Welcome to the North American Subaru Impreza Owners Club Saturday April 4, 2020
Old 02-17-2015, 06:44 PM   #4351
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
Look like there is one.
Aquamist is offline   Reply With Quote
Old 02-21-2015, 05:44 PM   #4352
lookylookitzadam
Member#: 348254
2013 WRX
Just wanted to update that my aquamist kit is still going strong. I love this thing! Only one complaint....need a bigger tank.
lookylookitzadam is offline   Reply With Quote
Old 02-21-2015, 06:00 PM   #4353
shaman
Member#: 164259
A question for those users using the safe mode wire in the ECU for the failsafe. What changes does it make in the ECU?
shaman is offline   Reply With Quote
Old 02-21-2015, 06:07 PM   #4354
lookylookitzadam
Member#: 348254
2013 WRX
I am not sure if I am talking about the same thing, but I think you are referring to the failsafe which ties into the boost control solenoid at the ECU. If so, when the failsafe or power off button is enabled, then the opens the circuit and basically runs at waste gate pressure. It doesn't cause a CEL because the Aquamist module matches the OEM solenoid resistance so the ECU doesn't even know.
Sent from my SM-G900T using NASIOC mobile app
Old 02-21-2015, 06:13 PM   #4355
shaman
Member#: 164259
I'm referring to B26 in this diagram
Old 02-22-2015, 08:36 AM   #4356
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
your rom has to have map switching capability, and of course another set of tables which have been shifted "safer" ie rich/retarded/low boost.
Old 02-22-2015, 12:41 PM   #4357
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
The single wire failsafe is for those running stand-alone EM. It's up to the tuner to determine what the failsafe trigger does. On my car, the lack of 5V on the failsafe wire switches the ecu to my standard pump gas tune that changes the fuel, timing, and boost maps
Old 02-27-2015, 07:40 PM   #4358
TheLadiesMan
Member#: 98674
1990 Skyline GTR
'03 Mustang Mach 1
Edit: K scratch all that. Decided to just go ahead and do it since I couldn't think of any issues. Any it works!.. mostly.
Just one of the line fittings seems to be leaking. Hmm.
TheLadiesMan is offline   Reply With Quote
Old 03-02-2015, 12:08 PM   #4359
TheSTIEvery1Knows
Member#: 308132
2013 Subaru STI Ltd.
Richard I'm finally sending the parts to you today for the not reading any flow issue. Im sending the controller, the gauge, flow sensor, flow sensor cable and the valve. they will go into the mail today so I'm sure you will see them next week sometime. Thanks Brendan
TheSTIEvery1Knows is offline   Reply With Quote
Old 03-02-2015, 05:56 PM   #4360
Aquamist
NASIOC Manufacturer
Member#: 110029
I have heard from you since August, I was expecting to help you months ago. I let you know when it arrived.
Old 03-02-2015, 06:21 PM   #4361
TheSTIEvery1Knows
Member#: 308132
I know Richard work has been insane I had a baby you know how things go!!! Sorry for the delay. I had to get the motor out of the car and sent out to be rebuilt and just slipped my mind to get it shipped out
Old 03-06-2015, 03:45 PM   #4362
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
Car 2002 Subaru impreza WRX 5mt
System Aquamist 2d (older pump with the massive heatsink iirc race version pump)
Fuel injector number 4 tapped.
I believe the HSV is now called the FAV
2d System was installed and working correctly. Then approx 2 years ago I decided to embark on an engine project.
I disabled power to the pump two years ago. And I removed the water jet and the HSV from the car, and stored them in a box in my study.
Problem. No flow from HSV when FIA is triggered.
Diagnosis 1
engine off
ignition switch on position 2
power applied to Aquamist pump without hsf or nozzle.
The pump primes correctly when power is connected
Water comes out of the tube at the end of the pump. Quite a fair bit.
Diagnosis 2
Aquamist pump with HSV connected but no nozzle. pump runs until pressure is built up at the HSV inflow port, then it switches off
engine off
ground brown wire on HSV
There is flow at the HSV. can hear the hsv clicking
Diagnosis 3
engine on (running)
FIA shows fuel light on.
