Welcome to the North American Subaru Impreza Owners Club Sunday July 21, 2019
Go Back   NASIOC > NASIOC Classifieds > New Product Development
Old 10-02-2014, 03:05 PM   #1
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Default 2015 WRX Killer B Motorsport Turbo Kit
The stock turbo on the 2015 WRX is great for street responsiveness, but really not much more. Bolt-ons with a pro-tune will only take you so far. So what's one to do when looking for 50, 100, or more whp gains? Turbo upgrade!
Kit pic
KillerBMotorsport is offline   Reply With Quote
Old 10-02-2014, 03:05 PM   #2
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Now that we're underway, some pics for your viewing pleasure. This kit has been daily driven since November and has been a pure blast to drive!
Here's a shot from the underside with the bellypan remove for your viewing pleasure. After the kit is installed the belly pan goes back on. What's missing from this picture is our custom turbo inlet; it works with anyone's intake setup that works with an OEM turbo inlet
Twin Scroll Billet Wheeled GTX3067-R tucked nicely into the stock-ish location. OEM response and a boatload of more power anyone? Big thanks to Garrett for making OEM reliable turbos that pack a big punch!
Engineering + advanced casting technologies = CADgasm
PLOTS
- Stage I with a Cobb OTS map loaded
- Stage II with Killer B Motorsport J-Pipe, Killer B Motorsport I-Pipe, Killer B Motorsport Aftercooler, IAG TGV and EGR Deletes, and JRTuned Pro-Tune
- All of the above plus the Added Killer B Motorsport Twin Scroll Fury Turbo Kit, with GTX3067-R with dual Tial Wastegates and a JRTuned Pro-Tune
Notice the same spool as OEM with a MASSIVE gain in power
Old 10-06-2014, 03:51 PM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Teaser...
Old 10-06-2014, 05:50 PM   #4
italianmafia070
Member#: 196111
2018 STI
CWP
subscribed
italianmafia070 is offline   Reply With Quote
Old 10-06-2014, 09:24 PM   #5
cmejatt
Member#: 389886
in for updates
cmejatt is offline   Reply With Quote
Old 10-06-2014, 09:41 PM   #6
Scoobman20
Member#: 388015
Finally!!
Scoobman20 is offline   Reply With Quote
Old 10-07-2014, 08:46 PM   #7
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
subscribed.
Zefy is offline   Reply With Quote
Old 10-09-2014, 11:34 AM   #8
ebo03
Member#: 111008
2011 LGT SSM, 2006
Baja Turbo ABP
Subscribed.
ebo03 is offline   Reply With Quote
Old 10-28-2014, 01:24 PM   #9
italianmafia070
Member#: 196111
2018 STI
CWP
Any update?
Old 10-29-2014, 01:31 AM   #10
bunz559
Member#: 388585
2015 wrx base
ISM
And so it begins... who's going to be the 1st wrx into the 10 and 9 sec? Lol
bunz559 is offline   Reply With Quote
Old 10-30-2014, 09:13 AM   #11
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
LOTS of interest on this! We'll be posting more soon. Since we've not finished reverse engineering our 'FA engine build' program, we'll be starting small with a GTX3067 twin scroll. This should still keep the engine (hopefully) from going pop, and it will provide a great comparison to our 2012 STi which we have data on using this same turbo.
This product will support any T3 Housing, can typically see ~500whp with pump fuel on the EJ25 platform.
Old 10-30-2014, 09:48 AM   #12
ebo03
Member#: 111008
2011 LGT SSM, 2006
Baja Turbo ABP
So this will be a stock location turbo or relocated with a different exhaust manifold? I'm asking b/c I have a 2011 LGT with the similar low mount turbo configuration so I'm curious as to the possibility of fitment.
Old 11-07-2014, 11:47 AM   #13
italianmafia070
Member#: 196111
2018 STI
CWP
Any updates? Ets just released a teaser of their setup.
Old 11-07-2014, 01:48 PM   #14
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I have no idea on fitment for the LGT. Without a car here I can only speculate.
