Tire & Wheel Forum sponsored by The Tire Rack |
03-31-2008, 11:20 PM | #1 |
Member#: 145303
Vehicle:2007 WRX TR Crystal Metalic |
Kuhmo Ecsta MX
Just wondering if anyone has these wheels and how do they like them? For $112 they are a great price, look great. Just wanting everyone 2 cents.
http://www.tirerack.com/tires/tires....nSpeedRating=V If anyone else has tires that perform better at about the same price or less, let me know. I have seem some of the new performance tires being released, but I just don't know bout throwing $160 towards tires that I might not feel a big difference between the $112 and $174(Potenza RE-0R1) These will be throw on my stocker 07 WRX wheels.
03-31-2008, 11:59 PM | #2 |
Member#: 140163
Vehicle:03 STi hellaflunctional |
i'm on them now and they're...loud. grip is impressive even though it's still in the 50s here and they've done well in the rain we've had lately. i won't be buying them again though, there are better tires to try out
04-01-2008, 12:47 AM | #3 |
Guest
Member#:
I have them and had them for 2 years. They worked very well in the dry. I was impressed. I would get them again especially for the price. But, I just ordered some re-01r's and they are already in the mail. mx's are great, but these bridgestones are going to be phenomenal.
04-01-2008, 12:49 AM | #4 |
Member#: 145303
Im so tempted by the re-01r's...just $170 a pop. Anyone sell them cheaper than tirerack?
04-01-2008, 01:32 AM | #5 |
Member#: 116557
NESIC
Vehicle:2016 WRX 6MT Ice Silver Metalic |
i am up in the air between the re-01's and the mx's
they both have good reviews. i heard the mx deals with heat a lot better and will retain its grip in hot running conditions. as well as the re-01 has much much more grip with a colder running condition |
04-01-2008, 03:38 AM | #6 |
Member#: 89291
Vehicle:03 WRXSedan+SSR/XS mbp |
I'm on my 2nd set of 225/45/17 MXs and will probably get the third set in September. I run them year long and get two years out of a set. MXs do handle heat well and take a couple of minutes to warm during winter driving. Hankook R-S2 offers similar performance and cost. Comparing MX to R-S2: MX handles heat better and is a better tire in the rain, R-S2 ha slightly better dry grip so long as it is not overheated.
Haven't tried the RE-01R. They cost 50% more but I can't imagine running around corners 50% faster than the MXs. For daily driving and aggressive weekend road driving the MXs are excellent. Some guys still auto-X with them. MXs are softer compound than most passenger tires. Get the WRX front end aligned to zero toe or the car will eat the MXs up. Last edited by yzer; 04-01-2008 at 11:07 AM. |
04-01-2008, 07:16 AM | #7 |
Hoodbridge!
Moderator Member#: 560
Vehicle:2006 STi, 16 Outback Crystal Gray, Silver |
If you're on a tight budget, I think they're a very good option for a grippy summer tire. I've heard they do fairly well at the track too. Don't have quite the grip on an Azenis 615, but also don't tend to go off as much when they get hot.
04-01-2008, 12:17 PM | #8 |
Member#: 14911
Vehicle:Not A Wagon! 2011 WRX - 285s on 18x9.5 |
For street use, the MX's are great. For occasional autoX and track, they're pretty good. For serious autoX, there's better choices (like the RE01R.)
04-01-2008, 07:00 PM | #9 |
Member#: 9339
TXIC
Vehicle:2005 Forester XT 80, 86, 87, and 88 RX-7 |
They are probably the best HPDE tire for the money as they handle the heat build up without becoming over greasy or chunking. I've had two sets and would order a third if I wasn't retiring the FXT from track work.
04-02-2008, 01:15 PM | #10 |
Member#: 144848
Vehicle:05 WRX, 17 M2 01 S2K, 16 Fozzy Turbo |
Going on my 3rd season with one set of MX's. Loudest performance tire I've ever experienced, but the performance and cost are well worth it. I'll get a new set soon. The MX's grip is more than the stock WRX brakes can handle.
As expected, they are slick as hockey pucks in cold season in Ohio. Last edited by AaronCompNetSys; 04-02-2008 at 01:21 PM. |
04-02-2008, 04:13 PM | #11 |
Member#: 89291
LOL! Yes, they are loud. Get 1/4 tread left and people on the sidewalk will turn around when they hear you coming down the street. MXs sound like off road tires when they wear down. Like you say, all of that performance is worth it. I like the tires a lot.
