Welcome to the North American Subaru Impreza Owners Club Friday July 19, 2019
Mid Atlantic Impreza Club
Old 01-10-2014, 03:00 PM   #1726
Smurftastic
Member#: 243697
17.4 PSI ECUtuned 02
BLOD Cofounder|TopScoob31
Continue preparations for the engine bay overhaul, ordered some custom fabricated stuff, preparing to go under the knife
Smurftastic is offline   Reply With Quote
Old 01-10-2014, 03:15 PM   #1727
Iggy1361
Member#: 377264
2013 Crosstrek
Desert Khaki
Changed the oil in the corsstrek... also ordered a fumoto oil drain... which i should have done first lol.
Iggy1361 is offline   Reply With Quote
Old 01-10-2014, 06:14 PM   #1728
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Just bought a power steering pump for my 07 wrx, 87xxx and it finally decided to let go with all this bitter cold.
Now time to.go pick it up and install it.
EvileyeZ88 is offline   Reply With Quote
Old 01-10-2014, 06:35 PM   #1729
infinite012
Member#: 74392
15 Foz
State inspection complete.
infinite012 is offline   Reply With Quote
Old 01-11-2014, 06:10 PM   #1730
wilk489
Member#: 368293
2016 Focus RS
Swapped out my 2006 radio with one from a 2007 sti that has an aux port so I can finally listen to Spotify.
wilk489 is offline   Reply With Quote
Old 01-12-2014, 08:36 PM   #1731
WorldRallyRedneck
Member#: 6506
2005 WRX Wagon
installed all new door speakers front and rear, then found out my passenger side rear window wont open.
WorldRallyRedneck is offline   Reply With Quote
Old 01-13-2014, 09:52 AM   #1732
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
just finished installing my walbro pump.
bluemax189 is offline   Reply With Quote
Old 01-13-2014, 10:25 AM   #1733
Neysa
Member#: 268694
2008 WRX
Ooo, good idea
Neysa is offline   Reply With Quote
Old 01-13-2014, 12:48 PM   #1734
Borjaq
Member#: 4812
04 STi
JBP
I stood in front of my car and listened to the bad bearring in my a/c tentioner pully for about 3 minutes at lunch while smoking a cigg.
Was deciding if I should go order a new one now or just pull off the belt and worry about it when I want a/c again.
:shrug:
Borjaq is offline   Reply With Quote
Old 01-13-2014, 01:02 PM   #1735
ThatGy
Member#: 137791
2002 Impreza WRX
WR Blue
:shrug:
You may want to fix it since the defroster uses A/C and will not work very well without it.
ThatGy is offline   Reply With Quote
Old 01-13-2014, 01:19 PM   #1736
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
I don't believe that whole thing....when I had a/c I never used it for defrosters....and now that I have no a/c system the defrosters still work 100%.
:shrug:
Same thing happened to mine a while ago....after a few minutes of listening to it like you, I ran inside and grabbed a pair of scissors to cut the belt.
Then I later deleted the whole system for teh weight savingz.
RavensFan7 is offline   Reply With Quote
Old 01-13-2014, 01:24 PM   #1737
ThatGy
Member#: 137791
2002 Impreza WRX
WR Blue
Well, when you turn on the defroster for the windshield, it turns on the A/C automatically. The A/C system removes moisture from the air which helps to prevent the inside of the windows from fogging up. Sure, it will still work without it (espically to defrost ice on the outside of the windows), but it works better with the A/C.
Old 01-13-2014, 03:10 PM   #1738
RavensFan7
Member#: 346388
SRP
..and you're probably right. I just don't agree when people say it like this:
The defroster uses A/C and WILL NOT work very well without it.
Not trying to jump down your back about it, I've actually read that tons of times and I think it's just how people word it....
I'd be OK with:
"It MAY NOT work as well"
Only reason I said anything, is so that person with the bad a/c pulley doesn't go out of their way trying to fix it just for the defrosters.
Old 01-14-2014, 08:46 AM   #1739
Borjaq
Member#: 4812
04 STi
JBP
Yeah, went and got a new pulley/bearring piece, just waiting to put it on.
Defrost, hah!
Old 01-14-2014, 08:58 AM   #1740
colin edge
Member#: 97648
So tired. Front and rear upgraded pads and rotors. Front kyb struts. Short shifter and bushings. Trans mount. Pitch mount. Turbo back. Re flash.
Oh and assembled the heads for my 351 cleveland.
Someone pass the Advil and alcohol.
colin edge is offline   Reply With Quote
Old 01-14-2014, 09:05 AM   #1741
slayer44wagon
Member#: 300834
03 wrx wagon
Logged my first data
slayer44wagon is offline   Reply With Quote
Old 01-15-2014, 04:14 PM   #1742
NowDatsG
Member#: 364933
08 Wrx sedan
First time installing overlays/vinyl, I think I did an ok job.
NowDatsG is offline   Reply With Quote
Old 01-15-2014, 08:32 PM   #1743
yuephoria
Member#: 64624
2008 FS XT
WR Blue Pearl
I bought a Zero/Sports oil cap on clearance from FastWRX.com.
Yesterday, I had Andrewtech Automotive open up a lightly used R160 case with rear Carbonetics Carbon 1.5 way LSD that I bought off the Forester forum for inspection and service. Everything checked out and I can't wait to have this installed next week!
yuephoria is offline   Reply With Quote
Old 01-15-2014, 08:45 PM   #1744
DavC825
Member#: 201736
12 IS-F Sold!! :(
Slowest 07 STi
Originally Posted by yuephoria View Post
I bought a Zero/Sports oil cap on clearance from FastWRX.com. Yesterday, I had Andrewtech Automotive open up a lightly used R160 case with rear Carbonetics Carbon 1.5 way LSD that I bought off the Forester forum for inspection and service. Everything checked out and I can't wait to have this installed next week!
Race car?
DavC825 is offline   Reply With Quote
Old 01-15-2014, 09:29 PM   #1745
yuephoria
Member#: 64624
2008 FS XT
WR Blue Pearl
Originally Posted by DavC825 View Post
Race car?
Apparently. :-)
Actually, I just found a good deal on the rear LSD and R160 case as a complete unit. It has less mileage on it than my stock LSD. I'm just trying to extend the useable life of my Forester.
Old 01-15-2014, 09:39 PM   #1746
AcquaCow
Member#: 36838
2001 B50 RSTi Sedan
2011 DGM WRX hatch
Bought a used roof rack for it. Yakima Whispbar.
Might be using it as early as Sat for a ski day-trip
AcquaCow is offline   Reply With Quote
Old 01-15-2014, 11:28 PM   #1747
ThatGy
Member#: 137791
2002 Impreza WRX
WR Blue
I removed the clock and started running wires for my new gage pod.
Old 01-15-2014, 11:36 PM   #1748
HawkeyeKev26
Member#: 377346
2006 Subaru Wrx Tr
I didn't do much besides drive it! But I did order some parts for it!
HawkeyeKev26 is offline   Reply With Quote
Old 01-16-2014, 12:41 AM   #1749
Minorthreat7171
Member#: 288712
2007 WRX IAP Stage2
Installed ebay "brand" android head unit. Had to trim the bezel to get it to fit, about 3/8 off each side and 1-2 mm off the top and bottom.
sorry for the crappy cell pic
Minorthreat7171 is offline   Reply With Quote
Old 01-16-2014, 08:07 AM   #1750
Borjaq
Member#: 4812
04 STi
JBP
:shrug:
Replaced it, much better. Spun the old one and it sounded like sand, lol.
