Welcome to the North American Subaru Impreza Owners Club Thursday July 18, 2019
Mid Atlantic Impreza Club
Old 09-07-2017, 10:55 PM   #4026
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
4 other Subarus
My 95 Impreza IG switch did what you are describing. Replaced it with a new unit and all was well!
carnz-pj-410 is offline   Reply With Quote
Old 09-08-2017, 09:25 AM   #4027
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Good to know. Were you able to get it keyed to your old key (so the door locks and trunk still match), did you change out all the locks, or did you just end up with 2 different keys?
Old 09-08-2017, 09:57 AM   #4028
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
4 other Subarus
I was able to buy the ignition switch from Subaru and i swapped my key lock cylinder to the new IG switch. No key change required
Old 09-08-2017, 10:31 AM   #4029
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Ahhh, got it. I was thinking the entire cylinder, not just the switch. Cool, thanks.
Edit: Looks like my '97 Legacy uses the same part. Since it's dead in the garage, I could cannibalize the part from the Legacy to see if that fixes the problem on the Impreza.
Old 09-11-2017, 06:22 PM   #4030
corona672
Member#: 262902
'04 WRX Hybrid
It's a wrap!
T9 at summit point flagger called out 'we just witnessed a hell of an event' as I stumbled off track hot into the pits formula D style.
How did this happen??? Checked torques before event, no other warning signs/vibrations. Hub is broken missing about a half inch of spindle - the rest is still on the axle, wheel bearing shot, and the axle sheared at the chamfer between the spline and the thread.
The bearing and hub were new this season, unsure on axle age.
corona672 is offline   Reply With Quote
Old 09-11-2017, 11:59 PM   #4031
Lagunagreen
Member#: 410537
2002 Wrx Sedan
Wrb
too much powaa or because racecar.
Lagunagreen is offline   Reply With Quote
Old 09-12-2017, 12:10 AM   #4032
corona672
Member#: 262902
'04 WRX Hybrid
It's a wrap!
Way too much racecar
Old 09-12-2017, 09:02 PM   #4033
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Originally Posted by corona672 View Post
Could you post some smaller pictures? I prefer to not be able to see any details at all.
Seriously, though, I've never seen/heard of that happening.
Old 09-12-2017, 10:07 PM   #4034
corona672
Member#: 262902
'04 WRX Hybrid
It's a wrap!
I blame my phone
http://i.imgur.com/gAeFaTi.jpg
http://i.imgur.com/xz68piS.jpg
Man those hoosiers have some grip!
It is frustrating, because until I know the cause of failure - I can't scope how much replacement or preventive maintenance on the other side I need to do.. I'll have to tear-down and investigate more soon
I'm leaning towards an out of spec knuckle. I had a tech help push out a race with his press a few events ago, but I failed to mention he should probably take out the lock ring first.. very suspect.
Old 09-15-2017, 01:22 PM   #4035
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Just pulled the switch out of the Legacy and installed it in the Impreza. Good to go. (Well, at least it gave proper indications and started the first time. Hopefully it continues to do that with some more cycles.) Thanks for pointing me in the right direction, carnz-pj.
- Dug through my spare nuts 'n' bolts bins and found some replacement fasteners for ones that I discovered were missing while I was replacing the ignition switch. Not sure what it's called exactly, but the metal cover plate on the bottom of the steering column had only 1 of the 4 screws holding it in place. Now it has 4.
- Replaced the positive battery terminal.
Old 09-17-2017, 02:14 PM   #4036
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
- Reconnected the speedo cable in the Impreza. It had popped off the back of the speedo the other day. I guess I inadvertently tugged on it or something while I was digging around under the dash during the brake switch troubleshooting. Went for a quick spin and verified the speedo is operational again.
Doesn't seem like the cable has anything in the way of a clip to keep it in position. The speedo cable on my Fox Mustang has a plastic clip that you have to press down to disengage the cable from the back of the speedo, kind of like a wiring harness connector.
Old 09-17-2017, 02:19 PM   #4037
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Attempted to "Wipe New" the dashboard and all plastic pieces I removed from the impreza yesterday...and the wipe new was hardened in the bottle. Apparently I will be driving to town and buying another bottle shortly, since all of the parts are now in my way.
Old 09-18-2017, 01:18 PM   #4038
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Hmmm, I have a bottle of that stuff somewhere in the garage, not sure I've ever used it. Wonder if the bottle I've got is also dead?
Old 09-18-2017, 01:30 PM   #4039
Loya1ty
Member#: 383680
2008 Impreza 2.5i
Newport Blue Pearl
Bought new Car Wash and Polishing kit.. didn't wash my car.
