Welcome to the North American Subaru Impreza Owners Club Tuesday October 16, 2018
Old 02-23-2008, 01:24 PM   #1
Stray Cat
Member#: 87481
06 STi Bruise v2
RIP 02 "STi"
Exclamation Help! No interior lights, no radio, no alarm, no temp sensor; NOT fuses
Car has been on jack stands for 2 weeks while I got parts powder coated and added some more goodies.
About a week ago, I was in the car taking apart the dash so I could mount my cb radio. In the middle of it, the interior dome lights died. Damn. Got a flash light, finished, and just thought the battery was dead.
Fast forward a week... turn the car to the on position. To my suprise, the gauges start up and dash lights go on.
Try and turn on the radio... doesn't work
Click on and off the interior lights... no good
Look to see how damn cold it is in the garage... nothing
Click the remote... nada
On top of all this, there is a wine in the engine bay. Sounds near the alternator. I don't know.
Checked fused: all good.
Car runs and drives. Albeit really rough the first couple minutes around the block.
What could this possibly be? I recharged the battery. Could it be toast? Bad alternator? Bad ground? A short somewhere?
Dealer is of no help. Please help me out nasioc!
Thanks for your responses,
Zack
Stray Cat is offline   Reply With Quote
Old 02-23-2008, 02:20 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
You most likely blew a fuse. Recheck all the fuses in the dash panel and in the panel under the hood. For so many things not to work it has to be a fuse or a connector problem.
Cougar4 is offline   Reply With Quote
Old 02-23-2008, 03:09 PM   #3
turbo_h4
Member#: 112433
06 WRX.stage2
so none of the interior stuff turns on but you're able to turn on the car?
turbo_h4 is offline   Reply With Quote
Old 02-23-2008, 04:24 PM   #4
Stray Cat
Member#: 87481
06 STi Bruise v2
RIP 02 "STi"
Gauge cluster will turn on. (has a big delay in start up) Temp gauge works now. Nothing else does.
Old 02-23-2008, 07:06 PM   #5
turbo_h4
Member#: 112433
06 WRX.stage2
If you car will start then it's most likely not the battery or the alternator. Most likely just the circuitry around your gauges. Where did you tap the connections for the gauges? What other things were done to your car recently?
Please be more specific as it will help to narrow down the possibilities.
Old 07-04-2008, 12:24 AM   #6
ilitical
Member#: 183801
2015 WRX Base
ISM
Same porblem here.
No Alarm.
No Clock.
No Dome Lights.
All i did was change my headunit and now they arnt working.
I checked every fuse and they are all fine.
any ideas?
ilitical is offline   Reply With Quote
Old 07-04-2008, 02:32 AM   #7
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
this is EXACTLY the problem i was having when I blew a fuse under the dash, not the radio one, I believe the fuse all the way on the right in the middle row (kind of a stab because its late and im not getting out of bed to check).
I would be very suprised if it wasn't this fuse, and if not its got to be the wiring in that circuit.
ProdriveDreams is offline   Reply With Quote
No interior lights on 95 Legacy SVeer Legacy Forum 4 09-13-2010 09:21 PM
Need help changing interior lights to red (06 STi) DarkDvr Southern California Impreza Club Forum -- SCIC 2 02-14-2008 02:04 PM
No interior lights...need some help snowboardr424 Electrical & Lighting 4 07-22-2007 10:58 AM
I Have No Interior Lights grindooo Normally Aspirated Powertrain 0 06-26-2006 09:53 PM
Help please.The lights on my speedometer/rpm/fuel/temp guages dimmed really low paul25RS Electrical & Lighting 3 11-09-2004 11:04 PM
