#1 |
Member#: 1026
Vehicle:'00 RS/WRX Stg5 '98 RS Stock |
![]() HI all,
This is slightly OT (home audio), but lends to the overall picture of what our sub systems do and DON'T do... I found this in the OT forum and thought i must share... http://www.rotarywoofer.com/ Many of you will rationalize this with Phenix Golds Cyclone http://www.phoenixgold.com/webfaq/cyclone.htm But that technology doesn't come close to this new technology. To any of you that actually care to learn about all things audio, it's a must read, as conventional subwoofer technology has been tossed out the window with this one. There is a review that covers everything including physics of WHY it does what it does... http://www.iar-80.com/ Edit: The link to the actual review "The only Subwoofer" http://www.iar-80.com/page142.html Again, this is only to further your personal knowledge base, and not ment to open a spiraling vortex/vertex in your universe... so read with caution... ![]() ![]() Now, if we could some how retrofit/re-design this into the car enviroment... Enjoy... Aaron
#2 |
Member#: 74041
Vehicle:2006 2012 Weee-strom 14 Hyundai Borenata |
![]() WTFBBQ! Looks like a radiator fan
#3 |
Member#: 1026
#4 |
Member#: 78952
Vehicle:2005 WRX CGM |
![]() Looks intriguing. I'll have to give this a read in a bit.
#5 |
Member#: 132389
BAIC
![]() Interesting stuff. However, it seems that it's only useful to reproduce sound below 20Hz and it's probably very bad with transients. You'll still want to keep a conventional subwoofer around.
#6 |
Member#: 140821
SCIC
Vehicle:MY06 nonSTi_vf39'd s204 |
#7 |
Member#: 113271
Vehicle:2006 STi Obsidian Black Pearl |
![]() For 23 to 25,000 bucks for total install, I'll be using conventional subs for a long, long time !
#8 | |
Member#: 1026
![]() Yup, i do
Last edited by Aaron'z 2.5RS; 02-16-2007 at 04:35 PM. Reason: Quoted for accuracy |
#9 | |
Member#: 1026
![]() Quote:
![]() But at the same time it is high end home audio, so it goes with the territory, i've sat in front of $80-100K systems and i guarentee there are plenty out there having houses built just for it... ![]() Last edited by Aaron'z 2.5RS; 02-16-2007 at 04:36 PM. |
#10 |
Member#: 7250
NESIC
Vehicle:2018 Honda Clarity |
![]() Man thats expensive but such an interesting read. Thanks for posting that up. Hopefully in 5-10 years we'll have $500 versions.
#11 |
Member#: 67536
NESIC
Vehicle:00 AW GM6 And a bunch of parts |
![]() 5hz is like what whales communicate at, isn't it?
Neat idea, I guess. |
#12 |
Member#: 92141
Vehicle:2014 GT-NC-PRHT Zeal Red. |
![]() part of me keeps looking at the "fan",
reading "$12,900 transducer" and thinking: April Fools joke. but, then I remember for high end HT, nothing is unreasonable. |
#13 | |
Member#: 102145
Vehicle:'04 STi/Cobb St. II 18L Java Black Pearl |
![]() Quote:
Not sure about whales... but isn't that what the Navy uses to communicate with submarines? Yeay! Your own personal ELF array!! http://en.wikipedia.org/wiki/Extremely_low_frequency Pretty cool... but for the $$$ I don't need faithful reproduction of a UH-60 that bad. I'll stick to silly cones for now. |
#14 |
Member#: 1026
![]() It will actually do 1hz at the same level as 5hz. From how it reads, it will do all frequencies at the same level, no roll off at all.
The fan spins at a constant rate, the fans motor has enough torque to keep it from slowing down, then the blades are of variable pitch and it's the pitch (and the subsequent swing of the blades) that creates the various frequencies (positive and negative waveforms) They say it outputs the same throughout it's range.... Honestly, i could see a much smaller version in a car, it would have to be in sort of an infinite baffle set-up (that is how it's used in the home, to separate the front waveforms from the rear waveforms) A DC motor structure and the transducer it used to change the pitch of the fan blades it powered from a "normal" amp..... I could see it being "doable" |
#15 |
Member#: 124060
Vehicle:2004 WRX STI Silver |
![]() I would think the DC motor would be powered by wall socket,...and the blade pitch would be powered by your amp.
