Welcome to the North American Subaru Impreza Owners Club Friday April 16, 2021
Old 02-27-2021, 04:44 PM   #1
needstobefaster
Member#: 320899
Default Please Help, Highway Shimmy Wont Go Away
Hey guys,
So Iíve had a shimmy whenever Iím between 65-80 (sometimes faster) and I canít figure it out.
Iíve had the tires balanced and it was still there, thought maybe my rotors were warped so I changed them, torqued wheels all around. I still get a shimmy and sometimes when I let off the gas it feels hard and lightens up a bit.
Could it be my driveshaft ? Iíve seen a few comments of people having the same problem but I donít hear any clunking or anything like that. Is there a way to check if itís bad without actually taking it out?
Appreciate any help!!
needstobefaster is offline   Reply With Quote
Old 02-27-2021, 05:44 PM   #2
Jay11STI
Member#: 492422
2011 STI
Have you had an alignment done yet? Might be something to consider. Usually rotate balance and alignment go hand and hand. If you verified you dont have any bent wheels, id probably do an alignment next.
Jay11STI is online now   Reply With Quote
Old 02-27-2021, 06:04 PM   #3
snow_bound26
Member#: 395793
2005 92x Aero
Beige
What, if any, suspension mods do you have? What tires, and size?
snow_bound26 is offline   Reply With Quote
Old 02-27-2021, 06:49 PM   #4
supermarkus
Member#: 6971
2008 WRX STi
SSM
My shimmy didnít go away until I had the wheels road force balanced.
supermarkus is offline   Reply With Quote
Old 02-28-2021, 09:00 AM   #5
needstobefaster
Member#: 320899
I just have BC coil overs, about 5 years old, and I have the Dunlopís of a 2015 wrx, they are 245,40/18 I believe.
Old 02-28-2021, 09:02 AM   #6
needstobefaster
Member#: 320899
Ah, thatís such a pain. I do have 17inch Rotas I just picked up used so maybe putting brand new tires on them and throwing them on will change the car. However, if new wheels AND brand new tires donít fix it, could it possibly be driveshaft or axle related even if I do not hear any clicking or clunking?
Old 02-28-2021, 09:04 AM   #7
needstobefaster
Member#: 320899
Now that I think about it, that could be my probably. I got an alignment done years ago and havenít had one since. I was hoping to grab the white line rollcenter bump steer kit just since my car has 100k and Iím in jersey where salt kills bushings.
Old 02-28-2021, 02:31 PM   #8
a5m
Member#: 519868
2010 Impreza WRX
Wheel bearings? My buddy's G35 did this badly and he almost wiped out driving in the rain.
a5m is offline   Reply With Quote
Old 02-28-2021, 02:47 PM   #9
snow_bound26
Member#: 395793
2005 92x Aero
Beige
I would get an alignment to rule it out, but I'm guessing the tires are causing some tram lining. Basically, you're feeling the minor deviations in the road surface. This happens more as tires get wider. A surfer sidewall or stiffer suspension parts can increase this feeling.
With the age of your BCs, they probably aren't sliding as smooth as they should which could enhance the feeling as well.
Old 02-28-2021, 03:44 PM   #10
needstobefaster
Member#: 320899
Would the coil overs cause a squeak at all if they donít slide smooth? Iím going to get an alignment and see if that fixes it, if not, Iíll try the new rims and tires I have but after that I guess I will check the suspension and maybe wheel bearing. Really hoping itís just the tires I have since they are a few years old and stretched on 18x9.5
Old 02-28-2021, 06:38 PM   #11
akritzer
Member#: 511749
2013 WRX Hatch
Jack it up if you can and wiggle each wheel. Check to see if there's any play up/down (ball joint) or left/right (tie rod). Play can also be from a bad wheel bearing. Do you hear any unusual noises while driving at highway speed, like a whirring or roaring?
Pull your wheels off and have a good gander at your tires. Is the tread wearing evenly?
While your wheels are off take a good look at your control arm bushings.
Mileage is important, 100k is a good time to start looking at all the things I mentioned.
Check out this post about your car's midlife crisis and you.
akritzer is offline   Reply With Quote
Old 02-28-2021, 07:41 PM   #12
snow_bound26
Member#: 395793
2005 92x Aero
Beige
I've definitely found that stretched tires tram line more. I stretched one set and hated the way they felt driving. Coilovers can make all kinds of different noises when they are going bad; squeaking, thunking, etc. Worn tires will also tram line more than new. I'd guess the combination is the main contributor to what you're feeling. Especially during the winter months when the road becomes more uneven in colder weather.
Old 02-28-2021, 09:12 PM   #13
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
really?? you're using tires off a 2015?? you should replace your tires they are beyond their life span. crappy tires will cause loss of stability...
murrdogg24 is offline   Reply With Quote
