Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2020
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 08-16-2013, 01:24 AM   #751
RichSJones
Member#: 235661
2006 Evo
GG Cursed
Originally Posted by *Ulimited* View Post
speaking of kanards I like the look of these
BTW, I think the only thing that makes these canards illegal is that they stick out past the farthest point of the bumper.
Something like the Voltex bumper with canards a la Jarrod Hoops would be legal IMO, as the canards finish flush with the edge of the lower half of the bumper. This pic is from the year the car won SM (2008). The question has been asked on SCCAForums recently and the general consensus is that those would be legal.
RichSJones is offline   Reply With Quote
Old 08-16-2013, 11:58 AM   #752
Splash
Member#: 55936
04 WRX STi
I'm still figuring out why nobody nailed that car for the front bumper beam.
Splash is offline   Reply With Quote
Old 08-16-2013, 12:33 PM   #753
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Dusty
It was still the stock beam as far as I saw back then.
subydude is offline   Reply With Quote
Old 08-16-2013, 12:35 PM   #754
Leafy
Member#: 330625
2006 WRX
In that pic I cant see where there's a spot of the bump beam, unless its behind the intercooler or behind the lower section of the hood. Or doesnt go all the way across.
Leafy is offline   Reply With Quote
Old 08-16-2013, 02:08 PM   #755
subydude
Member#: 80649
Dusty
The stock Evo FMIC sits where the ARC FMIC sits. The bumper beam was designed with the OE FMIC in mind so most kits (that I'm aware of) don't modify the beam much, if at all. Plus, they ran an aftermarket bumper skin that probably gave more clearance as well.
I'm pretty sure that someone would have thrown paper if something that obvious was wrong with it in 2008 after they won. I remember looking it over and not seeing anything out of the ordinary.
Old 08-16-2013, 02:08 PM   #756
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
It's supposed to run across the top of the intercooler, and is normally hidden by the middle piece in the front bumper cover. I don't see a beam in that picture, and a lot of those replacement from bumper covers make you remove it to fit correctly. Hard to say though since it's black and also has some holes in it.
Old 08-16-2013, 03:21 PM   #757
Splash
Member#: 55936
04 WRX STi
Right, but it looks like there is nowhere near enough room between the top of the FMIC to the bottom of the grille for a US 5mph bumper beam.
I mean, Subies can get rid of the black part of their bumper covers too, but they gotta remove the beam and replace it with something smaller to get anything from it, like a JDM beam...
Also, you gotta wonder why there would be slots in the bumper cover between there if there was just a fat beam behind it.
Old 08-16-2013, 07:37 PM   #758
RichSJones
Member#: 235661
2006 Evo
GG Cursed
I actually have his old bumper beam sitting in my garage. I bought it from him a while back because I'm getting the same Voltex bumper. He notched it for clearance. I can guarantee you that it weighs within a pound of stock.
The stock beam actually has rectangular holes in it that are the same size as the rectangular cutouts in the stock bumper.
Here's my car with the stock bumper beam.
Old 08-16-2013, 11:14 PM   #759
griceiv
Member#: 162781
interesting that you can't see a spot for it because i can actually see it in that pic.
griceiv is offline   Reply With Quote
Old 08-17-2013, 01:40 AM   #760
Splash
Member#: 55936
04 WRX STi
To me, and this could just be photo oddities, but the gray EVO looks like the FMIC hole is shorter and the area between it and the grille is taller.
That is a tiny beam in comparison though. I suppose it could just be the difference between having that 5-star crash rating and, well, not having it.
Old 08-17-2013, 01:30 PM   #761
Butt Dyno
Street's closed, pizza boy
Member#: 17301
2016 FoST ST3
2006 Evo #17 STU
Old 08-17-2013, 09:13 PM   #762
subydude
Member#: 80649
Dusty
Sadly enough, the crash ratings is why my wife chose not to buy another Evo and went with a Focus ST instead.
Still, I'm jealous of the Evo beam. I'm really hoping the letter I wrote prompts some discussion on modifying the front beam. If not, I'll stick with the stock location and grumble loudly.
Old 08-18-2013, 03:02 AM   #763
RichSJones
Member#: 235661
2006 Evo
GG Cursed
You're correct, the fmic opening is smaller. I still have the stock bumper.
Old 08-18-2013, 10:39 PM   #764
Leafy
Member#: 330625
2006 WRX
I see the intercooler through the holes where I'd expect the bumper beam to be.
