Welcome to the North American Subaru Impreza Owners Club Tuesday December 18, 2018
Mid Atlantic Impreza Club
Old 04-25-2012, 01:38 PM   #1076
MRF582
Member#: 48219
. Always drive
the race line .
Oh, I didn't mean to say that as if your car hadn't seen track time yet. Just that less than 1% of modified Subarus actually see track time and since it's your car, it will probably continue to see track time.
MRF582 is offline   Reply With Quote
Old 04-25-2012, 01:50 PM   #1077
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
shek, i really don't have time right now to do drawings and walk you through this. every textbook example of a macstrut has the strut incliniation and axis very nearly in line with the LBJ. this used to be how it was implemented, back in the 80s when those books were written. that's still how you calculate the instant center, and find the roll center, but the offset changes how it works as a system.
i know how to caclulate geometry, milliken&milliken is one of my toilet reading books. but you're incorrect with the strut inclination being what sets camber gain. and also off base where it matters. and also off base trying to change the roll center with the strut top. fabricated LCAs will be great if only for taking the LBJ out of the knuckle and dropping it an inch or two into the arm. something i think all the subarus should have. anyway, the strut inclination thing is not bad or catastrophic.
glhs377 is offline   Reply With Quote
Old 04-25-2012, 02:11 PM   #1078
MRF582
Member#: 48219
. Always drive
the race line .
Yes, and the fact that the strut axis lines up with the steering axis in those diagrams is just a coincidence. If you actually bothered to read those textbooks carefully you would know that. The steering axis is defined as an imaginary line that runs through the top strut mount and the lower ball joint. The strut axis is a line that runs coaxially with the strut's piston.
And for the 3rd ****ing time. The strut axis and the steering axis are two entirely separate things. You use the strut axis to calculate the instantaneous center not the steering axis.
In the case of the BRZ, the strut axis and the steering axis do not line up.
I refuse to have any further discussion with you until you realize the glaring difference between the two. Please go read your book on the ****ter.
Old 04-25-2012, 03:43 PM   #1079
turbocat
Member#: 120151
13 BRZ, 07 WRX
Wagon, 94 Land Cruiser
Via CraigsList...
turbocat is offline   Reply With Quote
Old 04-25-2012, 03:58 PM   #1080
MRF582
Member#: 48219
. Always drive
the race line .
So I changed the oil/filter yesterday on the WRX. Mobil 1 10w-40. Oil pressure at 3500 RPM at 190F went from 80 to 95psi. LOL. Guess 5,000 miles on old oil will do that.
Old 04-25-2012, 04:01 PM   #1081
d3v0
Member#: 225692
2015 WRX
d3v0 is offline   Reply With Quote
Old 04-25-2012, 04:02 PM   #1082
DILLIGAF Racing
Member#: 29440
2015 WRX
Originally Posted by turbocat View Post
Via CraigsList...
DILLIGAF Racing is offline   Reply With Quote
Old 04-25-2012, 04:28 PM   #1083
saabarupp
Member#: 189032
2015 STI CWP
'12 Impreza Sport Ltd DGM
Have any of you brainiacs in here ever thought about doing something useful with your time? Like building one of these:
saabarupp is offline   Reply With Quote
Old 04-25-2012, 04:50 PM   #1084
glhs377
Member#: 125388
97 240hp NA GF6
Originally Posted by MRF582 View Post
Blue is the BRZ front strut angle. Do not like! Damn near perpendicular for an even ****tier camber gain than an Impreza which is already quite terrible.
homeboy, you started this. and you stated it with the misnomer that strut inclination has something to do with camber gain. that is all.
also i'm glad you changed your oil.
Old 04-25-2012, 05:17 PM   #1085
MRF582
Member#: 48219
. Always drive
the race line .
Jason, do you recognize the difference between a strut axis and a steering axis?
Old 04-25-2012, 06:51 PM   #1086
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Originally Posted by garagedefeat
Show me a really good one with similar mods.
Dale...what the heck man? I am not ragging on the graph. Barely looked at it. I support you guys every chance I get. I typed pretty good cause in my world pretty good is....pretty good lol!
Bee gone....sad banana.
Tenacious Bee is offline   Reply With Quote
Old 04-25-2012, 06:52 PM   #1087
glhs377
Member#: 125388
97 240hp NA GF6
abhishek, you do realize that from that pic you can not determine anything about the pickup points of the LCA, which has an everything more to do with camber gain than the angle between the axial positioning of the strut vs anything else. i'll draw you pictures, in due time, or draw them yourself. basically, if the steering axis vs the LCA angle is acute, you're gaining camber in compression. strut axis, does not matter when your'e talking about camber gain. if you want to go jibba jabba bout roll center height and instant center, then by all means, use the strut axis as a reference.
