Welcome to the North American Subaru Impreza Owners Club Saturday February 24, 2018
Vancouver Impreza Club
Old 06-16-2014, 08:52 PM   #1
JapaneseGoKart
Member#: 372599
98 impreza sti
Default Random car trouble. Need igntion pack?
What up everybody, my gc shut off randomly on me today while in traffic and wouldnt turn over, i ahs to get it towed. i beleive it has to do with my igntion coilpack, my fuel pump and electrical is all good and their is oil in the engine, and also i have fairly new plugs so i was wondering if anyone on here knows who may have a f-569 12 volt coilpack for sale. Thought i would check on here for possible local hook ups before i order from japan. If you dont think its the coilpack what are some other possibilities?
JapaneseGoKart is offline   Reply With Quote
Old 06-16-2014, 10:17 PM   #2
FunkMasta
Member#: 66985
2001 SRP 2.5RS sold
2017 WRB WRX
have you checked for spark?
and are you sure you have fuel?
and when you say wouldn't turn over, do you mean wouldn't start or wouldn't crank? no amount of new coil pack will help you if the engine won't turn over....
FunkMasta is offline   Reply With Quote
Old 06-16-2014, 11:28 PM   #3
Bruere
Member#: 353523
1998 STi RA V-Ltd
Super Mica Blue
Sounds like the MAF issue with dry solder etc but could possibly be the crank or camshaft position sensors.
Bruere is offline   Reply With Quote
Old 06-17-2014, 02:14 AM   #4
colin22
Member#: 353372
1997 wrx
colin22 is offline   Reply With Quote
Old 06-17-2014, 02:56 AM   #5
JapaneseGoKart
Member#: 372599
98 impreza sti
Originally Posted by FunkMasta View Post
have you checked for spark? and are you sure you have fuel? and when you say wouldn't turn over, do you mean wouldn't start or wouldn't crank? no amount of new coil pack will help you if the engine won't turn over....
yea turnover meaning wont start bit it cranks once and makes a revolution sound then nothing.. Then after that one try i turn the key and it clunks and nothing.
Old 06-17-2014, 02:58 AM   #6
JapaneseGoKart
Member#: 372599
98 impreza sti
Originally Posted by colin22 View Post
sic dude your asking $30 for it? If you have it ill take it off your hands
Old 06-17-2014, 03:25 AM   #7
Bruere
Member#: 353523
1998 STi RA V-Ltd
Super Mica Blue
So you can't even crank the motor for 2-3 seconds with the starter? That's not a coilpack issue, it's either your starter or an issue with voltage going to it.
Old 06-17-2014, 10:50 AM   #8
zephyrantes
Member#: 301234
Try also checking ur battery and battery terminals.
zephyrantes is offline   Reply With Quote
Old 06-17-2014, 01:52 PM   #9
JapaneseGoKart
Member#: 372599
98 impreza sti
i dont think it would be a starter issue due to the car being already running when it turned off randomly
Yea i tried that but my electrical is all good, all power features run good and also brand new battery
Old 06-17-2014, 02:01 PM   #10
novacivic
Member#: 117980
2005 sti
wr blue
Sounds like your alternator isn't charging which caused your brand new battery to drain down enough that it couldn't keep the car running and now it won't crank because it's too low. Try jump starting the car then test the alternator
novacivic is offline   Reply With Quote
Old 06-17-2014, 02:25 PM   #11
JapaneseGoKart
Member#: 372599
98 impreza sti
oh **** dude i forgot that piece of information, i tried jump starting it when i brought it home and nothing happened, i was pretty bumbed it didnt work. I was hoping it was only a battery issue.
Old 06-17-2014, 02:57 PM   #12
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
nothing happened as in it would crank but not start or it would do absolutely nothing? But all your power options work...?
Zefy is offline   Reply With Quote
Old 06-17-2014, 03:26 PM   #13
JapaneseGoKart
Member#: 372599
98 impreza sti
yea bro it's wierd the first try the fuel pump primes, i crank it, makes a revolution sound like its struggling to start the engine but nothing happens and then it stops trying. Then when i try after a few more times it makes a clunk and thats it, doesnt make any attempt to try and crank. Some people say crank sensor, cam sensor, ignition coils. It was just really random how it died on me at idle after driving it. No CEL just ... And left me saying wtf lolol
Old 06-17-2014, 05:30 PM   #14
zephyrantes
Member#: 301234
Try cleaning your battery terminals really good.. both on the battery and on the wired end.
I say this because I had the exact same thing happen on my camaro. Drove it to my friend's house and it died on me right when I parked.
Everything worked. Just no crank at all. Would not even jump start.
Obviously ruled out the starter. Had fuel pressure at the rails. Didnt bother to check for spark (motor wouldnt even turn).
Looked at my terminals in the battery and that was fine, but the female end on the wired side has some mild corrosion. Cleaned it up, and all was good.
Obviously that slight bit of corrosion is enough to create a high resistance.
