08-23-2015, 08:27 AM | #1 |
Member#: 375915
RMIC
Vehicle:2006 Impreza wrx sti Grey |
GSC S2 cams who's running them?
Who's running the GSC stage 2 Cams and how you like them? Also did anybody had any valve to piston clearance issue with them at full avcs advance?
I want to use Manley Pistons and D25 heads....
08-23-2015, 03:52 PM | #2 |
Member#: 261138
South East
Vehicle:2005 WRX STi World Rally Blue |
putting them in my build. Should be done in about a month. If no one else has any imput ill come back and comment then. Going with the GSC s2 Billet 272/272.
08-24-2015, 01:17 AM | #3 |
Member#: 187648
International
Vehicle:2007 WRX |
You should clay your pistons to see how much AVCS you can safely run with them.
I ran 30 degrees on mine with D25 heads in the past before the cams grenaded |
08-24-2015, 06:28 AM | #4 |
Member#: 375915
RMIC
08-24-2015, 06:30 AM | #5 |
Member#: 375915
RMIC
I will definitely clay the Pistons but was wondering as how many of you had run 30 degrees lol. And by the way what Pistons did you used?
08-24-2015, 09:05 AM | #6 |
Member#: 159743
Vehicle:07 STI Limited TurboMike Tuned 2.35 |
i have them in a couple builds, one specifically is using weisco pistons with GSC S2 and a 6262 with the vband back housing. I didnt need more then 15-17 degrees avcs to spool it up though.. cams run really nice.
08-24-2015, 01:32 PM | #7 |
Member#: 375915
RMIC
Yea I'm not gonna run 30 degrees with pump gas but will probably be close with 91 and meth tho...
08-24-2015, 05:46 PM | #8 |
Member#: 159743
how big of a turbo are you running that you think you will need 30 degrees of avcs to make it usable? I dont even think i was running that on my 40r.
08-24-2015, 11:24 PM | #9 |
Member#: 375915
RMIC
I don't need to run 30degrees but it's always good to make sure it can be run...
08-25-2015, 10:21 PM | #10 |
Member#: 375915
RMIC
Bump for reviews...
08-27-2015, 02:17 AM | #11 |
Member#: 64908
Vehicle:10.8 XT+9.2@155 GR+ 9.1/157mph 2015 STI |
They worked well for me http://blog.amsperformance.com/2014/...-681147-39mph/
08-27-2015, 06:53 PM | #12 |
Member#: 375915
RMIC
Nice. That thing is fast. Junior
08-30-2015, 12:56 PM | #13 |
Member#: 319017
Vehicle:15 Prius 2JZ miata Death Trap |
ImageUploadedByNASIOC1440953731.079842.jpgworked well for me on low boost. Never got to turn it up like i wanted too because it broke lol.
Sent from my iPhone using NASIOC |
09-03-2015, 08:13 AM | #14 |
Member#: 69991
NESIC
Vehicle:Leh Keen Approved '68 Volvo Amazon |
Go for some of the new billets... the should be in stock...somewhere.
09-03-2015, 02:43 PM | #15 |
Member#: 295846
Vehicle:WRX FP HTA GT3076R Sexual Chocolate |
If you need GSC cams hit me up. I'm direct with them.
09-03-2015, 05:39 PM | #16 | |
Member#: 261138
South East
09-03-2015, 05:57 PM | #17 |
Member#: 319017
09-03-2015, 06:00 PM | #18 |
Member#: 261138
South East
09-05-2015, 08:58 AM | #19 |
Member#: 375915
RMIC
03-09-2017, 08:27 AM | #20 |
Member#: 259642
Some update?
03-09-2017, 01:45 PM | #21 |
Member#: 103232
Vehicle:GTX 3071R'd 11WRX PPG,4.44,LSD,E85,6spdx3 |
07-21-2017, 11:37 AM | #22 |
Member#: 370818
Vehicle:2006 WRX STI STEEL GREY METALIC |
Are the S2 cams streetable? I bought a set of S3 cams and am worried they won't be streetable. Is anyone running S3 cams that can have some imput?
07-25-2017, 03:11 PM | #23 |
Member#: 103232
I would say the S2 is streetable. The S3 would deff loose a lot more lowend-midrange around town.
07-25-2017, 10:00 PM | #24 |
Member#: 21145
NESIC
Vehicle:2002 Enemy of Aku |
A lot of people are running S2 cams on the street.
You can run S3 cams on the street, but as said, I'm sure low end response will be poor unless you get the revs up there and keep them up there. But the lumpy idle will sound very cool |
07-26-2017, 01:18 AM | #25 |
Member#: 156750
Vehicle:2000 2.5RS |
I have JDM S2 cams and they are very streetable. Idles almost like stock at 800 rpm. I have run up to 50 deg AVCS advance (crank degrees) no problem.
