Welcome to the North American Subaru Impreza Owners Club Monday June 17, 2019
Old 12-28-2018, 01:12 AM   #8826
Foo_Blyat
Member#: 93750
Originally Posted by yamahaSHO View Post
It's not my car, just a customer car that I tuned. I have never really tested really cold starts on my car as I don't drive it in the extreme cold. My car also does not sound like a Subaru, so the video doesn't sound "good" to me other than it firing right up.
Is your pump hardwired? If you're getting a pressure drop like that, I'd probably start with the factory FPR. I've seen quite a few fail over the years... Two in the last couple months with customer cars, and I do this as a side gig. They also made things like hot starts seem more like a -20 cold start with constant cranking.
Not too bad, especially for a piggyback.
you still doing cobb ap? want to set something up to tune my car once i get everything in and buttoned up?
Foo_Blyat is offline   Reply With Quote
Old 12-28-2018, 02:37 AM   #8827
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Originally Posted by birdflu View Post
No my pump isn't hardwired. Hot starts are instant.
Only noticed this since flashing carberry rom as I fitted the filter and under bonnet gauge at the same time.
Did you replace the stock FPR's that failed with standard or go aftermarket?
On the last 2 cars, one was a factory replacement the other was already an aftermarket, but then replaced with a better aftermarket part. He ended up with an Aeromotive... I can't remember what the previous was. I tried way too many maps before pointing at hardware, knowing it wasn't a tune issue after the 2nd or 3ed map.
I can do AP's and can definitely work with you on a good map. If you're wanting to move forward with one, just send me a PM. Just understand that although I can get close on the cold start, it may take a few tries to get your car as good as the video I posted... But I'm pretty good at getting it down pretty quickly as long as I have good feedback.
Is this for the Forester you picked up?
yamahaSHO is offline   Reply With Quote
Old 12-28-2018, 06:05 AM   #8828
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
I for carberry I just increase cranking fuel 50% over the gas tables. Only time I have issues is when car sits and battery drops to 11ish volts and cranks too slow
no694terry is offline   Reply With Quote
Old 12-28-2018, 06:49 AM   #8829
birdflu
Member#: 272186
03 wrx csevo6
vf34 e85 salted peanut
fuelab 818 6 micron
I've deleted the windscreen washer bottle as I never use it and replaced it with a 250ml 304 SS drink bottle that's BPA free....lol
birdflu is offline   Reply With Quote
Old 12-28-2018, 10:17 AM   #8830
TDagen
Member#: 163648
V9 6mt R180 Brembos
I like the washer fluid tank mod. Bought yourself some space.
Old 12-28-2018, 12:17 PM   #8831
birdflu
Member#: 272186
03 wrx csevo6
Thanks.
It was also one of a few weight saving mods. I keep around 50ml of water in their just in case the boys in blue pull me over and check my windscreen washers....lol
Not that it would matter if they checked under the bonnet because the nanny state I live in only allows one intake tract mod.
Old 01-02-2019, 12:23 PM   #8832
birdflu
Member#: 272186
03 wrx csevo6
OK. I feel like an idiot for posting about my fuel pressure drop.
Liquid filled turbosmart under bonnet gauge gets hot, pressure inside gauge increases and the gauge reading decreases. This is my 6 – 7 psi pressure drop. I only ever used this gauge twice tee’d on feed to check base pressure before, but never left it on there long enough to notice this.
Didn’t think to vent the gauge to reset it.
My ignition on, fuel pump prime went from 29 psi to 43 psi today after venting.
What fuel pressure senders are e85 compatible?......looking for an in cabin gauge that won’t crap out a sender.
Happy New Year!
Old 01-02-2019, 12:54 PM   #8833
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Thanks.
I saw a video a while back of them impounding trucks down there for illegal lift kits and stuff. Im suprised how strict they are. I think SEMA might have some lobbyists and maybe a lot to do with how we can mod in the States. I built my car in my garage, got it title and registered and can literally put any engine i want to in it.
Old 01-02-2019, 03:52 PM   #8834
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I don't understand how the masses likes to be regulated on every aspect of their life.
Old 01-02-2019, 04:03 PM   #8835
anarekist
Member#: 468117
2017 WRX
DMG
fuelab 818 6 micron
https://i.imgur.com/XvKRAhM.jpg
https://i.imgur.com/XenvFNU.jpg
https://i.imgur.com/7HOfiRD.jpg
awesome , thanks man.
anarekist is offline   Reply With Quote
Old 01-03-2019, 12:19 PM   #8836
birdflu
Member#: 272186
03 wrx csevo6
Your Exotruck is so far off the chain that there is no chain....lol
Last time I checked in my state you couldn't even do an engine conversion anymore.
I have an old Holden Gemini (4cyl isuzu) sitting in a paddock and a 13b sitting in the garage that i wanted to fit into it, but couldn't get it registered.
Old 01-03-2019, 12:30 PM   #8837
Waddlz
Member#: 395275
2012 STi
heres mine. Fuel lab 6 micron fuel filter. I'm still running stock lines and had to improvise where to put a fuel filter
Waddlz is offline   Reply With Quote
Old 01-03-2019, 12:32 PM   #8838
anarekist
Member#: 468117
2017 WRX
DMG
awesome, so you just cut your fuel line and clamp it onto a barbed fitting to an fitting to the fuel filter? what kinda clamp are those?
Old 01-03-2019, 12:35 PM   #8839
Waddlz
Member#: 395275
2012 STi
I am running stock fuel lines, ID1300s, Radium FPR and Cobb Flex fuel.
basically had to run a new line from the firewall to this filter, which uses -6AN on the end. I bought some -6AN to 5/8 hose barb from Summit Racing. 1 90 degree and 1 45 degree. Then I ran the hoses and clamped them using fuel clamps.
Old 01-03-2019, 12:37 PM   #8840
Waddlz
Member#: 395275
2012 STi
My buddy and I made a "Custom" bracket out of some aluminum, and Silicone Intakes sells a bracket for fuel pumps that you can just bolt to a firewall if you wanted. so i used one of those. its solid as hell.
Old 02-08-2019, 11:28 PM   #8841
Scoobie_Newbie_916
Member#: 497530
2017 WRX Premium 6MT
Pearl White
Default This Threads Been Alive forever
Damn This Thread is old
Scoobie_Newbie_916 is offline   Reply With Quote
Old 02-26-2019, 04:10 AM   #8842
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Haven't posted in ages but I'm currently working on 8 injector setup, I hated running at 12 afr on pump gas with id1700 and crap gas milage
Bariga is offline   Reply With Quote
Old 04-03-2019, 07:22 AM   #8843
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Just watched this video. While its not apples to apples, it shows MBT on gas and ethanol are about the same as far as ignition timing. Maybe even less timing on ethanol. The e85 advantage being that you can reach MBT in knock limited areas that you cant on gas, giving the illusion e85 "needs" more advance than gas.
Old 04-05-2019, 08:32 AM   #8844
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