Cam and crank sensors wont just kill the cranking process after one revolution. Either it will or won't start... or it will be a delayed start. As for coil packs.. i would also imagibe that it would continue to crank more than 1 revolution as the starter continues to spin
Old 06-17-2014, 06:35 PM   #15
JapaneseGoKart
Member#: 372599
98 impreza sti
Try cleaning your battery terminals really good.. both on the battery and on the wired end. I say this because I had the exact same thing happen on my camaro. Drove it to my friend's house and it died on me right when I parked. Everything worked. Just no crank at all. Would not even jump start. Obviously ruled out the starter. Had fuel pressure at the rails. Didnt bother to check for spark (motor wouldnt even turn). Looked at my terminals in the battery and that was fine, but the female end on the wired side has some mild corrosion. Cleaned it up, and all was good. Obviously that slight bit of corrosion is enough to create a high resistance. Cam and crank sensors wont just kill the cranking process after one revolution. Either it will or won't start... or it will be a delayed start. As for coil packs.. i would also imagibe that it would continue to crank more than 1 revolution as the starter continues to spin
thanks bro ill give it a look see and clean things up, i just want my baby fixed, this is the first hiccup after owning it for a year with proper maintenance and just does this to me. But yea ill check the terminals, thanks homie
Old 06-17-2014, 08:29 PM   #16
JapaneseGoKart
Member#: 372599
98 impreza sti
Replaced the ignition coil pack just now. No go, still being a little bastard . Battery terminals are clean.
Old 06-17-2014, 09:28 PM   #17
Atlasunit22
Member#: 391438
1999 Forester SF6
Acadia green
check for air leaks after the MAF. if pirate air is getting though pass the mac, that'll cause the engine to shut down.
Atlasunit22 is offline   Reply With Quote
Old 06-17-2014, 11:28 PM   #18
zephyrantes
Member#: 301234
Pull the plugs and see if any fuel comes out... a hydrolocked/hydrolocking engine does something similar while cranking. It will crank and "clunk" like it hit a wall and won't crank anymore (another personal experience with my camaro).
In my case, the fuel pressure regulator diaphragm tore and was dumping fuel into one cylinder all the time.
Liquid doesn't compress, so when you crank the engine, that liquid gas becomes that "wall".
My motor also stalled from obviously being flooded in that one cylinder.
I hope this is not the case foe you. I am just trying to draw from my own experience without being there in person.
If you can, check fuel pressure and remove your spark plugs to check.
Old 06-18-2014, 12:10 AM   #19
dumpsterdeesh
Member#: 369166
2004 FXT 5spd
Cayenne Red
I would rule your alternator first if your car try's to turn over and won't.. Assuming you actually have gas in your tank. If you have a multimeter or voltmeter you should test your batteries voltage. Remember it should be higher than 12 volts. A healthy battery should be at least 12.6 volts with the engine off. 14.4V with the engine running. Buy a multimeter from crappy tire and return it after if you're broke.
If your alternator really **** the bed it would explain dying in the middle of traffic. Also check for loose connections to your alternator.
I know you said you tried to jump it with no luck but that is where I would start. But to me it sounds like something electrical.
Is it a 5 speed? Have you tried to pop start it down a hill?
dumpsterdeesh is offline   Reply With Quote
Old 06-18-2014, 01:28 AM   #20
v Hall
Member#: 355033
2002 Outback Sport
I had coil pack issues a couple of months ago and it felt like I was running on 2 cylinders, but the car was still running. I checked for spark & that was the problem. Just my 2 cents.
v Hall is offline   Reply With Quote
Old 06-18-2014, 02:48 AM   #21
JapaneseGoKart
Member#: 372599
98 impreza sti
Pull the plugs and see if any fuel comes out... a hydrolocked/hydrolocking engine does something similar while cranking. It will crank and "clunk" like it hit a wall and won't crank anymore (another personal experience with my camaro). In my case, the fuel pressure regulator diaphragm tore and was dumping fuel into one cylinder all the time. Liquid doesn't compress, so when you crank the engine, that liquid gas becomes that "wall". My motor also stalled from obviously being flooded in that one cylinder. I hope this is not the case foe you. I am just trying to draw from my own experience without being there in person. If you can, check fuel pressure and remove your spark plugs to check.
yea hopefully hydrolock is not the issue. I dont know too much about what it is but it sounds bad and expensive to fix.
Old 06-18-2014, 02:51 AM   #22
JapaneseGoKart
Member#: 372599
98 impreza sti
Originally Posted by dumpsterdeesh View Post
I would rule your alternator first if your car try's to turn over and won't.. Assuming you actually have gas in your tank. If you have a multimeter or voltmeter you should test your batteries voltage. Remember it should be higher than 12 volts. A healthy battery should be at least 12.6 volts with the engine off. 14.4V with the engine running. Buy a multimeter from crappy tire and return it after if you're broke. If your alternator really **** the bed it would explain dying in the middle of traffic. Also check for loose connections to your alternator. I know you said you tried to jump it with no luck but that is where I would start. But to me it sounds like something electrical. Is it a 5 speed? Have you tried to pop start it down a hill?
yea its 5 speed and i thought about clutch popping rolling start but i dont wanna damage anything. Im taking it into a shop tomorrow to have it looked at since im so lost and somewhat frustrated with it
Old 06-18-2014, 04:33 AM   #23
Bruere
Member#: 353523
1998 STi RA V-Ltd
Super Mica Blue
It's a starter issue if the motor isn't even turning over, 12v applied to the starter with the clutch in will always crank it if the starter isn't hooped.
Old 06-18-2014, 10:00 AM   #24
m71owner
Member#: 332321
1998 2.5rs
wrb
Just a shot in the dark but has the timing belt ever been changed?
m71owner is offline   Reply With Quote
Old 06-18-2014, 04:29 PM   #25
Atlasunit22
Member#: 391438
1999 Forester SF6
Acadia green
There's a good one.
