Welcome to the North American Subaru Impreza Owners Club Sunday February 25, 2018
Old 06-16-2007, 11:14 PM   #1
ShagginWagon02
Member#: 118185
2002 Impreza WRX Wag
Default catless up pipe issue?
I just had my Invidia catless up pipe on my 02 wrx. My problem is that it's loud. Way too loud. Is it normal? Or might have the installer not tightened the pipe enough?
ShagginWagon02 is offline   Reply With Quote
Old 06-16-2007, 11:33 PM   #2
Screechers
Member#: 147934
2005 LGT
ok so what you want to look for is...if you have a boost gauge are you reaching peak boost, if no you have a leak...if no boost gauge turn on the car and check the flanges for leakes, just move your hand over the joints and if really hot air comes out then theres a leak...you can also listen for the leak
Screechers is offline   Reply With Quote
Old 06-16-2007, 11:36 PM   #3
ShagginWagon02
Member#: 118185
Ok thanks. I thought it might be a leak. Ill check when i get a chance. So its not normal for a lot of noise to come from the up pipe it's self?
Old 06-17-2007, 12:01 AM   #4
Screechers
Member#: 147934
2005 LGT
i just installed an erz ebay pipe...damn thing didnt fit right and i have a leak from the collector to the uppipe...way too loud...it will be louder though as you are removing a cat
Old 06-17-2007, 05:44 AM   #5
2wickedWRX
Member#: 151211
2007 RWD STI
WR blue
i just bought a perrin uppipe and i have been in several wrxs with it and its not bad at all was the install hard
2wickedWRX is offline   Reply With Quote
Old 06-17-2007, 05:45 AM   #6
Davenow
Member#: 23676
The only thing you should hear from a catless up pipe is a touch more "turbo" noise. (the whine) if anything at all. If you hear a loud noise, you have a leak.
Old 06-19-2007, 02:34 PM   #7
scoobynuts
Member#: 55370
05 Legacy GT Ltd
Obsidian Black
I have an Invidia uppipe with the same issues. It's loud, but it is building boost. I've felt every coonection for escaping hot air...nothing. But when I'm driving the car or even when my wife drives the car past me, I can hear the turbo whine quite clearly. Also, when given a lot of gas, the turbo sounds "fluttery", sorry, can't quite decribe the sound but it has a fluttering sound to it. I used all new gaskets except the exhaust manifild gasket to the crossover pipe. I think it might be leaking from the catless downpipe to the rest of the exhaust system (installed DP at the same time as the UP).
scoobynuts is offline   Reply With Quote
WTB: Turbo, intercooler, y-pipe and catless up pipe.... roloc31 RMIC Private Classifieds 6 03-04-2010 11:43 AM
FS: TD04 Turbo, catless Up Pipe, Stock Manifolds & Cross Pipe VKInnovations Engine/Power/Exhaust 13 02-13-2010 08:55 PM
catless up pipe issue ShagginWagon02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-16-2007 11:38 PM
FS: STi Catless up-pipe $100.00, Helix catless downpipe $175.00 jay25RS New England Impreza Club Forum -- NESIC 15 11-21-2005 05:19 PM
Catless up-pipe and down-pipe pfeif11 Private 'Wanted' Classifieds 3 08-16-2005 12:15 PM
