Welcome to the North American Subaru Impreza Owners Club Monday December 10, 2018
Mid Atlantic Impreza Club
Old 04-24-2012, 11:07 PM   #1051
bettner12
Member#: 56179
05 LGT 407hp/372tq
Tuned by [email protected]
Originally Posted by MRF582
Blue is the BRZ front strut angle. Do not like! Damn near perpendicular for an even ****tier camber gain than an Impreza which is already quite terrible.
Its not about camber gain. Ideal shock placement IS perpendicular to wheel travel. Maybe Pitt should have taught you that too...
bettner12 is offline   Reply With Quote
Old 04-24-2012, 11:23 PM   #1052
MRF582
Member#: 48219
. Always drive
the race line .
And looks like there isn't any room to slot the top mounting holes. This thing is going to need much more roll stiffness up front to not suck.
MRF582 is offline   Reply With Quote
Old 04-24-2012, 11:35 PM   #1053
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
what are you guys, daft? the inclination of the strut doesn't matter, it's the points between the strut top and LBJ in relation to LBJ and inner arm pivots. oh no there's more bending load there..
edit: clint yeah.
glhs377 is offline   Reply With Quote
Old 04-24-2012, 11:38 PM   #1054
MRF582
Member#: 48219
. Always drive
the race line .
LOL, you are dead wrong.
Old 04-24-2012, 11:51 PM   #1055
MRF582
Member#: 48219
. Always drive
the race line .
Jason, that is the steering axis and not the strut inclination angle!
Old 04-24-2012, 11:53 PM   #1056
bettner12
Member#: 56179
05 LGT 407hp/372tq
Not going to waste my time.on here tonight explaining suspension design. I encourage you to read the race car vehicle dynamics book by Millikan and Millikan. There is another book too, ill find it when I get back home.
Old 04-25-2012, 12:05 AM   #1057
MRF582
Member#: 48219
. Always drive
the race line .
^Please follow your own advice and re-read it. We're not talking about a baja off-road car here. We're talking about tarmac racing.
http://books.google.com/books?id=rY2...0strut&f=false
Old 04-25-2012, 12:11 AM   #1058
bettner12
Member#: 56179
05 LGT 407hp/372tq
You mean a Baja off road racer with better bump steer than a GT-1 with. 013" of total bumpsteer? And perfect camber gains through droop and compression?
Macpherson strut sucks end of story.
Old 04-25-2012, 12:12 AM   #1059
The1SloR/T
Member#: 251879
1998 Neon R/T 178whp
2010 Wrx Sedan WRB
So anyone got room for 2 adults and 1 car at OCAWD? We're lookin at hotels and I can get one for $100 a night but it'll be quite boring with just the 2 of us.
We'll pitch in up to that amount if need be
The1SloR/T is offline   Reply With Quote
Old 04-25-2012, 12:18 AM   #1060
MRF582
Member#: 48219
. Always drive
the race line .
Dude, we're talking about the BRZ front suspension here. Are you high?
We're talking about the BRZ front MacPherson strut. Camber gain DOES matter. And Jason is wrong. The strut inclination absolutely matters when defining the instantaneous center. The steering axis which is what he described does not matter.
http://www.modified.com/tech/0508_sc...3/viewall.html
To find the instant centers on a car with upper and lower control arms, draw lines from the center of the ball joint through the inner pivots of the upper and lower control arms and extend them inward toward the center of the car until they meet. Now draw a line from the center of the tire's contact patch to the instant center on both sides of the car. The point where these two lines intersect is the roll center.
For a car with a MacPherson strut suspension, the upper line is made by drawing a line 90 degrees from the strut axis, starting at the upper mounting point of the strut.
Old 04-25-2012, 12:51 AM   #1061
bettner12
Member#: 56179
05 LGT 407hp/372tq
K.....
Old 04-25-2012, 12:56 AM   #1062
garagedefeat
Member#: 101399
2001 Forester L
Originally Posted by Tenacious Bee View Post
Oh sorry. It was the mother of all graphs !!! The Eva Mendez of graphs !!!! The 86 Bears defense of graphs !! The best graph I have ever !!!