Loya1ty is offline   Reply With Quote
Old 09-18-2017, 03:30 PM   #4040
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
4 other Subarus
Ordered some more parts for my 2nd 95 Impreza Coupe, hopefully i'll have it road ready soon
simple 1.8L 4EAT FWD car, just a beater
Old 09-18-2017, 03:30 PM   #4041
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
4 other Subarus
Old 09-18-2017, 09:16 PM   #4042
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
If you had it for several months, possibly hardened. I bought another bottle and did all of the dash, console, steering pieces, etc. It basically made them have super gloss and darkened some a little.
The dash has only been faded for maybe six months, it was nice and dark before. The Wipe New didn't do any type of miracle on the dash, it had lots of dry looking areas after coating it last night. I coated it again tonight and it seems to have helped a little, but won't know until tomorrow.
I used something similar a few years ago on my other impreza and remember it lasting a few months then fading again. If this stuff only lasts a few months, after all of the bragging they do about going through a car wash hundreds of times, I will be just slightly pissed. It also has VERY strong ammonia + mothball scent, I suggest doing it in the garage. They claim it needs to be done in a cool dry area, which makes it almost impossible for most people with the smell being so bad. Sucks I didn't end up with the house I wanted several years back, had a separate large air conditioned workshop/garage. :/
Taking the dash out wasn't fun at all, with all of the extra wiring I've added having to be disconnected. I may install quick disconnects on all of them in case.
Old 09-23-2017, 10:32 AM   #4043
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd jdm 6 speed now!
Just picked this up yesterday, so about to install
666stars is offline   Reply With Quote
Old 10-05-2017, 07:32 AM   #4044
wilk489
Member#: 368293
2016 Focus RS
Traded my 2006 sti towards a 2016 focus rs on Monday. Never thought I'd get rid of it, but the timing seemed right and the rs is definitely a nice upgrade.
wilk489 is offline   Reply With Quote
Old 10-11-2017, 02:26 PM   #4045
robschilke
Member#: 397553
2014 GR8 DGM
Subaru Ambassador
What up Bmore?
Just modified one of my spare keys and converted it into a switchblade for my 2014 GR STI. No more teardrop remote + rogue key anymore. Much sleeker.
robschilke is offline   Reply With Quote
Old 10-12-2017, 07:10 PM   #4046
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Had the BRAKE light come on during the drive to work this morning. Got to work, checked the level of the reservoir, a bit low. Hmmm... Checked inside the wheels for signs of leakage and the right front looked wet.
Thinking I had a brake hose going bad, I left work early so I could go home to troubleshoot, then make it to Mach V to pick up a set of braided lines. (Had already checked online for a new stock hose - $50! Might as well spend ~$100 and get all 4 braided lines if it's $50 for just a single stock one.)
Took the wheel off and found that it wasn't wet with brake fluid, it was wet with CV grease that magically leaked out past an intact CV boot (and was all over the wheel, the brake caliper, the brake backing plate, the base of the strut, etc). I've had that happen on my Legacy before, but in that case, I could see that the boot clamp had allowed the boot to slip a bit, and I could see signs of where the grease escaped. That's not the case this time - both boot clamps are firmly in place, and I can't see where the grease came from. Weird.
Cleaned everything up, put the wheel back on, and topped off the brake fluid reservoir. I imagine I'll be replacing a bad axle at some point, and I'll keep an eye on the brake fluid to see if it drops again.
Old 10-12-2017, 09:10 PM   #4047
carnz-pj-410
Member#: 110994
1995 Turbo Impreza
4 other Subarus
dropped the EJ18 back into my 2nd coupe (the beater), threw my 2nd set of RS wheels on, and it's about ready to go
Old 10-21-2017, 11:47 PM   #4048
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
- Repaired a dead line in the rear window defrost grid. When I bought the car last winter I noticed that one of the lines in the grid didn't work, and of course it was right about the middle of the rear window. I bought a Permatex kit to fix it months and months ago, but finally got around to doing it on Tuesday.
The directions tell you not to use the defrost for 24 hours, so I didn't get to test it out before heading out of town for the 2nd half of the week. After getting back in town I was able to test it and sho'nuff the whole defrost grid works as it should. Hooray!
Old 10-24-2017, 09:48 AM   #4049
infinite012
Member#: 74392
15 Foz
The radiator broke on my Spec B.
Old 10-24-2017, 10:30 AM   #4050
j4k3
Member#: 262126
2007 STI
Plastic radiator problems. Mishi upgrade is a must.
j4k3 is offline   Reply With Quote
