Welcome to the North American Subaru Impreza Owners Club Saturday May 25, 2019
Old 05-15-2019, 09:13 PM   #1951
fullah
Member#: 233053
What's consensus on new strut mounts? Specifically whether it makes sense getting either the group n or the whiteline offset front mounts? I just bought the tein basis to replace my base suspension and wanted to get new mounts instead of having to disassemble my factory stuff. Not sure whether to just get oem mounts or upgrade.
fullah is offline   Reply With Quote
Old 05-15-2019, 11:44 PM   #1952
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Depends on the model and year.
Let us know.
If its a 2002-2007 WRX OR STI then yes the STI Group-N mounts are WELL worth it.
If its a 2008+ car with under 75k on it then the OEM(stock) mounts are good.
If in fact WL has actually upgraded the bearings in the Com-C mounts then yes that would be a good option too.
Myles
RCE
RaceComp Engineering is offline   Reply With Quote
Old 05-16-2019, 08:52 AM   #1953
fullah
Member#: 233053
Let us know.
Myles
RCE
Sorry forgot to add that in. It's a 2018 WRX base.
Old 05-16-2019, 08:56 AM   #1954
carlos.danger
Member#: 363268
2015 WRX STi
You definitely dont need upgraded mounts.
Like you said, unless you dont want to disassemble your stock stuff, then get some upgraded mounts.
carlos.danger is offline   Reply With Quote
Old 05-16-2019, 11:22 AM   #1955
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Yeah you dont need upgraded mounts. I'd use oem mounts(yours) and possibly get the WL caster bushing to get more front caster. Get an alignment to get more front camber and you should be good. The extra caster AND camber will improve turn in response very much so.
Myles
Old 05-16-2019, 11:40 AM   #1956
Norm Peterson
Member#: 498642
2019 WRX Limited
Dark Grey
Wouldn't he also need bumpsteer correction to go with any caster change he cares to make?
Norm
Norm Peterson is offline   Reply With Quote
Old 05-16-2019, 11:45 AM   #1957
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Norm
Yes only if he went beyond 7.5 caster( In my experience). He'd most likely end up at about 7.0 caster which still improves turn-in.
Myles
Old 05-16-2019, 12:05 PM   #1958
Norm Peterson
Member#: 498642
2019 WRX Limited
Dark Grey
Myles
Thanks.
Norm
Old 05-16-2019, 01:54 PM   #1959
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Thanks.
Norm
Btw its awesome to have a person with your experience and knowledge on the forums. They really should change your status to guru since you go back as far as I can remember to the 2000 or 99 era!
Myles
Old 05-17-2019, 03:29 AM   #1960
Kostamojen
Member#: 2272
2018 Type-RA 196/500
1999 OBS Camo Wagon
Does anyone happen to know the spring rate specs on the STI pink springs (from Japan parts) compared to the stock and RCE yellows?
Old 05-18-2019, 04:47 PM   #1961
Cianski06
Member#: 500975
A good way to improve ride quality on a 16 base WRX is to find a set of the inverted front WRX (not STI) struts. And make sure your tires aren't overinflated (incredibly common).
- Andrew
Thanks for the reply! ill keep an eye out for some used WRX premium inverted struts.
Cianski06 is offline   Reply With Quote
Old 05-21-2019, 06:35 PM   #1962
bamx
Member#: 501386
Hey guys quick question; RCE Yellows vs WL front and rear sway bars. Which will make the biggest difference in handling as a first mod?
bamx is offline   Reply With Quote
Old 05-22-2019, 01:16 AM   #1963
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
What car do you have trim yr model?
What do you do with it?
uofime is offline   Reply With Quote
Old 05-22-2019, 01:47 AM   #1964
bamx
Member#: 501386
sorry, it was a pretty poorly thought out question wasnt it.
I have a 19 STI, daily driver with occasional spirited canyon driving. I find the car understeers a fair bit, makes me quite hesitant throwing it into a corner.
I'm looking to do either lowering springs or replace the sway bars + end links. I get the feeling the sway bars will have greater efficacy in improving handling however the lowering springs also make the car look a tonne better so I'm hoping someone can convince me that they also help handling a lot too.
thanks for your help
Old 05-22-2019, 10:00 AM   #1965
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
For street use definitely skip the front sway and do a 22 in the rear. Save 100$ and keep you factory endlinks they’re fine.
Get the springs if you want the look, but don’t kid your self about it being a great performance benefit. It’s fine to want to be a hot boi
Then do th real thing for handling improvement and get a good performance alignment. Spend the extra 20$ and throw a set of secondary camber bolts in the front.
With those and the springs you should get around -1.7° of front camber then zero front and rear toe.
For bonus points get a rear alignment kit, on a budget the cam type lower controll arms and eccentric toe bushings are a good option. Drop rear camber from the probable -2.3° with the springs to -1.2° or so ( half a degree less than front).
Old 05-22-2019, 10:37 AM   #1966
Norm Peterson
Member#: 498642
2019 WRX Limited
Dark Grey
Whatever handling improvement you get from "lowering springs" is going to be coming from the lowering springs being stiffer than OE. Lowering by itself doesn't do what the change in appearance suggests, and with strut suspensions the roll center drops faster than the amount the car CG drops (meaning more roll if spring rate is held constant).
Don't overlook the shocks & struts. They're responsible for providing a feeling of composure and affect things like corner entry and exit, and are a more important part of the handling puzzle than most people give them credit for being. Handling is about much more than how many skidpad g's your car can pull or how flat you can hold the amount of roll down to.
Norm
Old 05-22-2019, 11:22 AM   #1967
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Good responses here.
Springs, rear swaybar, and a GOOD alignment (with GOOD being the crucial piece many overlook) will be a great start.
Alternatively, we do have our RCE SS1 coilovers. They're our entry level coilovers in terms of price, but an awesome road & track type suspension. With those, you could stick with OEM swaybars. They'll ride better than OEM shocks + RCE Yellows too. Damping adjustable and come with front lowering camber plates.
Old 05-22-2019, 01:17 PM   #1968
carlos.danger
Member#: 363268
2015 WRX STi
I've said it before and I'll say it again: I really enjoy my RCE YELLOW springs. I felt a difference in ride and stability. I also got a proper performance alignment, SPL rear control arms, and a set of Michelin pilot sport cups and I can say that the cars' performance is rarely pushed beyond its capabilities. I have done a few track days, and a lot of spirited driving and I'm very happy with how it performs.
Old 05-23-2019, 10:42 PM   #1969
bamx
Member#: 501386
^ thanks for all the advice above guys
I'll start with the rear swaybar + lowering springs and then go from there
Old Yesterday, 06:13 PM   #1970
carlos.danger
Member#: 363268
2015 WRX STi
Pros and cons of upgraded engine mounts
Old Today, 01:18 AM   #1971
IT.WRX
Member#: 494048
Default Looking for compatible suspension
Hey guys, not sure if this is the right thread but does anyone know exactly what other Subaru struts/coils fit the 15+? I've seen the 15+ STI fits the WRX but I'm wondering what else I could get and just directly swap into my 17 WRX. TIA
IT.WRX is offline   Reply With Quote