Old 08-18-2013, 11:36 PM   #765
Splash
Member#: 55936
04 WRX STi
Well, there you go Tim, notch what you need cleared for the big FMIC, take 1 pound off of what you cut out, tack the rest back in off to the sides. It does clearly say you can notch to clear allowed parts as long as it's <= 1 pound lighter.
I was under the impression that modifying the beam was verboten (sorta like the steering column), hence my original comment about Jarrod's car. With the IC that much closer to the grille, there was no way it fit without doing so.
Old 08-19-2013, 02:25 AM   #766
griceiv
Member#: 162781
you only see the intercooler through the factory slots in the bumper beam (closer to the center). the rest of the intercooler that should be visible though the bumper cover slots is blocked by the bumper beam.
Old 08-19-2013, 09:41 AM   #767
subydude
Member#: 80649
Dusty
No, I knew that I could do that, but there's no way I could justify it under the 1lbs/1" rule I'd be notching a lot more than is allowed to get things to fit. FMIC fitment? Yeah, I could do that, but doing a low mount turbo with FMIC....nope.
Old 08-25-2013, 03:59 AM   #768
Acrdys
Member#: 152261
2007 WRX 2.5
Crystal Gray Metallic
air pump delete legal for SM?
Acrdys is offline   Reply With Quote
Old 08-25-2013, 09:12 AM   #769
subydude
Member#: 80649
Dusty
Yes it is.
Old 09-10-2013, 12:18 PM   #770
Leafy
Member#: 330625
2006 WRX
No comments on Solo Nats?
Old 09-10-2013, 01:58 PM   #771
subydude
Member#: 80649
Dusty
I didn't drink as much as I should have
Old 09-10-2013, 02:00 PM   #772
Leafy
Member#: 330625
2006 WRX
I dont think I did either. I drank quite a bit but I only got beyond buzzed with the 1 dollar miller lowlife at brothers on wednesday. Too long between drinks, too much time being the DD.
Old 09-10-2013, 02:10 PM   #773
willub
Member#: 245695
04 STi
How am I just finding this thread?
Here is my current setup in my 04 STi.
Power/engine mods:
Blouch 1.5 XT-R 8cm
AMR top mount
Grimmspeed EBCS
Deatschwerks 850cc injectors
Walbro 255lph fuel pump
CNT catless downpipe and Gimmick cat-back
Tomei EL header and up pipe
KSTech 73mm CAI
Gimmick turbo inlet
Conservative tune by BrenTuning 385whp/380wtq
Suspension:
Fortune Auto v4 500's 10k front 8k rear
Whiteline 24mm front and rear adjustable sways and whiteline endlinks
No alignment yet (I know, I know )
Drivetrain:
Group N tranny mount and SPT/STi shifter bushing
Perrin lock out bolts and diff/outrigger bushings
Driveshaft Shop carbon fiber drive shaft (just installed)
ACT streetlite flywheel (just installed)
Exedy stage 1 heavy duty clutch (just installed)
Brakes:
Centric high carbon rotors
Ferodo ds2500
Regular dot 4 fluid for now
Daily driver/race setup
17x9.5 +38 silver enkei rpf1's
255/40/17 Dunlop Z2's
Leafy, you drive the SSM miata in NER right? I have yet to read through this thread
willub is offline   Reply With Quote
Old 09-10-2013, 02:13 PM   #774
Leafy
Member#: 330625
2006 WRX
Well there's two up here. Mine's the one with wings and things. I'm not very useful on subie setup without driving it.
Are those lockout bolts the ones that stop the rear sub frame from shifting? Are those legal in SM?
Old 09-10-2013, 03:03 PM   #775
subydude
Member#: 80649
Dusty
I only drank Tuesday night to the "I'm kind of drunk stage". Then I pussed out the rest of the nights since I had to be up earlyish the following morning. I need to plan more bar adventures for next time.
They're legal in SP. There was a clarification several years ago for an ESP WRX so SM gets it through inheritance.
Will my trans swap put me automatically in Street Mod? RebelINS Autocross 6 07-22-2013 05:24 PM
I'm still legal for Street Mod right?(list inside) Davenow Motorsports 4 05-24-2003 03:21 AM
street mod tire question Jaxx Motorsports 2 02-20-2003 07:59 PM
Autocross class... Street Mod? Motohead1 South East Region Forum 11 06-26-2001 10:11 AM
Street Mod news Eric Technical Forum Archive 5 05-31-2000 02:33 PM