Old 04-25-2012, 11:13 PM   #1088
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Went to a good home.
Old 04-26-2012, 08:07 AM   #1089
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
isis is offline   Reply With Quote
Old 04-26-2012, 08:51 AM   #1090
turbocat
Member#: 120151
13 BRZ, 07 WRX
That's a bummer. The last two cars I sold were hard to let go of. I still miss my blue wagon.
Vern, as you know better than many of us, there will be other cars.
Old 04-26-2012, 10:32 AM   #1091
MRF582
Member#: 48219
. Always drive
the race line .
Please re-read the parts in bold. First you say I'm off-base trying to change the roll center by moving the strut tops in and slanting the strut axis more but then later say I can use the strut axis as a reference to 'jibba jabba' about roll center?
I do believe those two statements are in direct contradiction of one another.
Old 04-26-2012, 10:41 AM   #1092
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Walked in the kitchen and looked out back where I kept it, looked at the empty spot and immediately started imagining what I will park there. Cost no object it would be a blue GC I know of chilling on the north side.
Old 04-26-2012, 12:03 PM   #1093
Blinden
Member#: 122993
Ex's WRX
02, 04 Sti, 12 Hatch
How stupid you trying to play us.
Cost no object, and you are getting a subaru?
I remember when I was 22 and haggling for the first car I was buying without parental assistance. It was a Dodge Stratus coupe, and they were asking $14k for it and I was goign back and forth with the guy and he gives me the "It's only $30/month difference" for the price that I was offering him. He says to me "Look, if price were no object, is this the car that you would want or not, because, it's only $30/month." I completely was unable to stop myself from laughing.
Blinden is offline   Reply With Quote
Old 04-26-2012, 01:06 PM   #1094
garagedefeat
Member#: 101399
2001 Forester L
sorry! i read too much into what you posted. Thanks for the support, Vern.
garagedefeat is offline   Reply With Quote
Old 04-26-2012, 01:07 PM   #1095
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Yeah. I guess I was thinking along the terms of reality. With all of the stuff I have to do the house and Ty starting school I can't see me spending too much on a toy. Dan's car is something that I could obtain. If I hit the lottery or something 911 turbo s please.
Old 04-26-2012, 01:17 PM   #1096
Tenacious Bee
Member#: 96452
So, what to play
with next ?
No apologies needed. With the atmosphere around here I don't blame you for having your guard up. The intelligencia is waiting to pounce
Old 04-26-2012, 01:21 PM   #1097
The1SloR/T
Member#: 251879
1998 Neon R/T 178whp
2010 Wrx Sedan WRB
Used 911's really aren't that badly priced if bought from private owner. I personally want to bank a little for a C6 grand sport or Z06
Harley is first
The1SloR/T is offline   Reply With Quote
Old 04-26-2012, 01:42 PM   #1098
glhs377
Member#: 125388
97 240hp NA GF6
997s are really affordable and great cars, interior is just horrible like a C5 and they look all donkey on the outside too.
and shek, at least i know where you think i made a mistake.
i can restate that for you as:
..and also barking up the wrong tree trying to change the roll center with the strut top.
now stop ignoring the rest of it.
Old 04-26-2012, 02:20 PM   #1099
MRF582
Member#: 48219
. Always drive
the race line .
This is absolutely appalling. Are you still unable to grasp how moving the strut tops inboard improves the roll center? That's OK, Vindler didn't understand this either. Must've gone to Pitt.
There's no point in talking about camber gain and other concepts if you can't even come to terms with the first part.
http://www.iwsti.com/forums/gd-suspe...-analysis.html
Read THIS! Maybe you won't believe me but you will believe someone else. Unfortunately the pictures don't work but the guy thankfully captioned them in text.
Here's how the camber curve changes with camber plates moving your strut mounting point one inch inward (maxed out for most products):
Notice there's quite a bit more dynamic camber when doing this! The roll center height goes up a bit, but not much.
So an improvement in dynamic camber AND roll center by moving the strut tops inwards.
Jason, there is no way you have had this SO wrong. You have got to be trolling. Actually, I really hope you're trolling.
Old 04-26-2012, 02:59 PM   #1100
Blinden
Member#: 122993
Ex's WRX
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 07:58 PM
Official Pittsburgh Thread v5 MRF582 Mid Atlantic Impreza Club -- MAIC 10302 10-07-2010 11:03 AM
Official Pittsburgh Thread V4 Kjott21 Mid Atlantic Impreza Club -- MAIC 10940 10-29-2009 04:16 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 10:08 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 08:23 PM
