#1 |
Member#: 349565
![]() Hey guys. I have a 2014 Sti that is basically stock.
I’m having a loud squealing and hissing noise whenever my car goes to boost (3k rpms). Sounds like a loud pig! Noise sounds like is coming from passenger side. I checked for boost and vacuum leaks and replaced the following: Intercooler couplers Turbo inlet hose All clamps Car acts normal when idling; only weird under boost. Any idea what’s going on? Could an up pipe be causing problems? Problems started after I test fitted a cold air intake, took it for a drive, and put the stock back on (I know, it needed a tune). |
#2 |
Member#: 378873
MWSOC
Vehicle:2012 WRX Sedan Ice Silver Metallic |
![]() Did you check the intercooler to throttle body coupler? Its know to slide off or crack.
Check the turbo inlet where it meets the turbo. It can also crack or fall off. |
#3 |
Member#: 349565
![]() Yes I changed them both
#4 |
Member#: 400179
Vehicle:2009 wrx |
![]() sounds like a boost leak test might be in order. it only takes 2 or 3 psi usually to find leaks. checking by eye is a good first thing to try, but there are so many places that boost leaks can hide - but they usually can't hide from a boost leak test. while testing listen for the same noise, sometimes you can feel air blowing out from a leak, or sometimes spraying soapy water on everything will cause bubbles at the leak.
#5 |
Member#: 349565
![]() Do I need to block off the vacuum lines and open the engine oil cap before I do a smoke test? I’m getting different answers from different people
#6 |
Member#: 400179
Vehicle:2009 wrx |
![]() yeah, lots of different ways to do it. personally i just go for the very low (2 or 3 psi) test, remove oil cap, then remove the large hose from the air cleaner housing and use something cobbled together to get air into that. then listen and feel for leaks, and spray soapy water if necessary on everything that could be a leak.
with that low pressure test, i don't find it necessary to block off any vac lines etc. |
#7 | |
Member#: 519457
BAIC
![]() Quote:
also when doing a smoke tes, do you need to block off vacuum lines?? i need to know as well lol |
#8 |
Member#: 487
TXIC
Vehicle:1998 /2005 STunIcorn Acadia Green RS-T |
![]() Lots of people would say this harms rubber hoses etc
But I would spray either carb/brake cleaner around engine bay With car idling.......if you have dip/rise in RPM.....there is your leak man (If u use non-chlorinated BC, RPM will dip down) |
