Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2020
Old 04-12-2015, 07:12 PM   #4401
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
I did ask you what shipping method you want, you chose airmail post. Fedex is trackable. I didn't charge you at all.
Aquamist is offline   Reply With Quote
Old 04-12-2015, 07:13 PM   #4402
TheSTIEvery1Knows
Member#: 308132
2013 Subaru STI Ltd.
Do you think it might just take longer because it was a bigger package?
TheSTIEvery1Knows is offline   Reply With Quote
Old 04-12-2015, 07:19 PM   #4403
Aquamist
NASIOC Manufacturer
Member#: 110029
I think it is most probable.
Old 04-12-2015, 07:38 PM   #4404
TheSTIEvery1Knows
Member#: 308132
Ok hopefully I see it soon I'll keep you posted. So that sensor pictured is a new style?
Old 04-13-2015, 03:13 AM   #4405
Aquamist
NASIOC Manufacturer
Member#: 110029
The picture you posted is not a sensor, it is a harness for the fast acting valve.
I forgot to pack this on the main package so I sent it separately afterwards.
Old 04-15-2015, 04:26 PM   #4406
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
You guys know if 50/50 meth is safe to use on pvc? My elbow at my tank started leaking and was looking for a temp solution at the hardware store until i can order a proper one. Found a fitting that fits the bill but its made out of pvc
ddavisgt is offline   Reply With Quote
Old 04-15-2015, 04:34 PM   #4407
Aquamist
NASIOC Manufacturer
Member#: 110029
PVC will not work with 50/50, it will soften and deform over time.
Post a picture of the elbow? It might not be the elbow, could be the thread?
Old 04-15-2015, 04:47 PM   #4408
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
k, its leaking where the 6mm line pushes into the quick fit. If the line moves side to side any then meth leaks out. I tried trimming the tip of the line so it could grab onto a fresh part of the hose but still leaking.
Old 04-15-2015, 06:24 PM   #4409
Aquamist
NASIOC Manufacturer
Member#: 110029
Can you post a picture? We haven't offer push-fit fittings for years.
Old 04-15-2015, 06:28 PM   #4410
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
Weird, my kit is only a year or so old and bought it new. I'm not home right now, but it looks just like this fitting http://www.gtmotorsports.com/images/P/P12007111.jpg
Old 04-15-2015, 06:29 PM   #4411
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
What do you guys use now for that area?
Old 04-15-2015, 06:35 PM   #4412
Aquamist
NASIOC Manufacturer
Member#: 110029
All our current systems use compression fitting, since 2010.
Here are some examples:
Old 04-15-2015, 06:36 PM   #4413
Aquamist
NASIOC Manufacturer
Member#: 110029
What is the model name of the kit?
Old 04-15-2015, 06:47 PM   #4414
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
Oh, those look nice! The kit is a Aquamist HFS -4
Old 04-15-2015, 07:02 PM   #4415
Aquamist
NASIOC Manufacturer
Member#: 110029
There is no way the HFS4 comes with those fittings. Unless they buy them in from a third party source. As you can see, we do have a 90-deg elbow that goes into pump.
Old 04-15-2015, 07:25 PM   #4416
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
Thanks for the info. I bought the kit through my tuner that ordered it so maybe that was the case. I will put in an order for some new fittings to get this fixed. They look much better.
I dont suppose theres a way to repair the old push in style ones in the meantime? Car was headed somewhere tomorrow, but looking like I might have to sit on it since I couldnt find any local solutions.
Old 04-16-2015, 10:51 AM   #4417
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
I got the fittings ordered, so that should do the trick when they come in.
Different question, you guys ever use wiffle golf balls as baffles in larger takes? Will meth break these down?
Old 04-16-2015, 12:42 PM   #4418
Aquamist
NASIOC Manufacturer
Member#: 110029
We don't use golf balls for baffles. I believe Howerton has tested them in pure meth.
Old 04-17-2015, 10:39 AM   #4419
JMlegacy
Member#: 341649
In terms of boost reference point. Would the FPR vacuum hose (t'd in) be a better point that anywhere else before the throttle body? I'm considering if it's before the throttle, when we let off the throttle and the pressure builds up before the throttle, the meth might still be spraying for a half second or so until turbo spools down. After throttle is less pressure and more in line to what the controller is looking for. Right?
JMlegacy is offline   Reply With Quote
Old 04-17-2015, 07:37 PM   #4420
Aquamist
NASIOC Manufacturer
Member#: 110029
You are perfectly correct about the tee location.
What system do you have? All our current systems are triggered by idc % so the boost signal is irrelevant.
Old 04-18-2015, 10:16 PM   #4421
Gatehous3
Member#: 335426
Hello Richard,
I was wondering if I chose the correct jets for my application, and if the location of the dual nozzle is okay.
HFS3 V3 (red board)
50/50 meth/distilled water
750cc injectors (maxed out at 90% injector duty cycle)
1.0mm and 0.9mm jets (just before the throttle body tapped into the TMIC)
0.7mm restrictor
30psi of boost
I feel like im spraying too much methanol and I havent had the chance to do a AFR drop test. I can do this when I get home in a few weeks.
Thanks for your time!
Gatehous3 is offline   Reply With Quote
Old 04-19-2015, 04:32 PM   #4422
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
Got my new fittings on to fix the leak, they worked out well. Still getting the failsafe triggering so i'm guessing that wasnt the problem.
Ive disconnected the pump and purged water through it and it seems fine. I've taken apart the injectors and cleaned them also. I pulled the interior apart and checked for kinks in the lines and the wiring and couldnt find anything. I'm stumped at the moment....
Im seeing both yellow lights kick on and no flow bars when pulling the jumper off the FAV while testing but water seems to be flowing out fine before the FAV and also through the injector.
Also since i had everything apart I went ahead and installed the tank filter that my installer missed a year or so back when he installed the kit. Would I need to set something back up now that theres a filter in the tank? Any suggestions on what else I could try to get the kit working?
Old 04-19-2015, 04:59 PM   #4423
Aquamist
NASIOC Manufacturer
Member#: 110029
Assuming the jet is b-not partially clogged and display a nice spray pattern in free air.
You need to reset and dial in the fail safe again as the settings will be wrong since the leakage.
When both yellow leds came on, it was the failsafe activated.
Old 04-19-2015, 05:25 PM   #4424
TheSTIEvery1Knows
Member#: 308132
Richard all the parts came in yesterday!!! Thank you for everything I'll let you know how the install goes
Old 04-20-2015, 10:41 AM   #4425
ddavisgt
Member#: 105232
2004 Hybrid Wagon
wrb
Would I need to adjust the SC on the gauge? I got the failsafe not to trigger but i'm only seeing 4 bars light up on the gauge instead of the normal 5 or 6. Would adding a filter in the tank cause the missing bars you think? The kit worked fine the past year at the current sc settings but that was without the filter in.
Passing the NEW required OBDII Emissions test in PA Questions and Answers!! mrtrex Mid Atlantic Impreza Club -- MAIC 29 03-10-2013 07:23 PM
Snow Performance questions and answers... Ultimate Collision Center Water/Methanol Injection, Nitrous & Intercooler Cooling 374 09-23-2008 04:36 PM
Motörhead Guidlines, questions and answers here: GO LEMMY!! El Camino Off-Topic 9 01-20-2006 02:39 PM
Roll Center, questions and answers Arnie Brakes, Steering & Suspension 5 12-21-2004 03:26 PM