04-02-2008, 05:01 PM | #12 |
Member#: 87921
SCIC
Vehicle:09 TSX 6 speed WRX has been sold |
Ive had them for about 1000 miles running 245/40/17. For the price its a pretty good deal.
04-02-2008, 05:09 PM | #13 |
Member#: 141672
I ran a set of MX's on my last car which was a better handler then my WRX. I think the Kumho's needed stiffer sidewalls and had a narrower running temperature range then most tires in it's class.
04-04-2008, 09:00 AM | #14 |
Member#: 14911
The MX definately has a soft sidewall. When autoxing I had to run 48psi front on asphalt and 51psi on concrete to keep the sidewalls from rolling over. Better camber would have helped, but they need more pressure than other tires.
04-04-2008, 10:20 AM | #15 |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
I am on my second set of Kumho MX 245/40R17s, on the stock 17x8 BBS.
I like these tires. They are light, 4lbs lighter per tire than the OEM RE070. Good traction in a straight line and I could care less about corners. |
04-04-2008, 02:27 PM | #16 |
Member#: 89291
The MX "soft sidewall" issue has to be taken into perspective. The MX is lighter than most extreme performance tires. The sidewalls may not be as stiff as heavier tires and that may be a disadvantage for running around pylons on a tiny autoX course. However, the MXs have all of the sidewall strength and stiffness you need for aggressive road and HDPE (as Tanj! states) driving.
The lighter weight of the MX can be a huge advantage. It all depends what you want the tires to do for you and your car. Saving a couple of pounds per corner at the most important places like the wheel rim and tire can improve acceleration, top end speed, handling and fuel economy. Light weight and extreme performance is why I paired the MXs with lightweight SSR Competition rims. |
04-04-2008, 05:39 PM | #17 |
Member#: 86356
Vehicle:2018 Aprilia Tuono v4 1100 |
I hated my MXs in the rain, especially compared to the rs-2 I had before them.
04-01-2009, 09:25 PM | #18 |
Member#: 204304
Vehicle:2008 WRX 4D Stage 2 Silver |
What PSI are you running for these tires? I just updated my 205/50/17 stock tires to these in a 225/45/17. I am not sure for driving if I should have them at the stock PSI.
Thanks, |
04-01-2009, 09:45 PM | #19 |
Member#: 116220
NESIC
Vehicle:2007 WRX Limited |
I had these on my MKV GTI....awesome tire for the price. A little loud once its worn but I think I'll be getting my 2nd set for the WRX in the next week or two. If performance and value is what you want, this is definitely a tire to consider.
04-01-2009, 10:13 PM | #20 | |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
i found that 39-41psi was good make SURE your toe is '0' and these tires like a LOT of negative camber |
04-02-2009, 09:03 AM | #21 |
Member#: 144848
I have 225/45 18 and I run 45 and 42. I'm quite rough on them.
04-02-2009, 08:53 PM | #22 |
Member#: 167082
Vehicle:1997 Impreza L Acadia Green |
Why not get the new Ecsta XS for $1 cheaper?
04-14-2009, 04:48 PM | #23 |
Member#: 190273
SWIC
Vehicle:05 WRX evoIII-16G WRB |
04-14-2009, 07:43 PM | #24 |
Member#: 140163
04-14-2009, 08:20 PM | #25 |
Member#: 190273
SWIC
PA: 18 x 114.3 Prodrive PFF7 With Kuhmo Ecsta MX | gasnutz | Wheels/Tires | 26 | 08-29-2006 07:52 AM |
wtb: Kuhmo Ecsta Mx 225/40/18 single tire | WillWRX | Private 'Wanted' Classifieds | 0 | 06-25-2006 10:51 AM |
Fs: Kuhmo Ecsta Mx | trisk | Rocky Mountains Impreza Club Forum -- RMIC | 2 | 10-24-2005 08:34 AM |
kuhmo ecsta MX vs. falken azenis | lettucemanatee | Tire & Wheel | 10 | 07-30-2004 07:23 PM |
Thoughts on the Kuhmo Ecsta MX? | CAP | Tire & Wheel | 44 | 05-17-2003 11:21 PM |
