Welcome to the North American Subaru Impreza Owners Club Wednesday October 24, 2018
Old 11-20-2008, 09:42 PM   #1
07Limited0306
Member#: 179247
2007 WRX Limited
Default So i WAS going to get a tune today...
I went to xxtuning to finally get my car tuned
its an 07 wrx with
cobb downpipe
borla hush
sti tmic
blouch 18g turbo
hallman manual boost controller
megan headers
cobb AP
so we threw it on the dyno and it made 237 whp with the ots map???
the boost curve was all messed up
It went to 18 pounds at like 4000 rpm then just dropped to 15 out of no where.
They said it was because of the boost controller, so we took it off.
the map w/o a controller is suppossed to make 18 lbs, it only made 11
they said this was either my boost control solenoid, my actuator, or vacum lines.
They're checking it out today and tomorrow, i left the car with them.
any ideas or suggestions?
it seemed to be running fine?
07Limited0306 is offline   Reply With Quote
Old 11-20-2008, 10:01 PM   #2
gabedude
Member#: 10108
2016 Bicycle
Did you remove the factory t when you installed your MBC? If you don't put the pill back in, it won't boost right (low). That 18 to 15 taper is normal for running an MBC on a 18G. I bet the lines, but you should really just get a 3 port blocking solenoid for the stock ECU to control and run it in interrupt mode to get your MBC like response. You don't need the pill then.
gabedude is offline   Reply With Quote
Old 11-20-2008, 10:03 PM   #3
07Limited0306
Member#: 179247
2007 WRX Limited
hmm, i don't really understand everything you said right there, but i am trying. what exactly is a 3 port blocking system? and now that i think about it, i dont have the factory t in it anymore... the hallman one was a lot bigger too...
Old 11-20-2008, 10:08 PM   #4
gabedude
Member#: 10108
2016 Bicycle
Yeah that is the problem, you need the stock lines. There are 2 types of 3 port solenoids (stock is a 2 port) that are popular on subarus. Many companies sell kits. Just get a 3 port.
Old 11-20-2008, 10:18 PM   #5
07Limited0306
Member#: 179247
2007 WRX Limited
alright i just looked them up, prodrive makes one for $100, that sound reasonable?
Old 11-20-2008, 10:25 PM   #6
gabedude
Member#: 10108
2016 Bicycle
See if xxtuning has one in stock that they prefer to use.
Old 11-20-2008, 10:29 PM   #7
jagstyle
R.I.P.
Member#: 155186
2007 STI
huh? I don't run the factory lines or pill with my Hallman MBC and it works just fine
jagstyle is offline   Reply With Quote
Old 11-20-2008, 11:02 PM   #8
gabedude
Member#: 10108
2016 Bicycle
Yeah he took off his MBC though and hooked the stock BCS to the non factory lines. He described a normal taper for an MBC.
Old 11-21-2008, 09:14 AM   #9
ThreeEleven
Member#: 157894
2007 WRB WRX
EJ257
GM BCS is cheaper and quality
ThreeEleven is offline   Reply With Quote
Old 11-21-2008, 10:06 AM   #10
Ranatsu
Member#: 87314
2017 BRZ
Yellow
Gabe is referring to the stock 2 port system as a "bleed" system
the aftermarket 3 port systems can do bleed or whats called interrupt(blocking)
But honestly if you have the MBC hooked up properly and you have completely removed the stock solenoid from the loop, you shouldn't be really having any problems.. the turbo is going to taper it just can't spin fast enough.
Now if you have eratic type boost response where it goes up and down, then you have a problem.
Ranatsu is offline   Reply With Quote
Old 11-30-2008, 10:30 AM   #11
EFI Logics
Vendor
Member#: 193180
All I want to say, is be careful.. Since I left, those guys have almost no clue how to use the dyno, let alone diagnose a Subaru.. Anybody who was worth anything there, has left since the new ownership. If they set the dyno up improperly, then you will look like you have all sorts of issues. If the ramp time on the Dynapak is set too long, the boost will spike REALLY hard, and look like you have all sorts of problems. Also, I had no idea they had anybody to tune there yet? I didn't train anybody.
Please be careful, I know, because I had a day to train them how to use the dyno before I left. I had a friend call, and they are telling people that "Chris is on vacation" and are still booking appointments.. This is not cool at all because they are giving people the impression that I am still tuning out of there, which I haven't been for over a month now.
- Chris
Chris - Owner / Lead Calibrator
XX Tuning's former Tuner / Shop manager
Jack - Shop Foreman / Head of Race Car development / Motorsports division
XX Tuning's former Shop Foreman
EFI Logics.com / MySpace / "New" Interactive Dyno Database
Subaru / Porsche / Mitsubishi / Ford / GM
Mustang AWD500SE - 60mph wind Dyno cell
8 Sympaug Park Road : Bethel, CT 06801
Phone: 203.748.1115
EFI Cars:
2004 STi ST-2 #777 - 3 Time Class Winner / Watkins Glenn ST-2 track record holder.
2004 STi ST-2 #27 - 8 Time Class Winner / 2008 Points leader.
2006 Evo9 ST-2 #42 - 4 Time Class Winner
2005 Evo8 ST-2 #101 - 2 Time Class winner
EFI Logics is offline   Reply With Quote
Old 11-30-2008, 04:44 PM   #12
xxscaxx
Member#: 86459
2013 BRZ
^ wow, not cool at all. i was wondering what/who was taking over your place at xx. i actually forgot for a second that you werent at XX anymore and was going to tell the OP that im suprised chris didnt suggest a prodrive unit, and ditch the mbc like you did when i got tuned
xxscaxx is offline   Reply With Quote
Old 11-30-2008, 05:57 PM   #13
northmiler89
Member#: 157163
2008 STI
Silvarrrrrrrr!
wow...
northmiler89 is offline   Reply With Quote
Old 12-02-2008, 10:27 PM   #14
EFI Logics
Vendor
Member#: 193180
Any updates?
k so i WAS going to get my valve cover seals replaced... kaisersouse Normally Aspirated Powertrain 6 08-30-2005 07:24 PM
WAS going to get my 01 2.5RS today, but... Sko North West Impreza Club Forum -- NWIC 7 07-18-2005 08:21 AM
So i was going to get pizza and.... RSimport Mid Atlantic Impreza Club -- MAIC 24 01-24-2005 05:00 PM
[PICS] The sheet metal place I was going to get body armor from burned down today! Sean New England Impreza Club Forum -- NESIC 15 07-08-2004 12:21 PM
So...which one of you was going to get this for me? jackwei General Forum Archive 4 03-14-2001 02:34 PM