Show me a really good one with similar mods.
garagedefeat is offline   Reply With Quote
Old 04-25-2012, 02:10 AM   #1063
glhs377
Member#: 125388
97 240hp NA GF6
i can't argue with you this right here and now, i don't have the time to do a convincing job, but all i should tell you is: do some modeling on extreme offset examples.
what you read on the webz with all the 90 degree to the top of the strut mount is effectively the upper arm's axis slag falls apart. besides, when you take off the 180lb/in springs and put on some real springs(400+) to handle non-low rolling resistance prius tires(not joking), how much usable suspension travel you actually have? so who cares about camber curves and camber gain? i'd care more about damper valving, static caster and camber, and what diff to be running, oh, and how much the engine has left before it's gonna go big joe.
Old 04-25-2012, 10:11 AM   #1064
FXTSPORTS08
Member#: 232340
2008 WRX
Dark Gray
Don't you want to raise the instant (roll) center? If so then a more perpendicular strut will do that!
FXTSPORTS08 is offline   Reply With Quote
Old 04-25-2012, 10:22 AM   #1065
MRF582
Member#: 48219
. Always drive
the race line .
Gawd, you're so ****ing annoying. Can't even admit when you're wrong.
edit: clint yeah.
^This is dead wrong.
And are you seriously that attention challenged that you can't stay on the discussion at hand?
This discussion started as turbocat and I observing how ****ty the inherent negative camber gain the BRZ has which is even worse than an Impreza. And I said you'd need much more front roll stiffness to make the car not suck. Did you forget to read that part?
Then Clinton chimes in with his massive amount of Formula Baja experience to say camber gain does not matter. I told him we aren't talking about a baja off-road car, to which he attempts to whip out his dick and talk about how perfectly the camber was controlled through droop and compression on one of the Baja cars. That is the exact opposite of what you want for a car driven on tarmac! The point is for the tire to stay perpendicular to the road as the body rolls. This can only be achieved if negative camber increases under compression!
Then YOU chime in with your massive amount of Formula SAE experience and trip over such an elemental part of MacStrut design. And you're telling ME to go search when YOU are the one that's totally got this wrong? For the love of god, please look up how to calculate the front roll center of a MacStrut car. Don't try to weasel out of this by talking about the engine, differential and tires etc. We are talking about the inherently worse MacPherson strut inclination of the BRZ compared to the Impreza.
How about page 36 'How to make your car handle' by Fred Puhn. http://books.google.com/books?id=cr4...0strut&f=false
Why don't you do some research about why strut inclination matters and then get back to me? Because I don't have time to put up with your arrogance and inability to accept when you're wrong.
Maybe the both of you should've gone to Pitt.
Old 04-25-2012, 10:24 AM   #1066
MRF582
Member#: 48219
. Always drive
the race line .
Jesus ****ing Christ.
Which strut inclination would YOU rather have? (You clearly don't know how to calculate roll center because you think the instant center is the same as the roll center.)
Pretend the strut inclination as drawn is perpendicular to the top red line... (obviously)
Old 04-25-2012, 11:29 AM   #1067
garagedefeat
Member#: 101399
2001 Forester L
kinda wish we were talking steaks and phones again.
shek/turbo - what's the purpose of the shallower strut angle on the BRZ?
Does it have to do w. being able to fit the motor in there? Safety? Is it somehow a cost thing? I'm just curious why more angle wouldn't be engineered in (especially since it doesn't seem like a cost-prohibitive act) if it matters so much on a car that was built for tarmac.
And do you have to approach changing the angle from the top? What about pushing the point at which the strut mounts to the knuckle away from the centerline?
Old 04-25-2012, 11:56 AM   #1068
MRF582
Member#: 48219
. Always drive
the race line .
Yep, blame all Subaru horrid strut designs on the boxer motor. Too wide. You can either move the top point in or move the knuckle away from the centerline of the car. Wider control arms will do that. They could've just made the car wider to begin with.
