Welcome to the North American Subaru Impreza Owners Club Friday June 20, 2025
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 10-07-2016, 04:31 PM   #576
Boxer4turbo2004
Member#: 106190
Phil you guys built my pro comp build 2 years ago .my fuel pumps prime on the ignition switch via output on hydra ..for some reason the pumps no longer come on I have tested pumps and wiring my laptop connects to the hydra. I am uncertain what is going on . I am in need of a final tune and I seen in previous post where you said you "travel the country tuning hydras" this would make the process much easier for me as I wouldnt have to trailer the car to jersey. I emailed element tuning a couple of times with no response and called not sure what else to do
Boxer4turbo2004 is offline   Reply With Quote
Old 07-19-2017, 10:59 PM   #577
Getnit206
Member#: 471359
Angry Hydra issues??
Hello i have an 04 wrx with the 2.0l turbo and i am trying to install an hydra stand alone out of an 05 sti i have already swaped the wiring harness from the o5 into the 04 and the ecu and i need a new map for a o4 wrx with a front mount ic and an under drive pully setup with a stock up pipe stock injectors and a 3" gready downpipe and exuast i have also installed all dccd sensores and the 6 speed out of the 05 along with all drive train componants. My main concern is the dbw is not installed so will it be possible to get a map for an 04 wrx 2.0l with an 05 sti hydra that had a 2.5l dbw setup ?
Getnit206 is offline   Reply With Quote
Old 11-23-2017, 07:17 AM   #578
francisco1971
Member#: 407601
Default need hydra ems 2.5 ems software
hy people and happy thanksgiving to all. ok i just finish my project. it is an impreza wagon 2002 with a full 2005 sti swap and im running a hydra ems 2.5. for some reason my computer is dead and i can't fine my cd to download it to anoteher lap top. and i need to tune it. can any one help? where can i find a site so i can download it or any guy tha work for hydra or element tunning. please
francisco1971 is offline   Reply With Quote
Old 11-23-2017, 06:51 PM   #579
Tap
Member#: 21893
2002 WRX w/STi swap
Tap is offline   Reply With Quote
Old 12-17-2017, 11:16 AM   #580
francisco1971
Member#: 407601
thank you for the link. but my problem is that i installed it on my windows 10 and but i cant find it or lunch it. i tried it a bunch of times and it doest work at all. can someone help me?
thank's to all an happy hollydays
Old 11-03-2019, 08:23 PM   #581
catz4dave
Member#: 476565
2000 RSTI
74F
Reviving a dead thread here;
Currently running a Hydra 2.7 EMS with a JDM EJ255 rotated GT3076R at 18 PSI (377 whp on a mustang dyno)
Car has had this setup since Fall 2013; so around six years and about 30,000 miles. Compression tested at 5 psi within 150 for all cylinders last month.
Nothing but great things to say about the longevity of the Hydra EMS and its capabilities sustaining a high hp build for a long term daily driver.
Building a V6 EJ207 RSTI and for me its either HKS F-Con or Hydra from now on.
catz4dave is offline   Reply With Quote
Old 11-15-2019, 05:46 PM   #582
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Since there's not a post here from him about it and it's been well over a year: As some of you may know, Phil Grabow of Element Tuning took ownership of the "Hydra Nemesis EMS" and it is now known simply as "Nemesis EMS" with its website over at http://nemesisems.com/
I'm curious. How many of us are there left running Hydra Nemesis (now "Nemesis EMS") systems? I'm 1.
jblaine is offline   Reply With Quote
Old 11-16-2019, 09:18 AM   #583
SW00P_G
Member#: 5591
EJ257 Gt35r
I've moved to Haltech, but I ran the Hydra until this spring. It was a great ECU, but since development has stopped it was time to move on to new features.
SW00P_G is offline   Reply With Quote
Old 11-16-2019, 05:58 PM   #584
moby4dick
Member#: 51901
'04 WRX
Hydra running my ‘04....
