Welcome to the North American Subaru Impreza Owners Club Saturday July 20, 2019
Mid Atlantic Impreza Club
Old 02-15-2014, 10:09 PM   #1826
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Originally Posted by 96accord View Post
Replaced both front axles and replaced the drivers side sway bar bolts (one sheered off)
I thought your selling the car
Louie is offline   Reply With Quote
Old 02-15-2014, 10:14 PM   #1827
96accord
Member#: 145105
2007 Impreza WRX STi
'15 Accord (Daily)
Well when you use it every day for work you kinda need to replace the axle when they have an issue
96accord is offline   Reply With Quote
Old 02-16-2014, 08:29 PM   #1828
jeffy2.5xt
Member#: 376335
2005 outback 2.5xt
finally got around to putting in that fresh rotella t6 and installing my sti up pipe. now to find some time to install/fab my exhaust.
jeffy2.5xt is offline   Reply With Quote
Old 02-16-2014, 08:40 PM   #1829
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Removed the dashboard as part of the neverending EZ30 swap.
Made some templates of the floor of the Mustang in order to cut some new insulation in preparation for new carpet.
Old 02-16-2014, 08:47 PM   #1830
Rackness
Member#: 380487
14 WRX
Not all that exciting but I put my RA mud flaps on. This is something Subaru should have as a factory offering. My hatch has mounting holes in the rear wheel well but none in the front. The RA set up is pretty nice but a factory solution vs a bracket would have a cleaner look.
Rackness is offline   Reply With Quote
Old 02-19-2014, 01:02 AM   #1831
yuephoria
Member#: 64624
2008 FS XT
WR Blue Pearl
Replaced the drivers low beam bulb. It was such a pain having to disconnect and remove the battery to get to the bulb.
yuephoria is offline   Reply With Quote
Old 02-19-2014, 05:03 PM   #1832
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
Holy hell the damn air pumps are a PITA on this car. Got the main actual pump off, stupid injector bracket off and deleted codes. Gotta go buy a low prifule jack i guess to get under the car for the pump valves.
bluemax189 is offline   Reply With Quote
Old 02-19-2014, 06:54 PM   #1833
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
why remove it?
Old 02-19-2014, 10:23 PM   #1834
96accord
Member#: 145105
'15 Accord (Daily)
Yours already ****ed up?
why remove it?
I had mine removed because it broke.
Old 02-20-2014, 10:09 AM   #1835
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
why remove it?
The system has a tendency to break, sometimes the valves are stuck closed (the best scenario) or they get stuck open, which is bad and causese the car to run lean.
The best option is just to remove the whole system, replace the valves with block off plates, and enjoy all the room for activities it frees up.
I think the dealer charges like $1200 to replace the air pump system. I'd rather put on some $35 block off plates and call it a day.
~Evil
EvileyeZ88 is offline   Reply With Quote
Old 02-20-2014, 01:21 PM   #1836
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
Nope making room for activities.
Old 02-20-2014, 02:03 PM   #1837
96accord
Member#: 145105
'15 Accord (Daily)
Yeah $1200 is crazy!
o0o
Old 02-21-2014, 11:47 AM   #1838
yuephoria
Member#: 64624
2008 FS XT
WR Blue Pearl
I replaced my 5 year old 3M Clearbra on the Forester for a new XPEL kit.
Old 02-21-2014, 12:40 PM   #1839
swcrow17
Member#: 304498
07 sold :(
Cleaned MAF; about to change plugs
swcrow17 is offline   Reply With Quote
Old 02-23-2014, 06:49 PM   #1840
Mr. AWDriver
Member#: 176505
07 SWP STI
Installed shifter bushings in a fellow subie owners wrx.
And finally installed my grimmspeed hood struts.
Mr. AWDriver is offline   Reply With Quote
Old 02-23-2014, 07:28 PM   #1841
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
Changed plugs, injectors and turbo
Untitled by bluemax189, on Flickr
Old 02-23-2014, 07:35 PM   #1842
CowboyD Eng6ine
Member#: 365893
2013 F150 FX4
Changed out my silver WRX fender badges for black ones.
CowboyD Eng6ine is offline   Reply With Quote
Old 02-23-2014, 08:39 PM   #1843
swcrow17
Member#: 304498
07 sold :(
change spark plugs in my car for the first time and for a first time in a Boxster engine.... WoW is that not easy
Old 02-23-2014, 09:10 PM   #1844
noahguth6
Member#: 353570
1993 Impreza L
Red
changed my oil, made a diy garage door lip, and a diy mesh grill. looks nice to me so i guess thats all that matters haha
noahguth6 is offline   Reply With Quote
Old 02-23-2014, 10:07 PM   #1845
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
swapped out front oem springs with tein h tech's. Started on the back and ran into a very, very tight strut bolt. Stopped, buttoned it all back up. Figured out and will take a different approach tomorrow. Sooo, took it to merchants, up on the rack and the guy had all 4 loose in 10 mins. Paid him cash and everybody was happy. Swapped the rears out...spring rates now a good match for my tokico d specs and tastefully lowered.
Alignment done. Car tracks well, corners razor sharp and "floaty" is gone. My 3 years unlimited alignment expired early Feb so signed up for another 3 yrs for $169 (got the special pricing).
mhoerath is offline   Reply With Quote
Old 03-01-2014, 11:05 PM   #1846
sailil
Member#: 26390
2016 WRX Whiteness
1993 Del Sol
Scrubbed off & rotated the tires. Plus another round of fiddling with the resistor on the rear o2 sensor. I thought hard about a light wash but decided to wait out Monday's snowstorm / salt bath. Sighed at the rust spots.
sailil is offline   Reply With Quote
Old 03-03-2014, 12:51 PM   #1847
mhoerath
Member#: 131379
justablue hatch
road trip from RVA to cheraw, sc. Drove the piss out of it on 100 miles of closed forest service roads to include packed sand, loose sand, churned up sand and wet sand mixed with clay And road tripped back via secondary roads.
ps. hate the lowered car. going to standard ride height king springs.
Old 03-03-2014, 07:10 PM   #1848
LightningRexi
Member#: 376105
2011 WRX Premium
Lightning Red
Got my cross bars put on the car after a plasti-dip session turned them black and had some fun in a little bit of snow on my way to work, yay night shift.
LightningRexi is offline   Reply With Quote
Old 03-04-2014, 10:12 AM   #1849
VXSS
Member#: 115345
'18 FXT Touring
Wiped off deer slobber and mud from plowing over it. Driver coming other way hit it first and slapshotted it over on my side, where it hit my front end and folded under the car, where I proceeded to drive over it.
Only damage I managed was cracking the OEM plastic slid plate. *whew*
VXSS is offline   Reply With Quote
Old 03-04-2014, 10:32 AM   #1850
Dayglow
Member#: 211395
0000 4wfp Flintstone
Mobile made of stone+wood
That's some serious luck there.
Dayglow is offline   Reply With Quote
