Welcome to the North American Subaru Impreza Owners Club Monday July 16, 2018
Go Back   NASIOC > NASIOC Reviews > Car Part Reviews
Old 06-17-2012, 07:39 PM   #1
Chukjagr
Member#: 314419
2004 WRX
Default Grim speed up pipe issue?
I'm reposting this from the Newbie section, I realized it was the wrong area. I just purchased a Grimmspeed uppipe. All was good until I looked inside the pipe where the flex portion is. The upper tube extended into the flex pipe about 2 inches and was pressed against the flex portion of the tube. The other side of the tube would just be sitting out in the exhaust flow, about 1/8" to 3/16" from the wall. Here are some pics, but they aren't the best: and
Is this normal or a fluke? I called and sent pics to the place I bought it from and they said it was ok, but after 12 years of working on cars professionally, I think its not. Thoughts?
Chukjagr is offline   Reply With Quote
Old 06-18-2012, 03:42 PM   #2
GrimmSpeed
Vendor Sales Rating: (212)
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Looks like the angle it was welded at is incorrect. . Generally there is going to be some gap there but in your pic it looks like it is a 1/4" or something. Hit me up on PM with your info.
Justin
__________________
| AIM: GrimmSpd | Phone: 612-379-0000
Email:
Old 06-18-2012, 06:45 PM   #3
Chukjagr
Member#: 314419
2004 WRX
PM sent!
Originally Posted by GrimmSpeed View Post
Looks like the angle it was welded at is incorrect. You are correct, that would definitely impede flow. No problem on replacing it. Hit me up on PM with your info.
Justin
Old 06-27-2012, 10:03 AM   #4
Chukjagr
Member#: 314419
2004 WRX
A big thumbs up to Justin, Matt, and the rest of the gang at Grimmspeed! Great customer service, issue is resolved! Also purchased the hardware from them that I've been scouring the net for as an added bonus!
Old 06-27-2012, 11:59 AM   #5
RavingLunatic
Member Sales Rating: (2)
Member#: 76673
2006 Impreza WRX STi
Crystal Grey Metallic
Perfect example of a responsible company! I have an issue also so I will send you a PM.
RavingLunatic is offline   Reply With Quote
Old 06-27-2012, 07:53 PM   #6
Blktrax
Member Sales Rating: (1)
Member#: 220971
2002 WRX 223K Mi.
Well now that doesn't seem to be what I was told.
Copy of Email sent and recived.
Hello Blktrax,
Both of these things should not cause any issues. When you install a gasket the area will get mostly filled and there will be no leaking. As for the tube extending into the flex, that should not cause any significant turbulence.
Thank you and please feel free to contact us if you have any further questions.
Taras Tarlov
Customer Service & Purchasing
GrimmSpeed
612-379-0000
AIM: tarasgrimmspeed
[email protected]
www.grimmspeed.com
On 1/6/2012 7:13 AM, Blktrax wrote:
I received Ceramic up-pipe (p/n : 003002) yesterday and am excited to install it. However I have 2 questions just to verify this is ok to install.
First : The lower header flange has 2 low spots one about the size of a dime and the other 9mm wide but very near the gasket sealing surface.
Second: The internal part of the flex pipe, there is approx 25-30mm of pipe extending past the weld line on the turbo side of the flex joint. It would seem this lip inside the flex would rub and cause a significant amount of turbulence due to the gap around the pipe end. However not having installed one of these before I wanted to make sure this is how the pipe is designed.
Attached pictures.
You can call or email reply anytime.
Thank you,
[/indent]
Blktrax is offline   Reply With Quote
Old 09-15-2012, 08:24 PM   #7
socalflat4
Member#: 330562
2002 WRX Wagon
Unhappy
Just received my Grimmspeed up pipe today and had encountered a similar issue as well. They make a very solid product otherwise and am waiting to hear from them when they re-open Monday. My previous order along with this one was conducted very professionally along with phone calls regarding back order up dates and shipments.
socalflat4 is offline   Reply With Quote
Old 09-16-2012, 10:52 AM   #8
Blktrax
Member#: 220971
2002 WRX 223K Mi.
Grimmspeed is awesome, I got mine swapped out back in the beginning of Aug. super easy to deal with. They earned my future business.
I talked to Matt Holmes, he took care of everything no problems.
Old 09-17-2012, 10:54 AM   #9
socalflat4
Member#: 330562
2002 WRX Wagon
Talking
Matt @ Grimmspeed got in contact with me first thing this morning, all taken care of! Amazing customer service, will definately be ordering from them again.
Up Pipe Issues?? redbull41 Newbies & FAQs 20 07-23-2011 05:46 PM
FS : lude speed up pipe and down pipe blazin91 1993 - 2001 Impreza Specific Parts 1 12-24-2010 10:18 PM
Stock Up Pipe Issues skep18 Newbies & FAQs 5 06-29-2009 03:48 PM
catless up pipe issue? ShagginWagon02 Newbies & FAQs 6 06-19-2007 01:34 PM
catless up pipe issue ShagginWagon02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-16-2007 10:38 PM
