#1 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
![]() Killer B Motorsport - High Flow Water Pump Inlet
• 3D CAD Designed & Simulation Tested • Made from Heat Treated Cast Aluminum • Smooth Taper Inlet for Turbulence Free Flow • Bead Assures Proper Hose Connection • Large Smooth Bend Transitions into the Housing with Maximum even Flow distribution. • Machined Flange for a Leak Free Install • Designed and Made in the USA In typical fashion, we just can't leave things alone. We've been making a high flow water pump inlet for years that have been geared towards the higher end track guys. We've change manufacturing technologies, tweaked the design some, and will be providing a High Performance Water Pump Inlet at a more reasonable price: $99. Presenting, the Killer B Motorsport V2 high Performance Water pump Inlet. ![]() Last edited by KillerBMotorsport; 11-15-2020 at 12:20 PM. |
#2 |
Member#: 261040
Vehicle:04 STi PSM |
![]() Bravo for another great product!
#3 |
Member#: 193940
Vehicle:2004 WRX STI Black RalliSpec Shortblock |
![]() Pics?
#5 |
Member#: 469585
W. Canada
Vehicle:2009 STi White |
![]() Funny enough I just ordered one along with a filler neck relocation and upper coolant reservoir yesterday. ***128077;
#6 |
Member#: 198281
#7 |
Member#: 198281
![]() Have had a couple questions about the factory hose fitment. It's super easy. Reverse the hose and trim 1/2 from each side and it fits perfect.
#8 |
Member#: 261040
![]() Are these available yet
PM me price shipped to 44149 ! Thx! |
#9 |
Member#: 508105
Vehicle:2002 WRX Wagon VF39 Midnight Black Pearl |
#10 |
Member#: 395793
AKIC
Vehicle:2005 92x Aero Beige |
![]() Going to be switching to either a Koyo or CSF rad in the spring. Would you recommend one of these for a 207 while I'm in there? Any other cooling system mods you recommend? Already have cyl 4 mod. Currently have 20g xtr and am planning on going EWG, and flex fuel in the spring. Will be doing track days and some auto-x.
#11 | ||
Member#: 198281
![]() Quote:
#12 | |
Member#: 395793
AKIC
![]() Quote:
Auto-x is not a focus and no intent on being competitive. I use it a few times a year for training and keeping my reflexes good. I have fun with it but no interest on being competitive. Mostly HPDE and track days working toward time attack style events. I do spend time in UT and may do some track days there but it would be in May, September and October. I will be making a custom belly pan and splitter in the spring. Already have a radiator shroud. I use a TMIC so no FMIC blocking flow. I'm using OEM fans and will be keeping them. I was more thinking how you stated this pump housing is designed for higher rpm. Where do you find the OEM housing starts to suffer from turbulence? |
#13 |
Member#: 198281
![]() Smart move. OEM fans are as good as it gets unless you're going to spend +$600 for a fan.
+6,500 RPMs and worse above 7,500. Sustained high PRM is where this product shines. |
#14 |
Member#: 395793
AKIC
