Welcome to the North American Subaru Impreza Owners Club Saturday January 16, 2021
Old 07-10-2017, 02:44 PM   #1
SacKing23
Member#: 78476
18 STI
Default Help. Brand new 18 STI – pulls to the right under acceleration
Hello! I just picked up my 18 STI yesterday. And I love it. Except one thing… The car seems to pull towards the right under acceleration. Doesn’t really matter the speed or road type. And it only happens while accelerating. The car/wheel will stay completely straight under braking or when cruising off the gas. But anytime the accelerator is applied, the car pulls to the right.
Please advise. Thanks in advance!
SacKing23 is offline   Reply With Quote
Old 07-10-2017, 02:48 PM   #2
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
you have a brand new car!! take it back to the dealership to fix it.
bmxhotsauce is offline   Reply With Quote
Old 07-10-2017, 03:13 PM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
After checking tire pressures.
Old 07-10-2017, 04:18 PM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Presuming this is still the same issue, ie; the factory hasn't changed anything:
Torque steer like this would occur due to the factory alignment settings. The Dealer will align to the Factory specs.
Once you verify your tire pressures are correct, you may want to find a reputable alignment shop in your area and have the alignment checked and reset.
Typical good alignment specs would be:
-1* camber
0* toe
maxout positive castor
Old 07-10-2017, 04:47 PM   #5
rtv900
Member#: 428511
2016 STI
mine pulls like hell when the tire pressure on a front wheel gets low, and it doesn't even need to be enough to trip the dash light.
But it pulls all the time, not just acceleration
rtv900 is offline   Reply With Quote
Old 07-10-2017, 05:30 PM   #6
SacKing23
Member#: 78476
18 STI
-1* camber
0* toe
Thanks for all the replies. Would the car not pull during coasting and breaking (vs only when accelerating), if it was a pressure or alignment issue?
Old 07-10-2017, 11:00 PM   #7
Samurai Jack
Member#: 21145
2002 Enemy of Aku
It generally would not pull during coasting but remember that, depending on where you live, most roads are crowned so it could pull either way depending on which side of the road you are on.
Presuming nothing was wrong with the brakes, then it should not pull under braking
Old 08-09-2017, 03:08 PM   #8
rtv900
Member#: 428511
2016 STI
I doubt it.
I know mine pulls 100% of the time if there's a pressure issue.
I just had it for 10 days in a row from a leaky stem so every day the light would come on when I left work, but it would pull non stop.
If yours is just under acceleration it's probably something else.
Old 08-09-2017, 03:24 PM   #9
JJay03
Member#: 279061
2018 WRX STI
Lapis Blue
Mine pulled only under light acceleration with low pressure in one of the front tires. Is was not really that low though maybe 8-10lbs or so and did not trigger the tpms light.
JJay03 is offline   Reply With Quote
Old 08-10-2017, 12:32 PM   #10
BeantownWRX18
Member#: 468095
2018 STI
CWP
You're not alone. My 18' STI was one of the early ones to hit New England and I have this same problem. Checked tire pressure and it's all good. Taking it back to dealer
BeantownWRX18 is offline   Reply With Quote
Old 07-10-2017, 06:12 PM   #11
MedicDG
Member#: 329822
2016 STi
Yes check tire pressure for sure! I run 38psi cold in all wheels.
But it's not tire pressure sounds like a alignment problem. Consider a good alignment shop that can make sure your camber is equal side to side and zero toe in all wheels.
MedicDG is offline   Reply With Quote
Old 07-10-2017, 08:27 PM   #12
PERRIN_Thomas
Member#: 423601
2016 WRX
LBP
If the Tire pressure is good, then the belts in the a tire are bad and you need a new tire.
One way to test this is to rotate the tire to the back to see if it goes away,
PERRIN_Thomas is offline   Reply With Quote
Old 08-09-2017, 09:38 AM   #13
JJay03
Member#: 279061
2018 WRX STI
Lapis Blue
Mine did this when the tire pressure was off even after the dealer assured me they checked it. If thats not it then your tires are probably bad. Someone on youtube with an 18 STI had their tires replaced for this issue.
Old 08-09-2017, 02:51 PM   #14
Sarcoughaguy
Member#: 472039
2018 STi Limited
LBP
Yep, there are a set of defective tires going around on the early models. You'll know if you move the tire and the problem moves with it. They can check the serial # and determine if it was made in week 13 I think?
Sarcoughaguy is offline   Reply With Quote
Old 08-10-2017, 11:03 PM   #15
sterling8080
Member#: 410838
Might be week 13 production tires. If so, your dealer will replace them.
sterling8080 is offline   Reply With Quote
Old 08-10-2017, 11:57 PM   #16
wrx43v3r
Member#: 331119
Lift more weights with your left arm only - this will even it out.
wrx43v3r is offline   Reply With Quote
Old 08-11-2017, 12:24 AM   #17
Marvick08GT
Member#: 469091
I'm dying!
Marvick08GT is offline   Reply With Quote
Old 11-13-2017, 07:33 PM   #18
Prowizard
Member#: 394682
Angry pulling
Just picked up my 2018 sti and mine is pulling to the left only when accelerating not flooring it just cruising but on the throttle. as soon as i just coast down a hill though it is straight as an arrow. i went to the dealer they did an alignment but it is still happening. Frustrated
Prowizard is offline   Reply With Quote
Old 11-14-2017, 10:06 AM   #19
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Then take it back and tell them they didn't fix the problem.
That's what any reasonable person would with any shop.
Tell them to keep the car until they fix it properly and to give you a free loaner. After all, it's under a new car warranty.
Old 11-17-2017, 09:11 AM   #20
rtv900
Member#: 428511
2016 STI
is anything different suspension wise on the 18's?
That must be it because my 16 tracks dead nuts.
They were using Dunlop I believe for the stock tires in 16. Sportmaxxx I think they are.
Old 11-26-2017, 05:35 AM   #21
enigma94
Member#: 143254
2007 STi
UGM
I just purchased a 18 STi as well and am having the exact same issue where the car pulls pretty hard to the right under acceleration. So much so where the car feels unpredictable and unstable in turns if you let off the gas.
The odd thing is I test drove another car a couple weeks back at a different dealership and it did the exact same thing! Thinking it was related to that specific car only I didn't even test drive mine before purchasing it...
Has this been confirmed to be the tires??? Going to have to call the dealer Monday and see what they say...
enigma94 is offline   Reply With Quote
Old 11-29-2017, 04:10 PM   #22
some dude
Member#: 100300
06 WRX
Would too much gear backlash in one of the wheels cause any pulling symptoms?
Old 12-01-2017, 08:10 AM   #23
SnowmanCT
Member#: 330110
2017 STI Limited lip
LBP
They should be checking for anything loose in the front suspension (ball joints, endlinks, etc.)... and if it moved when they swapped wheels - it could be a wheel (sounds like they only replaced the tires).
SnowmanCT is offline   Reply With Quote
Old 12-06-2017, 02:40 PM   #24
zzpatzz
Member#: 477772
+1 I would take it back to the dealership, but I always hate taking my car to the dealership...
zzpatzz is offline   Reply With Quote
Old 12-14-2017, 10:03 AM   #25
Obviously Tyler
Member#: 395955
2021 Mazda 3 Turbo
1999 NB Miata
I don't know why Subaru still bothers with the Yokohamas. Nearly everyone takes them off and goes with different tires or to all seasons. Mazda loves the Yokos too, and they're just as bad on them.
If they want to keep up with the competition they should just slap pilot super sports on at least the STi.
Obviously Tyler is offline   Reply With Quote
