07-30-2014, 10:26 AM | #4501 | |
Member#: 79643
NESIC
Vehicle:2021 STI TE Terminal black pearl |
07-30-2014, 10:26 AM | #4502 | |
Member#: 219492
Vehicle:17' 5mt XV & 02 WRX @comrad |
07-30-2014, 11:10 AM | #4503 | |
Member#: 9017
Vehicle:2011 WRX 5dr 405whp 385wtq |
07-30-2014, 05:20 PM | #4504 |
Member#: 219492
pretty sure my interior is 100% one off.
custom relocated push start/heated seats. Australian black rim/buttons. Red stitched/alcantara cluster hood-ebrake boot-center vent JDM toyota armrest Genuine alcantara wrapped center console with custom din-pocket molded in Genuine alcantara vent rings Perforated alcantara door cards GT2-RS pull strap door conversion. JDM STi push start button with chrome trim painted gloss black. Leather door speakergrills/knee pads all of the alcantara work was don't by jason at Overland Designs (overland04 on nasioc), the fabbing/relocating/pullstraps were all done by me. this is what i finished up today: interior: Button: Before/After i'm leaning towards some sort of shade of black, but honestly i don't know for sure, but the copper has to go. |
07-30-2014, 05:23 PM | #4505 |
Member#: 219492
and this is what the interior looks like OEM bone stock for comparison.
07-30-2014, 05:27 PM | #4506 |
Member#: 387569
NWIC
Vehicle:1968 Abomination |
07-30-2014, 08:10 PM | #4507 |
Member#: 261307
South East
Vehicle:04 wrx wagon WRB |
Very nicely done Jive.
Sent from my iPhone using NASIOC |
07-30-2014, 09:37 PM | #4508 |
Member#: 331281
SCIC
Vehicle:car car |
carbon is life
I stripped the wing down to the fiberglass. Took two hours and caused a dust storm in the midwest. I wrapped it in one layer of the fabric and pushed all the excess resin out. it still wasn't flat, so after some aggressive sanding, it was flat and strong but ugly. butt ugly. so I did another layer. Paying a lot more attention to detail this time with two other people instead of only one other. I slathered it in two more coats of epoxy. Then came the wet sanding. My arms are now twice the size. Next was the prime base and clear coat of the underside trailing section of the airfoil. After a great internal struggle, I needed it to look rally, but show off the carbon. because racecar. So i painted what you see from the rear blue, and what you see from the rest of space i left carbon. Then it came for the clear. I used the 2k clear in a can, the type you mix the hardener in the bottom and shake it up. Worth the extra money. I let it dry and mounted it back on the car. Not too shabby right? Now comes a nice wet sand to cut the clear down, a polish a wax and a pat on the back. |
07-30-2014, 11:04 PM | #4509 |
Member#: 362529
Show us your Unique (custom) modifications, Part 2
07-30-2014, 11:18 PM | #4510 |
Member#: 180748
VIC
Vehicle:2013 Scion FRS Whiteout |
Because most people don't have a friend who works at a trophy store?
07-30-2014, 11:29 PM | #4511 | |
Member#: 362529
This is true, I did have the resources to do this in less than 5 mins, but Id rather leave it stock because could never justify 55$ for a piece of metal that says Cobb or grimmspeed or wrx. I believe there are many ways to get around the expense without a trophy shop friend lol. Sent from my iPhone using NASIOC |
07-31-2014, 08:10 AM | #4512 |
Member#: 119292
South East
Vehicle:2003 WRX Sonic Yellow |
07-31-2014, 12:25 PM | #4513 | |
Member#: 328635
NWIC
Vehicle:2004 STi GTX3076R Rally Blue |
07-31-2014, 12:51 PM | #4514 |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
07-31-2014, 02:02 PM | #4515 |
Member#: 219492
deleted the door lever. made a block off plate and wrapped in perforated alcantara. got GT2 straps. got Go-kart brake cables. dremel. beer. attach cable-rod-strap. test. beer. dremel. test. dynamat. beer. test. tighten cables. done.
in that order |
07-31-2014, 02:11 PM | #4516 | |
Member#: 292709
NWIC
Vehicle:2006 WRX Wagon World Rally Blue |
07-31-2014, 02:13 PM | #4517 |
Member#: 146287
BAIC
You lost me at Go-kart brake cables
And then again at cable-rod-strap And again at done. Do you still have a spring return? Did you completely remove the original pull handle and it's spring? |
07-31-2014, 02:24 PM | #4518 |
Member#: 306301
Vehicle:05 wrx white |
07-31-2014, 07:24 PM | #4519 |
Member#: 362529
08-01-2014, 10:26 AM | #4520 |
Member#: 219492
08-01-2014, 02:38 PM | #4521 |
Member#: 336252
Vehicle:2006 impreza wrx sti aspen white |
08-01-2014, 08:54 PM | #4522 |
Member#: 231904
RMIC
Vehicle:2007 WRX UGM |
So two weeks ago i got my 07 wrx tuned on E85 with all supporting mods and thought this new little custom/unique mod would be fun.
Started off with my stock fuel cap popped the ring off around the white threaded part and the part that attaches to the door then went on ebay and found the cheapest random E85 fuel cap and thought to myself they should all be the same. sure enough did the exact same steps as i did with the stock cap and it worked perfect. the cap was for a ford van off ebay. you can say what you want on it not being unique/custom but i think it is and cool. also sorry for the crappy pics from my phone |
08-02-2014, 01:30 AM | #4523 |
Member#: 276382
NWIC
Vehicle:2005 SaaBeeru OBP |
Simple but smart mod, can't believe how many diesel cars got filled with gas when I was selling cars :facepalm:
08-02-2014, 03:10 AM | #4524 |
Member#: 377832
Vehicle:2002 WRX MBP |
08-20-2014, 07:13 PM | #4525 |
Member#: 395546
NESIC
Vehicle:2002 WRX Blue Pearl |
Re: galaxy headliner
This is how my galaxy headliner turned out
http://i39.servimg.com/u/f39/18/97/00/28/img_2812.jpg http://i39.servimg.com/u/f39/18/97/00/28/img_6610.jpg |
Show us your unique modifications | lancewr1 | Interior & Exterior Modification | 7214 | 01-10-2012 12:09 PM |
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods | bluerex79 | Member's Car Gallery | 6 | 05-02-2011 09:02 PM |
Calling all Graphix......Show Us Your Stuff... | grnlantern1 | Member's Car Gallery | 37 | 07-16-2002 01:25 AM |
show us your wrx gauge installs. | lstepnio | Member's Car Gallery | 51 | 05-22-2002 03:43 AM |
Show us your T's (OZ Super T's that is) | Who flung dung | General Forum Archive | 11 | 02-12-2001 07:46 PM |
