Welcome to the North American Subaru Impreza Owners Club Thursday March 21, 2019
Go Back   NASIOC > NASIOC Classifieds > New Product Development
View Poll Results: Killer B Motorsport 2015 WRX header?
Yes please, must have! 32 68.09%
Nah, I'd rather spen my had earned cash on other stuff 15 31.91%
Voters: 47. You may not vote on this poll
Old 06-28-2016, 05:35 PM   #1
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Default 2015 WRX Header
As much as we don't want to make this part, we keep getting asked over and over and over again. If you guys r-e-a-l-l-y want it... We can make it happen, with or without EWGs.
Cast your vote!
KillerBMotorsport is offline   Reply With Quote
Old 06-29-2016, 08:20 AM   #2
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks for the votes. Getting good feedback through e-mail, PM and FB as well. Also feel free to let us know if you'd prefer them as shown here, or with Dual EWGs?
Thanks!
Chris
Old 06-29-2016, 08:31 AM   #3
tank the ek
Member#: 295911
2015 WRX
LR
Thanks!
Chris
I think alot of the questioning about the stock turbo manifold is due to the STX71 from steamspeed, and the conclusion they posted, stating the turbo manifold was limiting the turbo from reaching optimal speed. I think that if an aftermarket turbo manifold was the true solution, those who were aimed in a larger turbo direction, would definitely appreciate a product from KillerB, who has put out consistently quality products.
If the EWG option was requested, would there be an additional option for different turbo flanges, or only the factory turbo flange?
tank the ek is offline   Reply With Quote
Old 06-29-2016, 09:10 AM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ That conclusion is an interesting one. Since we ran into zero issues with a restriction running a standard T3, it would seem to me that the more logical issue Steam is having is with sticking with the OEM style turbine housing. The turbine plots I've seen for that setup shows this as well, I don't see why it's a surprise to anyone, or why they would say it was the manifold.
The is the same issue with the EJ engines all over again. No 'bolt-in' turbo that uses OEM design features, is ever going to match the performance of a ground-up performance oriented design.
As far as making different flange options available, you're into our turbo kit. There is no T3, T4 or V-band turbine housing that maintains OEM location (or J-Pipe Bolt pattern) for turbine outlet, compressor inlet, and compressor outlet... this is all included in our Twin Scroll Fury Turbo kit
The turbo kit doesn't include a header, but if you did have an EWG header, we could make the kit's OEM to T3 TS adapter without the EWG ports.
Old 06-29-2016, 12:26 PM   #5
under_score
Member#: 221624
PRL Motorsports is finalizing their design right now (found via a Facebook post), so there is some competition on the horizon or an option for those who are looking for this, in the event that KillerBMotorsport opts out.
under_score is offline   Reply With Quote
Old 06-29-2016, 03:33 PM   #6
Boggie1688
Member#: 165955
2015 WRX Base
You already have built the manifold.
Why not just find someone locally that has the turbo and do some real testing? Or ... get steamspeed to send one to you. If they are SO positive its the manifold....they should have any reason not to send you a turbo to test.
Boggie1688 is online now   Reply With Quote
Old 06-29-2016, 04:17 PM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Finalizing the design before a singe test has been done?
Actually we have a few header sets here. Our 2015 WRX has been running one since November for reliability testing. We're definitely NOT selling a product that hasn't been rigorously tested for performance AND reliability. I have no interest in the Steam setups. I've seen the turbine flow data and I just don't see the point in them as a decent upgrade. It's not going to come anywhere near matching the power of an performance designed turbocharger platform like a GTX or EFR. It comes down to the old adage; cheap, reliable, fast... you can only have two.
Old 06-29-2016, 04:35 PM   #8
SoCal_Scooby
Member#: 210777
Don't worry bout' it Brah
Is it still going to be 321?
RD Engineering says their header makes 10whp / 12-15wtq on 91 CA and has a similar design.
SoCal_Scooby is offline   Reply With Quote
Old 06-29-2016, 04:49 PM   #9
Boggie1688
Member#: 165955
2015 WRX Base
I made an assumption based on the timing of PRL releasing their header for the Steamspeed turbo.
Old 06-29-2016, 05:10 PM   #10
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Yes.
Sounds about right. We were on a low reading dyno; car barely made 250whp at stage II+, Of course every dyno is different, loading ,etc...
Old 07-12-2016, 07:55 AM   #11
baseballdbk1
Member#: 242700
2015 Impreza Wrx
We test every part we make...
Design, make mock up manifold, test fit, build complete manifold and test for gains on the dyno
Process has worked well with no reason to change now.
Dave
PRL Motorsports
baseballdbk1 is offline   Reply With Quote
Old 07-12-2016, 10:25 AM   #12
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ good job
Old 07-19-2016, 06:45 PM   #13
fl1p
Member#: 407265
Hey Chris...
I know I read it somewhere, but can you post up why you're so hesitant to produce headers? Maybe update your OP with a reason to your aversion?
--flip
fl1p is offline   Reply With Quote
Old 07-20-2016, 12:21 AM   #14
spdracerut
Member#: 269226
Originally Posted by fl1p View Post
Hey Chris...
--flip
IIRC, in testing his header with the turbo kit, the header only gained about 10whp over the stock header. Considering the Holy Header for the EJ cost around $1300-$1600, do you want to pay that much for 10whp?
spdracerut is offline   Reply With Quote
Old 07-21-2016, 06:02 PM   #15
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
So here we are.
Old 07-21-2016, 06:56 PM   #16
tank the ek
Member#: 295911
2015 WRX
LR
:insert Cleveland "that's nasty" gif":
Old 07-22-2016, 04:55 AM   #17
SoCal_Scooby
Member#: 210777
I think the EWG variant makes more sense. Not really about the HP gain from a header, but the better boost control for those who suffer from constant overboost.
Old 07-22-2016, 04:57 AM   #18
SoCal_Scooby
Member#: 210777
Is it able to swap over to the KB turbo kit those choose to buy the kit later down the line?
Old 07-22-2016, 05:53 AM   #19
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
This is a great point. As power levels and higher power density fuels (E85) are used, going the EWG route removes the limitations of the factory turbo's IWG.
Yes. Since the Twin Scroll Fury Turbo Kit uses an flange adapter, you can use the manifold for either.
Old 08-11-2016, 04:50 PM   #20
ebo03
Member#: 111008
2011 LGT SSM, 2006
Baja Turbo ABP
Subscribed.
ebo03 is offline   Reply With Quote
Old 08-13-2016, 10:51 AM   #21
pjacobs22
Member#: 417038
2015 Wrx
ISM
Saw Brentuning's post about installing this on a customers car... I'd love to throw my wallet at this right now.
pjacobs22 is offline   Reply With Quote
Old 08-17-2016, 08:28 AM   #22
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Thanks for the positive feedback guys. Should be some info posted soon.
Old 10-03-2016, 08:05 AM   #23
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Still more details to post on the website. We've also got a OEM WG door keeper closer kit available. It's pretty simple and will be available as an option with the EWG version.
Old 10-05-2016, 01:19 PM   #24
ozma
Member#: 191239
2015 WRX sedan
dgm
Just sitting here patiently waiting for the call to get my headers. :P
ozma is offline   Reply With Quote
Old 01-17-2017, 09:04 AM   #25
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Ring ring...
We currently have a small backorder, but are shipping them out daily!
