Welcome to the North American Subaru Impreza Owners Club Wednesday April 10, 2024
Old 11-14-2009, 04:29 PM   #1
markf4e
Member#: 113232
05 CGM STi
04 Outback
Default Phase II SOHC heads on EJ257
Ive got a 2000 2.5 rs with a spun bearing that I am trying to get back on the road. Right now I don't want to turbo it, I just want it to be a nice DD. I have a line on an EJ257 that I was going to put the Phase 2 SOHC heads on and run it like that for a while. So the question is will there be any hurdles I will have to watch out for doing this? The only info I could find on this setup is in this thread: CLICK I didn't see anything in there about any complications, but I just wanted to be sure.
Thanks!!
edit - I am also looking into slightly thinner head gaskets to make up for the change in compression ratio for running N/A. Any recommendations?
markf4e is offline   Reply With Quote
Old 11-14-2009, 05:06 PM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
what CAME on the 2.5RS was the THIN HG. Replacements for the 2.5RS are STi HG's. The compression with your EJ25 NA heads are gonna be like doing a EJ205 WRX head. Compression will be like. 8.6:1 or something like that.
Just plug up the breather in the back. Clean your oil pump by taking it apart. put everthing that bolts onto your block onto the EJ257. Once you start taking your motor apart, you will know what to use. Don't sit here and ponder if you have the engines in front of you. Swap over the pistons from your EJ25 NA.
Old 11-14-2009, 06:05 PM   #3
Maxwell Power
Member#: 190729
can't swap pistons over between the two. They use different length rods. The STi rods are shorter by 1.1mm and that would lower the compression ratio so far, it would be a waste of time and effort.
we run the EJ257 block with those heads in our airplanes. The compression ratio is 9:1 and everything bolts up fine.
Maxwell Power is offline   Reply With Quote
Old 11-14-2009, 06:23 PM   #4
markf4e
Member#: 113232
05 CGM STi
04 Outback
Do you plug the breather on your engines, and do you have a picture of the breather to plug? Thanks!
Old 11-14-2009, 06:36 PM   #5
Maxwell Power
Member#: 190729
simple
5/8" freeze plug you get from any advance/napa/carquest
Old 11-14-2009, 06:39 PM   #6
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
I can show you what they are talking about on the block.
CKxx is offline   Reply With Quote
Old 11-14-2009, 07:18 PM   #7
markf4e
Member#: 113232
05 CGM STi
04 Outback
Ok thanks!!
Old 11-17-2009, 08:33 PM   #8
markf4e
Member#: 113232
05 CGM STi
04 Outback
Bumping this back up with some different questions about valve springs. I figure when I have the heads out might as well do them since I would probably experience valve float at the pressure I will eventually run. THIS is my new thread that I made in NA to turbo, but it probably should have been asked here.
Options I have found for valve springs:
Cosworth springs sold by rallitek (I don't think they are the right height but rallitek lists them under 2.5l NA)
TWE springs, can't find a vendor that stocks them (Besides their website) Not much new (after 2005) info about them that I could find through searching.
Supertech springs and retainers, didn't see a vendor on here selling them but many websites seem too. I didn't find much info on these on the SOHC heads but it seems like they are used fairly often on wrx/sti DOHC heads
Ferrea doesn't list any springs that would work for the SOHC heads
It seems that the correct installed height should be 35.5mm, which Supertech and TWE definitely offer. The Cosworth website says that their valve springs installed height is 36mm @ 62 lbs. The Supertechs installed are 35.5mm @ 70 lbs so it seems to me that extra half mil could be taken out by a little more pressure @ installed height while using the Cosworth springs.
The reason I don't just jump on the supertechs is I don't know how reliable importperformanceparts.net is, and I can't really find any reviews. Has anyone ever used them?
Or should I just get measurements and search for generic valve springs?
- Mark
Old 11-18-2009, 12:41 PM   #9
Maxwell Power
Member#: 190729
- Mark
The supertech springs work fine. They use the same spring as the WRX/STi with a big spacer (about 1/2") under the spring that has a new spring seat machined into it. I can get you the part number if you need it.
The Ferrea springs that TWE sells/used to sell are direct replacements. I ran those in my car.
Old 11-18-2009, 02:36 PM   #10
markf4e
Member#: 113232
05 CGM STi
04 Outback
Great thanks! I don't need the part numbers for supertech, but do you possibly have the Ferrea spring P/N that was a direct replacement?
Old 11-18-2009, 05:37 PM   #11
Maxwell Power
Member#: 190729
I don't, but TWE might.... if you can get ahold of them.
Old 11-18-2009, 05:42 PM   #12
silentt
Member#: 119995
2004 Outback XT
Peachy
Contact Lightspeed Innovations in Red Deer, Alberta, Canada. Since TWE shut down, the old owner for TWE has been working closely with Cam from Lightspeed. Lightspeed will be your best bet to get ahold of the TWE guys and they will likely have the springs in stock.
silentt is offline   Reply With Quote
Old 11-18-2009, 08:17 PM   #13
markf4e
Member#: 113232
05 CGM STi
04 Outback
Great thank you! And thanks again maxwell power!
Old 11-18-2009, 08:28 PM   #14
Maxwell Power
Member#: 190729
anytime!
Phase II SOHC on EJ257 - Valve Springs & fueling markf4e Normally Aspirated with bolt-on Forced Induction Powertrain 1 11-17-2009 07:14 PM
Phase II SOHC heads question Marnix Normally Aspirated Powertrain 5 10-24-2006 07:22 AM
Will a Phase I DOHC run using a Phase II SOHC ECU? Patrick Olsen Normally Aspirated Powertrain 12 10-11-2004 01:27 PM
2004 WRX Heads vs. Phase II SOHC RS heads... latinskllz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-28-2004 12:28 PM
v7/v8 JDM intake manifold -> Phase II SOHC heads? BAN SUVS Subaru Conversions 1 01-10-2004 05:11 PM
