Welcome to the North American Subaru Impreza Owners Club Wednesday July 9, 2025
Old 07-10-2003, 10:40 AM   #1
nmyeti
Member#: 4980
Exclamation Important UTEC announcement! Please read
It has been brought to our attention that over the last 4 weeks or so a fairly large number of UTEC have been shipped with an incorrect software version installed on them. All recent UTEC owners please take a few moments and verify which version of the software you have loaded onto your UTEC.
When looking at the home menu, the upper right hand will tell you which version of software your UTEC is running. The problem UTECs will display software version 3.1t.
If your UTEC is running 3.1t software you must update your software to the current 3.1 version immediately. The 3.1t software is used by our engineers in Australia to bench test some of the UTEC’s fueling functions and MAF hardware. It was never designed or intended to actually drive a car. It also renders any user tuning of the fuel map to be useless.
If you have version 3.1t please follow the update procedures at the following link
http://www.turboxs.com/utectuning.htm
We apologize for any inconvenience this has caused.
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 07-10-2003, 05:47 PM   #2
nmyeti
Member#: 4980
Bump
Old 07-10-2003, 06:57 PM   #3
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
It would've taken me weeks to figure out that fueling adjustments weren't having any effect...I dunno how much affect 0.1 adjustments are supposed to make.
Thanks Nathan
Concillian is offline   Reply With Quote
Old 07-11-2003, 02:39 AM   #4
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
****, I got a 3.1t also! That explains why my EGTs always stayed the same when I made fueling adjustments! I'm going to load up the right version and start tuning from scratch again..
Paul
PaulRex is offline   Reply With Quote
Old 07-11-2003, 07:25 PM   #5
Ski Man
Member#: 5334
WR Blue
Exclamation
Bump.
Now to go find out if I start over...
but I've never worked with a better vendor.
Ski Man is offline   Reply With Quote
Old 07-12-2003, 01:03 AM   #6
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
I did the software change this morning.. It was really easy. I had th etwo toggleson my board. So you just flip the one on the right to the "A" position and run the flash program and upload the new version. Took like 5minutes
I made 5 totally new maps, some of them are just copies of the first good one I made from the stg.2 map this morning but with altered boost levels, or a leaner fuel map for testing things like that.
Old 07-12-2003, 03:56 AM   #7
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I have a version 6 UTEC, and it comes with a different cover from that shown in the instructions. It was IMPOSSIBLE to tell which toggle was the 'flash' toggle with the UTEC on top of the ECU.
I tried the one on the bottom (as the UTEC sits on the ECU), which looked like the correct one from the picture in the instructions. That didn't work. So I tried the other one, and that one worked.
Nathan, the instructions may need some work for the new cover. Either that or make a little sticker with the labels for the two toggles so we can tell which is which without trying to peek in at the circuit board under the new, non-removable, cover.
Old 07-12-2003, 12:02 PM   #8
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Yeah I have the newer version as well (the one that came with the 3.1t software), and it was the toggle on the far side, or right side if your facing the UTEC reading the "TurboXS" sticker.
Old 07-12-2003, 05:13 PM   #9
nmyeti
Member#: 4980
The newest version of the UTEC manual (V3.11) which has been on the website since 6/12/03 has the information you are looking for on page8. If you received a revision 6 board with a old 3.1 manual, I apologize. Please download the new manual for future reference.
-Nathan
www.turboxs.com
Old 07-16-2003, 09:44 PM   #10
wyowrx
Member#: 34157
00 Toyota MR-S
bump
wyowrx is offline   Reply With Quote
Important OTter Memo: Please Read upnygimp Off-Topic 25 04-07-2006 09:55 AM
An Even More Important OTter Memo: Please Read 24 Off-Topic 12 04-06-2006 05:39 PM
ANNOUNCEMENT! **NEW FORUMS**, please read. munkis STi Forum Archive 30 09-19-2003 04:21 PM
UTEC Users please read the manual! nmyeti Engine Management & Tuning 15 10-27-2002 04:10 PM
Important, please read, be careful of this phsyco Delicious Tuning Bay Area Impreza Club Forum -- BAIC 30 08-02-2001 03:00 PM
