Welcome to the North American Subaru Impreza Owners Club Tuesday February 20, 2018
Mid Atlantic Impreza Club
Old 05-18-2013, 06:40 PM   #501
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Originally Posted by acumenhokie View Post
Dropped my car off to get a new snail installed.
What did you go with?
Louie is offline   Reply With Quote
Old 05-18-2013, 08:35 PM   #502
acumenhokie
Member#: 271479
2010 LGT
2009 FXT
BNR 20G TD05
also doing ic, fuel pump, injectors, aos, ebcs, bpv, etc. etc.
acumenhokie is offline   Reply With Quote
Old 05-18-2013, 11:13 PM   #503
GoRabbit
Member#: 251854
2013 WRX
Dropping my car off to have the clear bra installed by Auto Armor Columbia
GoRabbit is offline   Reply With Quote
Old 05-18-2013, 11:19 PM   #504
prashanth
Member#: 123534
2004 Forester XT
Gold
Refinished old Volk Racing center caps and installed them on the car
prashanth is offline   Reply With Quote
Old 05-19-2013, 08:41 PM   #505
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
Cleaned up the interior quite a bit.
bluemax189 is offline   Reply With Quote
Old 05-19-2013, 10:35 PM   #506
HinshawWRX
Medium Frank
Member#: 140114
2013 Audi
A6 3.0T
Wash, wax, oil change. (Essentially)
Old 05-19-2013, 11:23 PM   #507
needasubie10
Member#: 234907
2002 wrx wagon
mbp
Installed my front mount
needasubie10 is offline   Reply With Quote
Old 05-20-2013, 01:02 AM   #508
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Finished installing the Koni Yellows with RCE Yellow springs. Also installed rear SPC arms. Andrewtech alignment tomorrow. They can **** with the camber bolts because I'm not.
OrbitalEllipses is offline   Reply With Quote
Old 05-20-2013, 01:15 AM   #509
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
Wired in the serial cable to be able to log AFR on my AEM wideband! I think my tune can definitely be leaned out a little bit.
ResidentR is offline   Reply With Quote
Old 05-20-2013, 02:35 PM   #510
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
Looked at my suspension.
98% sure I have a front strut leaking.
WTF!!?
RavensFan7 is offline   Reply With Quote
Old 05-20-2013, 04:04 PM   #511
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
Cleaned up some more of the car. It was calling for rain so i didnt wash the bidy of the car and of course it doesnt rain.
Old 05-20-2013, 04:10 PM   #512
butterflyx3
Member#: 293345
2005 Forester
RBP
Rolling the fenders on my car ^_^
butterflyx3 is offline   Reply With Quote
Old 05-20-2013, 07:05 PM   #513
yuephoria
Member#: 64624
2008 FS XT
WR Blue Pearl
Washed it over the weekend, but dressed the exterior trim and tires with Adam's Super VRT today. I also dusted and applied 303 Protectant to the interior.
yuephoria is offline   Reply With Quote
Old 05-20-2013, 07:34 PM   #514
GoRabbit
Member#: 251854
2013 WRX
Clear bra installed couldn't be happier with the outcome.
Old 05-20-2013, 10:32 PM   #515
needasubie10
Member#: 234907
2002 wrx wagon
mbp
installed an 04 sti steering wheel on my 02 wagon
Old 05-21-2013, 11:42 AM   #516
RavensFan7
Member#: 346388
SRP
Checked oil
Added some brake fluid
Diagnosed a headlight issue.
Low beam doesn't work on the drivers side. Voltage at the pins on the plug are correct, and I swapped the passenger bulb which worked fine.
So its the drivers side bulb. Why only the low beam filament died, I have no clue.
Old 05-21-2013, 11:47 AM   #517
Ahh Vtec
Member#: 172456
2011 WRX Hatch
Installed spark plugs last night and encountered a coil pack bolt that had become cross-threaded on the very last plug. It was a very hair-raising experience removing said bolt, but a tap and die later it's all good (fingers crossed).
Ahh Vtec is offline   Reply With Quote
Old 05-21-2013, 03:16 PM   #518
SlverEJ20
Member#: 157158
05 WRX stage 2
Originally Posted by RavensFan7 View Post
Checked oil
since low beams are used more often then the high beams, they usually burn out quicker
SlverEJ20 is offline   Reply With Quote
Old 05-21-2013, 03:53 PM   #519
prescottn6ft7
Member#: 268918
2007 WRX STi
Obsidian Black Pearl
^ That and, it's very common to burn out just one filament... if both burn out then you've probably got a more serious issue than just the bulb.
prescottn6ft7 is offline   Reply With Quote
Old 05-21-2013, 06:51 PM   #520
RexNoob
Member#: 311659
2004 WRX
Java Black Pearl
Painted my stock 16s with vht gold... Now it's pouring rain :/ hope it doesn't mess them up
RexNoob is offline   Reply With Quote
Old 05-21-2013, 07:21 PM   #521
RavensFan7
Member#: 346388
SRP
Oh, good to know.
I rewired both headlight plugs a couple months ago, and I almost died when I saw I had a low beam light out. Good thing it's just the bulb, cause there's not much factory wire left to rewire again
Old 05-21-2013, 07:37 PM   #522
Uncle Tattoo
Member#: 139542
2007 Civic Sedan
Daily driver status son
Looks great!
Uncle Tattoo is offline   Reply With Quote
Old 05-21-2013, 07:47 PM   #523
RexNoob
Member#: 311659
2004 WRX
Java Black Pearl
Originally Posted by Uncle Tattoo View Post
Looks great!
Heck of a lot better than they did that's for sure, I just did a quick job though needs more coats. I had to hurry before it dumped rain on me. Now I need to get these wheel spacers to fit :P
Old 05-22-2013, 09:07 AM   #524
lilblue619
Member#: 288292
2004 sti
wrb. the blue one.
Painted my last two torque's yesterday. No rain tho
lilblue619 is offline   Reply With Quote
Old 05-22-2013, 10:23 AM   #525
prescottn6ft7
Member#: 268918
2007 WRX STi
Looks great!
I second this! Looks really clean!
