Welcome to the North American Subaru Impreza Owners Club Saturday October 20, 2018
Old 03-29-2005, 11:08 PM   #1
watcher in the sky
Member#: 3513
1997 Legacy Outback
Default wrx fuel pump into 00rs gas tank
swapping 03 wrx into 00rs, need to get fuel pump, but is that it? need to get any hoses.. etc? or is the fuel pump good enough? Mechanic near here is familiar with it all, but havent gotten a chance to talk to him about it.. and need to order stuff
watcher in the sky is offline   Reply With Quote
Old 03-29-2005, 11:26 PM   #2
agterlik
Member#: 41626
SPB We make people
quit teh internet
you need the fuel pump and the controll unit. The rs pump ran at one speed where as the wrx pump/engine requires the control unit to run at several different speeds.
agterlik is offline   Reply With Quote
Old 03-30-2005, 12:10 AM   #3
watcher in the sky
Member#: 3513
1997 Legacy Outback
control unit part of harness perchance? I wouldn't know. Someone else is doing this for me, I just need to order somethings
Old 03-30-2005, 12:41 AM   #4
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Fuel pump controller . Its part of the rear harness. Normally is located in the trunk on the right hand side near the fuel door/filler.
Ver.III is offline   Reply With Quote
Old 03-30-2005, 02:33 AM   #5
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
Don't bother... just use a walboro 255lph pump and be done with it. They're cheap and everywhere.
no-coast-punk is offline   Reply With Quote
Old 03-30-2005, 04:08 PM   #6
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
You can get away without using the FPC. You will get a CEL if you are not running one but the car will run fine. As stated already get the Walboro unless you can find a killer deal on a stock WRX one.
Z
Zephyr is offline   Reply With Quote
Installing an 08 Sti fuel pump into an 02 WRX Vlad Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-26-2009 08:55 PM
AR -02 Wrx Fuel Pump, Y-Pipe, Washer Tank gotboost02 Engine/Power/Exhaust 6 04-08-2008 08:08 PM
VF39 and STi Fuel pump into 03 WRX.. bolt right up or problems? Dakken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-18-2005 01:09 PM
really need wrx fuel pump assembly, maybe a tank vortectoy Private 'Wanted' Classifieds 0 04-15-2005 02:29 PM
WRX Fuel pump into 98 RS ilmaestro Normally Aspirated with bolt-on Forced Induction Powertrain 4 03-03-2004 07:33 AM
