Welcome to the North American Subaru Impreza Owners Club Saturday January 16, 2021
Old 07-10-2017, 02:44 PM   #1
SacKing23
Member#: 78476
18 STI
Default Help. Brand new 18 STI – pulls to the right under acceleration
Hello! I just picked up my 18 STI yesterday. And I love it. Except one thing… The car seems to pull towards the right under acceleration. Doesn’t really matter the speed or road type. And it only happens while accelerating. The car/wheel will stay completely straight under braking or when cruising off the gas. But anytime the accelerator is applied, the car pulls to the right.
Please advise. Thanks in advance!
SacKing23 is offline   Reply With Quote
Old 07-10-2017, 02:48 PM   #2
bmxhotsauce
Member#: 127099
02 IMPERZA WRX
BLACK
you have a brand new car!! take it back to the dealership to fix it.
bmxhotsauce is offline   Reply With Quote
Old 07-10-2017, 03:13 PM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
After checking tire pressures.
Old 07-10-2017, 04:18 PM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Presuming this is still the same issue, ie; the factory hasn't changed anything:
Torque steer like this would occur due to the factory alignment settings. The Dealer will align to the Factory specs.
Once you verify your tire pressures are correct, you may want to find a reputable alignment shop in your area and have the alignment checked and reset.
Typical good alignment specs would be:
-1* camber
0* toe
maxout positive castor
Samurai Jack is offline   Reply With Quote
Old 07-10-2017, 04:47 PM   #5
rtv900
Member#: 428511
2016 STI
mine pulls like hell when the tire pressure on a front wheel gets low, and it doesn't even need to be enough to trip the dash light.
But it pulls all the time, not just acceleration
rtv900 is offline   Reply With Quote
Old 07-10-2017, 05:30 PM   #6
SacKing23
Member#: 78476
18 STI
-1* camber
0* toe
Thanks for all the replies. Would the car not pull during coasting and breaking (vs only when accelerating), if it was a pressure or alignment issue?
Old 07-10-2017, 06:12 PM   #7
MedicDG
Member#: 329822
2016 STi
Yes check tire pressure for sure! I run 38psi cold in all wheels.
But it's not tire pressure sounds like a alignment problem. Consider a good alignment shop that can make sure your camber is equal side to side and zero toe in all wheels.
MedicDG is offline   Reply With Quote
Old 07-10-2017, 08:27 PM   #8
PERRIN_Thomas
Member#: 423601
2016 WRX
LBP
If the Tire pressure is good, then the belts in the a tire are bad and you need a new tire.
One way to test this is to rotate the tire to the back to see if it goes away,
PERRIN_Thomas is offline   Reply With Quote
Old 07-10-2017, 11:00 PM   #9
Samurai Jack
Member#: 21145
2002 Enemy of Aku
It generally would not pull during coasting but remember that, depending on where you live, most roads are crowned so it could pull either way depending on which side of the road you are on.
Presuming nothing was wrong with the brakes, then it should not pull under braking
Old 08-09-2017, 09:38 AM   #10
JJay03
Member#: 279061
2018 WRX STI
Lapis Blue
Mine did this when the tire pressure was off even after the dealer assured me they checked it. If thats not it then your tires are probably bad. Someone on youtube with an 18 STI had their tires replaced for this issue.
JJay03 is offline   Reply With Quote
Old 08-09-2017, 02:51 PM   #11
Sarcoughaguy
Member#: 472039
2018 STi Limited
LBP
Yep, there are a set of defective tires going around on the early models. You'll know if you move the tire and the problem moves with it. They can check the serial # and determine if it was made in week 13 I think?
Sarcoughaguy is offline   Reply With Quote
Old 08-09-2017, 03:08 PM   #12
rtv900
Member#: 428511
2016 STI
I doubt it.
I know mine pulls 100% of the time if there's a pressure issue.
I just had it for 10 days in a row from a leaky stem so every day the light would come on when I left work, but it would pull non stop.
If yours is just under acceleration it's probably something else.
Old 08-09-2017, 03:24 PM   #13
JJay03
Member#: 279061
2018 WRX STI
Lapis Blue
Mine pulled only under light acceleration with low pressure in one of the front tires. Is was not really that low though maybe 8-10lbs or so and did not trigger the tpms light.
Old 08-10-2017, 12:32 PM   #14
BeantownWRX18
Member#: 468095
2018 STI
CWP
You're not alone. My 18' STI was one of the early ones to hit New England and I have this same problem. Checked tire pressure and it's all good. Taking it back to dealer
BeantownWRX18 is offline   Reply With Quote
Old 08-10-2017, 11:03 PM   #15
sterling8080
Member#: 410838
Might be week 13 production tires. If so, your dealer will replace them.
sterling8080 is offline   Reply With Quote
Old 08-10-2017, 11:57 PM   #16
wrx43v3r
Member#: 331119
Lift more weights with your left arm only - this will even it out.
wrx43v3r is offline   Reply With Quote
Old 08-11-2017, 12:24 AM   #17
Marvick08GT
Member#: 469091
I'm dying!