Amps do not output a continuous dc current. |
#16 |
Member#: 78952
![]() Ha that's exactly what I thought at first. I mean, to people that drop $5k on a 0.5 meter cable $5k for a sub is NOTHING).
#17 | ||
Member#: 1026
![]() Quote:
If you read this: Quote:
Please read. |
#18 |
Member#: 1026
![]() bump, to try and keep people reading...
#19 |
Member#: 9090
Vehicle:09 Forester Gump 02WRX->04STi->09Gump |
![]() Looks like a total sham to me.
The combination of ultra cheesy website, extrapolated results, THD ratings you wouldnt even see on radio shack equipment... puhhhleeease. ![]() ~v6 the price isnt scary... I was reading a review in Home entertainment on a new projector a few hours ago... I read the whole review before looking at the price... then I see the unit is $29,999!!! That was almost as rediculous as the review on the home theatre in some guys house in FL... grand total aproximately $290,000. ![]() |
#20 | |
Member#: 1026
![]() I donno man, did you read any of the review http://www.iar-80.com/page142.html
The only extrapolated results, i saw were of the cone woofer below 20Hz... I'm sure the THD rateing were set so high to account for the cone woofer and it's THD at such low freq. Quote:
#21 | |
Member#: 9090
![]() I read the specs
As unacceptable as a $25,000 SUB-subwoofer that will RARELY do anything as very few sources use 20hz and down (from what i gather it suggests you cross it over at 20hz and down). In fact a decent amount of quality subwoofers use subsonic filters to entirely remove those frequencys for a few main reasons. First and foremost because you cant hear them, secondly because they use extremely high amount of power to produce (which rob power from tones that are actually audible), and thirdly because most of them simply cant reproduce sounds that low I read some of the review. I dont know anything about the source (website) and I dont trust any source I dont know about. It seems like one giant sales pitch to me, but what do I know... When a product is new, innovative, and actually works, EVERYONE talks about it. Not just one website that looks like it was made in a few hours. They would have a booth as CES, etc etc... ESPECIALLY for such a high ticket item. At least thats my always skeptical view. ~v6 Last edited by V6TurboTA; 02-19-2007 at 04:39 PM. |
#22 |
Member#: 1026
![]() I see what your saying man, but i spent an hour reading throught the review, and all of the reasioning is gone through about Why subs tipicaly have sub-sonic filters, and why a sub cannot couple to the air properly at such low frequencies, why normal subs require such power to even touch sub-sonic freq. and you may not be able to hear them, but tactle feeling is as much a part of hearing low freq AS hearing it... I mean how often can you hear a helocopter or jet before you see it.... you "feel" it first...
It may certinly be a sales pitch.... i'm not saying either way, just passing on info... |
#23 |
Member#: 78290
Vehicle:2011 WRX 5-door SSM |
![]() Can humans even hear this thing?
#24 |
Member#: 9090
![]() I totally agree with you on the feeling it part. If that was not true bass shakers would be useless
![]() This is an interesting piece. I'll say that. I am eager to see how this pans out in the grand scheme of the audio world. ~v6 |
#25 | |
Member#: 116046
Vehicle:1976 Lincoln 540 rwhp |
![]() Quote:
I'd pay $1,500 for one. |
Just when you thought greenpiece had attempted to ruin enough things................. | SQ3.0dotJP | Off-Topic | 35 | 05-23-2008 12:23 PM |
Just when you thought you had the worlds greatest PM already, a better one comes... | Davenow | Off-Topic | 216 | 03-28-2006 04:41 PM |
CD's you thought you had... | Brad Pittiful | Off-Topic | 17 | 03-23-2005 05:20 PM |
And you thought YOU had a nice camera/lens | trhoppe | Off-Topic | 33 | 08-26-2004 05:02 AM |
If you thought Ronin had the best car chase.... | AKGC8 | General Forum Archive | 34 | 12-10-2000 03:10 PM |