They can't move the top in much further without rendering a spark plug swap almost impossible without removing/lifting the engine. They did give the car enough fender room so a wider control arm will work.
Look how close the tire is to the coil. Won't even be able to install 'camber bolts' to tilt the wheel in.
In a year's worth of time, all fast BRZs will be running with 30mm less backspacing on the wheels and -3.5 degrees or more of camber to try and bandaid the pile of **** Subaru designed. If someone can sell wider control arms, they will sell very very well.
Old 04-25-2012, 11:56 AM   #1069
turbocat
Member#: 120151
13 BRZ, 07 WRX
Wagon, 94 Land Cruiser
kinda wish we were talking steaks and phones again. The phones... Meh. The Steaks, ribs, brisket, smokers, all very good, but I was getting bored. Engines and all the bit that get them down the road is what really makes my head spin. I like that this thread always has variety.
shek/turbo - what's the purpose of the shallower strut angle on the BRZ? I have no official answer for you. I freely admit that I'm no engineer, and that there are people in this thread that have a ton of engineering knowledge above my own. My best guess is packaging, safety, and feel. I think this (Feel) was one of the biggest factors in the whole design of this chassis. Look at this pic again. The strut towers don't have much room to be pushed in.
And do you have to approach changing the angle from the top? What about pushing the point at which the strut mounts to the knuckle away from the centerline? My next thought on camber adjustment was eccentric bushings and/or slots on the lower control arm(ball joints or chassis mounts). Which is what I think you are getting at.
So I think Shek beat me to it.
Look at Ken Gushi's FR-S Drift car. They have tons of inward(Neg) camber adjustment left on the top mounts. I don't have exact answers. Plus we all know Drift cars are completely opposite of the kind of handling we are talking about. I do know the stock BRZ has been reviewed as being very responsive, and easy to toss about, and slide. I don't know what the rest of Gushi's suspension looks like, but it does get me asking more questions about the stock BRZ.
turbocat is offline   Reply With Quote
Old 04-25-2012, 12:35 PM   #1070
bettner12
Member#: 56179
05 LGT 407hp/372tq
Old 04-25-2012, 12:59 PM   #1071
saabarupp
Member#: 189032
2015 STI CWP
'12 Impreza Sport Ltd DGM
Hey guys, what's up with PVGP registration? Should we just go register independently via the website?
saabarupp is offline   Reply With Quote
Old 04-25-2012, 01:04 PM   #1072
SubaruWRC
Member#: 11063
2001 Impreza 2.5 RS
and bye bye Turtle :(
Thank you for hurting my brain sir!
Jiffy
SubaruWRC is offline   Reply With Quote
Old 04-25-2012, 01:18 PM   #1073
MRF582
Member#: 48219
. Always drive
the race line .
If I had a BRZ, those camber plates would be my first mod and crank the things in.
Old 04-25-2012, 01:25 PM   #1074
buddsautoparts.com
Member#: 263591
2004 being rebuilt
good question!
Hold off on that till you hear from fisher. He has the most up to date info on that.
buddsautoparts.com is offline   Reply With Quote
Old 04-25-2012, 01:31 PM   #1075
ruby-ru
Member#: 44535
2003 PSM WRX
Twinscroll Goodness!
Yeah but does it have an O2 sensor bunghole on the DP a few inches past the hotside?
But I do like the fact that this car will actually see some track time. Do eeet Jeremey!
Actually, my car has seen track time on every turbo set up except stock. This is the fourth set up to include stock. Wow! I hadn't thought about that up until this point. Turbo set-up ADD.
I don't see why this turbo setup would be any different. I just can't do it as much as I'd like to due to my schedule.
ruby-ru is offline   Reply With Quote
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 07:58 PM
Official Pittsburgh Thread v5 MRF582 Mid Atlantic Impreza Club -- MAIC 10302 10-07-2010 11:03 AM
Official Pittsburgh Thread V4 Kjott21 Mid Atlantic Impreza Club -- MAIC 10940 10-29-2009 04:16 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 10:08 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 08:23 PM