moby4dick is offline   Reply With Quote
Old 11-21-2019, 10:08 PM   #585
kp05sti
Member#: 80973
Still running one here on my 06
Keep wanting to upgrade but the process is so painful starting over lol
kp05sti is offline   Reply With Quote
Old 12-04-2019, 01:18 AM   #586
stu
Member#: 25768
2003 XONA 9569S 40++
2.3 slobaru
since 05
stu is offline   Reply With Quote
Old 12-04-2019, 11:48 AM   #587
jsquared
Member#: 212052
2005 STi
You could say I'm still running it (2.5r12), but the car is in the US and I'm overseas I ran it from install in 2013 or 2014 (memory is fuzzy) and last I drove it was in late 2016 ... since then it's been parked at my mom's house and she is *supposed* to drive it for about 30 mins per month. I know when she hasn't driven it per the agreement because I usually get a video chat and she has to hook a battery charger up to top up the battery to have enough juice to start it
I bought a Euro-spec E36 M3 out here (eligible for import to the US starting this month!) but every time that dang thing has to go to the shop, I kind of wish I had just shipped the STi out here
jsquared is offline   Reply With Quote
Old 01-13-2020, 09:28 PM   #588
Tap
Member#: 21893
2002 WRX w/STi swap
How hard was it to swap over? I am running a similar setup (04 STI swap in my 02 WRX) and have been thinking about going to Haltech.
Old 02-25-2021, 09:27 PM   #589
Rizzo314
Member#: 42215
2002 WRX being built
and going for 10s :evil:
I gave up and went OpenSource with the Carberry ROM. It was too much hassle to get it tuned and it lacked any kind of support.
I wanted it to work, but now it's just a several thousand dollar paperweight on my shelf. I also have a brand new Hydra Mist I never was able to use.
Rizzo314 is offline   Reply With Quote
Old 02-26-2021, 06:53 AM   #590
SW00P_G
Member#: 5591
EJ257 Gt35r
Haltech wasn't hard. I've installed several over the past 2 years. I also have 2 Hydra 2.7 units of mine on the shelf. They do both work without issue, I just wanted new features and windows 10 support to be honest.
Old 07-17-2023, 12:16 PM   #591
CptTripps
Member#: 371033
::: Digging up a really old thread :::
I've got a Hydra 2.6 ECU running a built up EJ20 engine in my Porsche 914.
The tune that's on it now is...fine. I know there's a LOT more to be had from my engine though.
Is there anyone out there that will remote in to my computer and tune it?
Debating scrapping the whole thing and going to an FT550, but as a last resort, I thought I'd check here. I'm in NE Ohio if there is anyone out there that knows somewhere local that can work on it.
CptTripps is offline   Reply With Quote
Old 07-17-2023, 06:34 PM   #592
SW00P_G
Member#: 5591
EJ257 Gt35r
I'm located in Columbus, Ohio, and am the owner of #MundyTuned.
It's possible that I could dig up some software to work with the now-defunct Hydra. I would recommend moving to something supported, though. If you want to chat, you can contact me via PM or my website.
Thanks!
-Bryan Mundy
Old 01-04-2025, 08:35 PM   #593
traction issuez
Member#: 86559
2010 Toyota Prius :)
I found my old 2.17 for my 2005 STi. I was wondering if anyone have the software for it? and more importantly, the pin outs?
I want to use it on another car in the future.
traction issuez is offline   Reply With Quote
Old 05-13-2025, 05:31 PM   #594
PSCD
Member#: 541058
Also a hydra user here.
Using a fully unlocked 2.7 and still actively tuning with it.
Have the software for 2.17 & 2.7 as well as some additional info, canbus protocol /pin types/ the "zener" fix (have made this change inside my own EMS).
@traction issuez, I don't have the pinout for the 2.17, but for the 2.7 it whas within the software @ help-menu.
Further more:
The only quirck I haven't been able to solve (yet), is the automatic leaning out at very very small throttle openings. Closed loop & autotune keeps leaning out (due to deceleration), but when re-visiting the cell it correct itself, but if you again are within that same low throttle opening percentage it does not and remains lean.
Obviously a threshold setting is reached.
Especially whilst pulling up from a stoplight you'll go through this area and will be lean for a sec.
Note: in open loop no such issue after tuning.
PSCD is offline   Reply With Quote
Using the Hydra with the GM AIT Sensor.. sponaugle Other Engine Management 1 11-14-2008 01:24 PM
How does the antilag work on the Hydra? Crazykev Other Engine Management 2 10-15-2005 07:11 PM
How many people are using the Hydra on the STi? Quick Other Engine Management 10 10-03-2005 01:20 AM
The Second Official Unofficial Hydra Thread bboy Other Engine Management 2 06-06-2005 11:39 AM
Hydra Users: Anyone know the Hydra injector mapping? wgknestrick Other Engine Management 12 03-07-2005 04:12 PM
