Welcome to the North American Subaru Impreza Owners Club Wednesday November 14, 2018
Old 12-29-2003, 09:48 PM   #1
ASpec818
Member#: 37059
03 WRX
World Rally Blue
Default wierd noise when letting off acceleration, sounds like tranny is grinding or somethin
is this normal? say i accelerate, then let go of gas, i can hear the transmission. it sounds like metal grinding against each other or something?
ASpec818 is offline   Reply With Quote
Old 12-29-2003, 09:53 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
That would be decelleration noise that is common with our tranny's. You can alleviate it by inflating your front tires more than your rear. I usually fill the front at 39psi and run the rears at 35psi. That will help the noise issue.
Calvin
cnk is offline   Reply With Quote
Old 12-29-2003, 10:21 PM   #3
20swrt
Member#: 50186
9804 WRX, RS25 coupe
WR Blue
39/35 Isn't that a bit too much? I thought the recommended is 32/30 for the WRX.
20swrt is offline   Reply With Quote
Old 12-29-2003, 10:23 PM   #4
cnk
Member#: 10757
The factory recommendation is 32/29 IIRC. . you can check on your driver's side door sill. I find this to be too low and prefer to run a higher PSI in my tires. This is after much trial and error. Keep in mind that I'm not on a stock suspension.
Calvin
noise when letting off the gas crxgator Transmission (AT/MT) & Driveline 2 06-28-2009 11:25 PM
shaking when letting off accelerator usenet4life Transmission (AT/MT) & Driveline 0 11-16-2008 09:39 PM
Metallic noise when letting off gas _JsWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 01-16-2007 02:20 PM
AC makes noise when turned off, sounds like BOV ILSMKU2 Service & Maintenance 1 07-03-2006 09:15 AM
Wierd noise when hitting hi rpm, kinda like a rattle? fedrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-14-2004 05:29 PM
