Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2020
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Old 08-25-2019, 05:45 PM   #1
GK1707
Member Sales Rating: (1)
Member#: 373868
2004 STi
News NYC: Garage Clean Out 02-07 WRX STi Performance & OEM Parts
I have a bunch of parts for sale located in Queens NYC for local pickup. All parts are from an 04 STi with low mileage. Pics are below.
- Deatschwerks 850cc Side feed injectors - $SOLD
- OEM VF39 Turbo - SOLD
- Steamspeed STX67 Turbo with Turbosmart IWG75 Wastegate - $450
- OEM STi Side Feed Yellow Injectors - $SOLDD
- OEM STi 6 speed shifter - $80
- OEM STi Radiator - $80
- APS 70mm Cold Air intake - $180
- Kinugawa turbo feed oil line - $30
- OEM turbo feed hard line
- OEM STi Lamco Boost gauge & Pod
- 3 port catch can with lines - SOLD
- 2 used Power steering pumps $60 & $40
- Coilover springs - $120
- OEM Side feed TGVs - SOLD
- (2) 4th Cylinder cooling water outlet for 4th cylinder cooling mod - SOLD
- OEM pitch stop mount - $20
- Benen rear tow hook - $SOLD
- TurboXS RFL BOV - $120
- OEM STi Up pipe - $100
- OEM STi Front left axle - $60
Scroll down for pics and description.
- [b]Deatschwerks 850cc Side feed injectors - SOLD
PM me if interested. All parts are located in Queens NYC for local pickup
GK1707 is offline   Reply With Quote
Old 08-25-2019, 05:46 PM   #2
GK1707
Member#: 373868
2004 STi
- Steamspeed STX67 Turbo with Turbosmart IWG75 Wastegate - $450 - No shaft play and is in perfect condition, may need a rebuild as it has wisps of coolant smoking from it
https://i.imgur.com/FMUTd6T.jpg
https://i.imgur.com/VJqoVaL.jpg
https://i.imgur.com/fMODgES.jpg
https://i.imgur.com/9vtZQw1.jpg
-[b] OEM STi Side Feed Yellow Injectors - SOLD
- OEM STi 6 speed shifter - $80 - Perfect condition
https://i.imgur.com/p56Rjjd.jpg
https://i.imgur.com/7TDwN4w.jpg
- OEM STi Radiator - $80 - Perfect condition, will include upper and lower hoses
https://i.imgur.com/Rzf1QP4.jpg
https://i.imgur.com/JKicsMS.jpg
Old 08-25-2019, 05:47 PM   #3
GK1707
Member#: 373868
2004 STi
- APS 70mm Cold Air intake - $180 - Perfect condition, powdercoated gold
https://i.imgur.com/LgoTUpy.jpg
https://i.imgur.com/ultq0MD.jpg
- Kinugawa turbo feed line - $30 - The line is brand new, the restrictor/fitting is for ball bearing turbos, but will work with the OEM turbo as well.
https://i.imgur.com/PNp0b9S.jpg
https://i.imgur.com/O0Zt0MU.jpg
- OEM turbo feed hard line - $20 - Perfect condition
https://i.imgur.com/YXwkf1I.jpg
- OEM STi Lamco Boost gauge & Pod - $50 - Perfect condition
https://i.imgur.com/jHVNTwf.jpg
https://i.imgur.com/5wxKhSE.jpg
Old 08-25-2019, 05:47 PM   #4
GK1707
Member#: 373868
2004 STi
- 2 used Power steering pumps - $60 for the OEM and $40 for the reman - both of them need to be rebuilt, they both leak (note they will not come with pulley or brackets pictured
https://i.imgur.com/Ty4s91k.jpg
https://i.imgur.com/Jpjjpvt.jpg
- Coilover springs - $120 - Perfect condition but dirty. They are 8KG front and 6KG rear. 220mm rear and 200mm front. They will fit almost any brand of coilovers (Tein, BC, Koni, D2, Fortune)
https://i.imgur.com/p3h5Z4C.jpg
https://i.imgur.com/Uvn7Lj1.jpg
https://i.imgur.com/eFdAmDq.jpg
- OEM pitch stop mount - $20 - Perfect condition
https://i.imgur.com/xhrePVY.jpg
Old 08-25-2019, 05:48 PM   #5
GK1707
Member#: 373868
2004 STi
- OEM STi Front left axle - $60 - Has a ripped boot and will need it replaced but otherwise no issues
https://i.imgur.com/eRNYSrK.jpg
https://i.imgur.com/xIkQ5rA.jpg
- TurboXS RFL BOV - $120 - Perfect condition
https://i.imgur.com/CqP9Icp.jpg
https://i.imgur.com/WOImsCu.jpg
https://i.imgur.com/JXqlqem.jpg
- OEM STi Up pipe - $100 - Perfect condition, all studs intact
https://i.imgur.com/D6wvBHV.jpg
https://i.imgur.com/0GPk0ka.jpg
https://i.imgur.com/vdCQJWX.jpg
Old 08-25-2019, 05:48 PM   #6
GK1707
Member#: 373868
2004 STi
Old 09-01-2019, 02:17 PM   #7
GK1707
Member#: 373868
2004 STi
bumppp
Old 09-07-2019, 02:09 PM   #8
GK1707
Member#: 373868
2004 STi
bump vf39 sold
Old 09-12-2019, 03:10 AM   #9
Skip62
Member#: 506279
Default I could use a front sub frame
If you have one.
Skip62 is offline   Reply With Quote
Old 09-12-2019, 07:38 AM   #10
GK1707
Member#: 373868
2004 STi
Originally Posted by Skip62 View Post
If you have one.
I do not. Not parting out any cars. I only have available what is listed above.
Old 10-13-2019, 12:21 AM   #11
GK1707
Member#: 373868
2004 STi
bumpppppp
Old 11-01-2019, 10:53 PM   #12
stockimpreza12
Member#: 420261
2013 Impreza WRX
Crystal Black Silica
Sti boost gauge still available?
stockimpreza12 is offline   Reply With Quote
Old 11-02-2019, 08:26 PM   #13
GK1707
Member#: 373868
2004 STi
Still have it available. PM coming your way
Old 11-17-2019, 02:46 PM   #14
GK1707
Member#: 373868
2004 STi
Bump it. I can ship most of the smaller items. Larger things like the Intake, radiator and turbo, I would prefer local pickup
Old 12-09-2019, 10:20 AM   #15
GK1707
Member#: 373868
2004 STi
Bumppp ttt
Old 12-14-2019, 01:32 PM   #16
GK1707
Member#: 373868
2004 STi
bumppppppp
Old 12-25-2019, 10:23 AM   #17
GK1707
Member#: 373868
2004 STi
bump for some updates, havent got to fix the images but the links still work and will take you to imgur
Old 01-13-2020, 07:42 PM   #18
GK1707
Member#: 373868
2004 STi
bump ttt
Old 02-01-2020, 04:33 PM   #19
GK1707
Member#: 373868
2004 STi
bumppppppp
Old 02-25-2020, 05:24 PM   #20
GK1707
Member#: 373868
2004 STi
update
Old 03-08-2020, 04:45 PM   #21
GK1707
Member#: 373868
2004 STi
updateeee