I saw that. We will have our WG ports tied in AFTER the collector for proper and equal backpressure. You will also not need to buy a header with our system as well. The OEM manifold actually isn't bad, and certainly nowhere near as bad as the previous EJ manifolds; they also need to pay attention with the OEM manifold design because it is double walled (triple if you consider the shielding) for a reason.
Old 11-08-2014, 12:59 AM   #15
ebo03
Member#: 111008
2011 LGT SSM, 2006
Baja Turbo ABP
I'm relatively close to Waynesboro (in Roanoke) and would be happy to discuss a test fit if you are interested.
Old 11-08-2014, 01:21 AM   #16
Scoobman20
Member#: 388015
How are you adapting the housing to the stock headers for the new turbo? Or are you using the stock exhaust housing?
Old 11-10-2014, 02:05 PM   #17
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
That's possible. I need to do more research on this as well. How similar is the turbo and turbo back exhaust to the 15 WRX?
With an cast stainless adapter; OEM to divided (twin scroll) T3
Old 11-10-2014, 10:03 PM   #18
ebo03
Member#: 111008
2011 LGT SSM, 2006
Baja Turbo ABP
Turbo is a low mount VF54 single scroll. From the looks of the 15 WRX exhausts that I've seen they appear to be very similar, at least in the downpipe area.
I don't mind making a trip to your shop just so you can put it on a lift and see for yourself. Anything to help the Subaru community and us Legacy guys are desperate for a turbo kit so just let me know.
Old 11-11-2014, 07:41 AM   #19
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
With the LGT being single scroll that would be an issue. Although, assuming the WRX and LGT have the same head and spacing/bolt pattern, a WRX manifold could be used to run twin scroll.
Old 11-11-2014, 09:30 AM   #20
ebo03
Member#: 111008
2011 LGT SSM, 2006
Baja Turbo ABP
There is one manifold on the market for 2010+ LGT at the moment. From the looks of the pics, ETS uses a twin scroll flange on their LGT manifold. This is pure speculation but maybe it also fits 2015 WRX and they didn't see any point in manufacturing it with two different flanges. Also the manifold wasn't produced until this summer after the 2015 WRX was released.
http://www.extremeturbosystems.com/E...-Manifold.html
My offer is on the table to come to your shop if there is any interest.
Old 11-11-2014, 10:07 AM   #21
cnaka
Member#: 401780
2015 WRX
CBS
I hope Subaru made this gearbox stronger than the old 5 speed. It's about to get a lot more power.
cnaka is offline   Reply With Quote
Old 11-11-2014, 11:44 AM   #22
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Some those pics, the LGT turbo change is completely different. That would mean we'd have to design and cast another turbo adapter to make this work. With how few LGTs there are out there looking to do a turbo upgrade I don't see there being enough demand for a product
I'm thinking the same thing!!!
Old 11-11-2014, 09:49 PM   #23
ebo03
Member#: 111008
2011 LGT SSM, 2006
Baja Turbo ABP
I completely understand. It just doesn't make much sense from a business perspective. LGTs are definitely rare so the market for most parts just isn't there.
So your kit is going to use the OEM manifold with an adapter instead of a Killer B designed manifold?
Old 11-12-2014, 12:17 PM   #24
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Correct. We are attacking FA projects by bang-for-the-buck, or by which OEM parts are crappiest The OEM manifold isn't bad. It sure it's nearly as TERRIBLE as the OEM EJ manifold was. You will not see nearly the same gains as what used to be seen on the EJ engines by bolting on a header. Anyone to make such claims, should be approached with skepticism until the independent (non-sponsored) reviews start rolling in.
The other concern with the FA manifold is that is has a VERY unique design using double walled tubing (triple layers if you include the heat shielding). This is a very smart design move by the OEM for a few reasons. Designing an aftermarket product to perform better AND provide long term street and track reliability over years, is not as simple as welding stainless tubes like a traditional header. I'm sure there will be many made this way, but when the time is right we will attack that product too. Ideally, bringing a product to market that is obsessively engineered with a goal of being best performing product available.
Old 11-12-2014, 12:21 PM   #25
Scoobman20
Member#: 388015
You have my attention.
Do you plan on selling the turbo adapters by themselves?