Marvick08GT is offline   Reply With Quote
Old 11-13-2017, 07:33 PM   #18
Prowizard
Member#: 394682
Angry pulling
Just picked up my 2018 sti and mine is pulling to the left only when accelerating not flooring it just cruising but on the throttle. as soon as i just coast down a hill though it is straight as an arrow. i went to the dealer they did an alignment but it is still happening. Frustrated
Prowizard is offline   Reply With Quote
Old 11-14-2017, 10:06 AM   #19
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Then take it back and tell them they didn't fix the problem.
That's what any reasonable person would with any shop.
Tell them to keep the car until they fix it properly and to give you a free loaner. After all, it's under a new car warranty.
Old 11-17-2017, 07:56 AM   #20
IanManger
Member#: 474147
2018 WRX STi
Default Same issue
I picked up my 2018 STi in early October and had the same issue. This will be long, but I want to share my full experience in detail to hopefully save other people time and energy of making multiple trips to the dealership. My car pulls to the left when under even the slightest bit of acceleration. Driving on the interstate I also notice the steering wheel is off center. I am turning the wheel about 5-10 degrees to the right to keep the car driving straight. I am sure some of this is caused by the crowing of the road, but I am always having to pull the steering wheel to the right. I can never just relax my arms and cruise on the high way I have to always be "driving" the car.
Took the car to the dealership 4 times.
1st visit to dealership - they double checked the alignment and it was out slightly but not a lot. The issue was still present.
2nd visit to dealership - This time the service manager went on a test drive with me. He also verified that he felt the issue (now I know I was not being paranoid). They swapped the two front wheels. The issue was still there but reversed this time. This means that the issue should be in the tire. They ordered two brand new yokohamas.
3rd visit to dealership - Replaced the two tires with the new ones they ordered. The issue is still there pulling right still. They ordered another two Yokohamas to replace all four tires now.
4th visit to dealership - Replaced rear two tires with new. The car now has all new tires. The issue has moved back to the left and feels almost exactly the way it did in the beginning.
The dealership has told me they don't know what else could be causing the issue and they have done everything that they can under warranty to address the issue. I don't know if this is just the nature of the car or if these Yokohama tires are just complete crap. When I buy a 40k high performance car, I expect it to have precise steering. I am planning to buy some winter wheels and tires here soon and I will then see how the car drives after that. If this fixes the issue then I know that these tires are junk.
That is my experience and I hope this helps anyone who is also having this issue. I love everything else about the car and am still very happy with my purchase, I just wish I didn't have to make so many trips to the dealership after buying a brand new car.
IanManger is offline   Reply With Quote
Old 11-17-2017, 09:11 AM   #21
rtv900
Member#: 428511
2016 STI
is anything different suspension wise on the 18's?
That must be it because my 16 tracks dead nuts.
They were using Dunlop I believe for the stock tires in 16. Sportmaxxx I think they are.
Old 11-17-2017, 11:23 AM   #22
Cliff000
Member#: 477868
Thanks for sharing!
Here is my current situation.
I am currently dealing with the same issues. I have 1k miles on it. It was pulling to the left, off centered steering wheel, pulled while accelerating, and had to hold the wheel to correct the pull the entire time so i took it in. They had the car for 3 weeks. I picked it up on the 16th of nov. The alignment was off and they found a bent rear upper control arm from factory. After that, it still pulled. They did road force testing and found the left front tire to be bad. They replaced it and said it was all fixed. As soon as i left i could feel it on the RH side this time. It now pulls heavily right when accelerating but stays completely straight when braking or coasting. But I have noticed if I set the diff to manual rear the pull is less noticeable but still present. Tire pressure is set to the recommended psi as well. I made an appointment for the 21st to get it inspected at another dealership. I am thinking the ****y tires are to blame? I'll be sure to post back when ever they figure it out! I am also going to try winter tires as well!
Cliff000 is offline   Reply With Quote
Old 11-17-2017, 02:45 PM   #23
Norskie
Member#: 454461
2nd visit to dealership - ... They swapped the two front wheels. The issue was still there but reversed this time. This means that the issue should be in the tire. They ordered two brand new yokohamas.
At this point I would suspect a problem with the wheel.
Think of it as the "Audi Experience" at a lower price ....
Norskie is offline   Reply With Quote
Old 11-26-2017, 05:35 AM   #24
enigma94
Member#: 143254
2007 STi
UGM
I just purchased a 18 STi as well and am having the exact same issue where the car pulls pretty hard to the right under acceleration. So much so where the car feels unpredictable and unstable in turns if you let off the gas.
The odd thing is I test drove another car a couple weeks back at a different dealership and it did the exact same thing! Thinking it was related to that specific car only I didn't even test drive mine before purchasing it...
Has this been confirmed to be the tires??? Going to have to call the dealer Monday and see what they say...
enigma94 is offline   Reply With Quote
Old 11-29-2017, 04:10 PM   #25
some dude
Member#: 100300
06 WRX
CGM
Would too much gear backlash in one of the wheels cause any pulling symptoms?
some dude is offline   Reply With Quote
