in the sky Subaru Conversions 5 03-30-2005 04:08 PM
WRX fuel pump in 98 RS? IllNastyImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 4 05-30-2004 10:56 AM