When I open the hop switch circuit. (this is normally closed)
-FIA water light comes on
But no water comes out the HSV
diagnosis 4
Received a used/working FIA
Replaced FIA, same problem
Please help
runner19 is offline   Reply With Quote
Old 03-07-2015, 02:57 AM   #4363
Aquamist
NASIOC Manufacturer
Member#: 110029
At idle there may not be enough duty cycle to energise the HSV. I suggest ground the brown wire of the HSV and see if the HSV opens up.
Old 03-07-2015, 07:05 AM   #4364
runner19
Member#: 39562
My02 WRX Sedan 5MT
WR blue
Okay that is good info. Should I rev it to 3000 rpm
I did do that in diagnosis step 2. The HSV is working
Thank you for the help
Old 03-07-2015, 01:46 PM   #4365
Aquamist
NASIOC Manufacturer
Member#: 110029
You need to put some load on the engine by driving it. A stable 3000rpm free revving has next to no load. If you blip the throttle hard, it will load the engine. Try this first.
Old 03-09-2015, 09:01 AM   #4366
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd jdm 6 speed now!
I have an aquamist 2d. What does it mean if the red and green lights on the fia2 flash together at idle
666stars is offline   Reply With Quote
Old 03-09-2015, 01:23 PM   #4367
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
is your manifold pressure sensor grounded/properly connected? if you unground it, it will send signal to FIA2 to inject water, which could explain why you are seeing both lights at idle
on another note, I put my system back together today to find out my ERL race pump doesn't work, so if anyone has a working one and willing to sell at a reasonable price, let me know
I am unaware if I can upgrade to the big shurflo pump at this point while keeping all 2D wiring/FIA2 stuff?
Hyper is online now   Reply With Quote
Old 03-09-2015, 05:05 PM   #4368
666stars
Member#: 221364
I have a leak at the quick disconnect from the manifold to the accumulator. I have tried to cut new hose and it's still leaking. So I ordered new hose and two quick disconnects
Old 03-10-2015, 08:29 PM   #4369
Aquamist
NASIOC Manufacturer
Member#: 110029
Do not use quick connectors, there are better alternatives that don't leak.
Old 03-11-2015, 09:16 AM   #4370
666stars
Member#: 221364
I ordered the connector with the Orange fitting. Should I have ordered the all metal compression fittings
Old 03-11-2015, 10:34 AM   #4371
Aquamist
NASIOC Manufacturer
Member#: 110029
The orange fittings are still push on type, Since you ordered them already. I would leave it.
Old 03-12-2015, 06:58 AM   #4372
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
you should be able to use the bypass pump. this guy is selling off his hydramist with a spare pump he might be willing to part out: http://forums.nasioc.com/forums/show....php?t=2705599
Old 03-12-2015, 05:56 PM   #4373
666stars
Member#: 221364
[quote=Hyper;43176950]is your manifold pressure sensor grounded/properly connected? if you unground it, it will send signal to FIA2 to inject water, which could explain why you are seeing both lights at idle
Thanks Hyper, I had a spare manifold pressure sensor and swapped them . Looks like that fixed my issue
Old 03-12-2015, 06:45 PM   #4374
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
ken, what do you mean by bypass pump? shurflo? (don't know how to spell it) I was under impression it is both 6mm in and out, and according the HFS diagrams it has 2 wire instead of 3 for the ERL
actually I was lucky to snatch a brand new ERL from my friend, but for the future experiments I'd love do know how difficult it is to retrofit one into an older system... I don't need most of the neat stuff as I am using Autronic to control most of it anyway
666stars, good to hear, I had an issue with that myself a while ago and Richard figured it out in no time and sent me a replacement unit, so all thanks goes to him
Old 03-15-2015, 06:37 AM   #4375
Aquamist
NASIOC Manufacturer
Member#: 110029
I have received the bundle and will be testing it next week.
Passing the NEW required OBDII Emissions test in PA Questions and Answers!! mrtrex Mid Atlantic Impreza Club -- MAIC 29 03-10-2013 07:23 PM
Snow Performance questions and answers... Ultimate Collision Center Water/Methanol Injection, Nitrous & Intercooler Cooling 374 09-23-2008 04:36 PM
Motörhead Guidlines, questions and answers here: GO LEMMY!! El Camino Off-Topic 9 01-20-2006 02:39 PM
Roll Center, questions and answers Arnie Brakes, Steering & Suspension 5 12-21-2004 03:26 PM
