#676 |
Member#: 90539
South East
Vehicle:My BOV goes COVFEFE! |
![]() Does anyone have part number for the gasket of the metal coolant expansion tank that bolts to the intake manifold?
#677 | ||
Member#: 393747
![]() Quote:
Water tank assembly. Quote:
Sorry, very late... but here they are ![]() Translation: Version D/E models with EJ20G, 20K or 22G engines have 3 types of gasket available. At the time of changing the gaskets, check the type of the gasket and then order. Type A RH 13270AA062 (gasket), 13264AA131 (cover) LH 13272AA063 (gasket), 13278AA111 (cover) Type B RH 13270AA082 (gasket), 13264AA160 (cover) LH 13272AA082 (gasket), 13278AA140 (cover) Type C RH 13270AA111 (gasket), 13264AA190 (cover) LH 13272AA110 (gasket), 13278AA170 (cover) ---------------------------------------------------------- Sadly, I don't remember which one was mine; not that that would of helped you last year. edit** Looking at my pictures from my rebuild, I see that mine were Type A. ![]() Last edited by gc8fxt; 12-16-2016 at 08:47 PM. Reason: rebuild |
#678 |
Member#: 133923
Vehicle:03 Legacy GT wagon I love goooollllllllddddd |
![]() I'm pretty sure they don't sell that separately. I couldn't find any reference to it online and couldn't find it on any diagram. You just have to buy the whole tank
#679 |
Member#: 90539
South East
![]() /\ You're correct, I was excited when he posted the part number because I was at work and didn't realize it was the tank part number. It's a shame, because the metal tanks are really nice. I may have to just fork out the money for a new plastic tank instead of gluing the two together. I don't want to risk any leaking with the new sleeved block.
#680 | |
Member#: 133923
![]() Quote:
#681 |
Member#: 90539
South East
![]() I'm going to buy a new one piece plastic, shouldn't get brittle for a long time and I don't want to risk a leak with the new engine. It will be tough enough keeping the coolant from leaking around the edge of hoses. I may use a different brand of coolant, since the Toyota pink seems to find every microscopic pore to leak from. Honda coolant may be the choice this time.
#682 |
Member#: 410300
![]() Anyone have the part number for a ej20k starter, or know what model usdm starter, if any would work?
#683 |
Member#: 133923
#684 |
Member#: 410300
![]() Last edited by mrgf8sti; 03-14-2017 at 02:40 PM. |
#685 | |
Member#: 468107
International
Vehicle:2001 JF1 Rs GM-coupe Blue |
![]() Quote:
If you have information on how or where to get it please. |
#686 |
Member#: 457410
International
Vehicle:1991 Legacy RS RA White |
![]() Here is a good source of parts and part numbers for a JDM engine
https://partsouq.com/en/catalog/genu...c=Subaru+Japan |
#687 |
Member#: 472184
![]() Hey guys, been strongly considering buying a 93 jdm wrx. Wondering if you can all help me.
little run down on the car; was a running and driving wrx about a year ago. The previous owner pulled the motor due to low compression and at the time wanted to clean up the wiring in the engine bay. He got the motor rebuilt, and sold the motor. Now has the wiring all out of the engine bay. He has a 94 wrx wiring harness that he was planning on putting back in as it needed very minor repair opposed to the one he originally took out. But he did have the car running a ej20g with the crappy harness he had in originally. So now i am contempleting buying this mint wrx.. Thing is im not to sure what ej20g motor will work in the car. Will any ej20g work? Does it need to be a specifc year, model ect? Is there anything else i should consider looking into before i pick up the car? ecu? Its a very good deal for the car i feel as it has alot of potential to be awesome again, he only wants 900 for the car, has everything else besides the motor, that includes the transmission (unsure of which one though). Thank you all! |
#688 |
Member#: 13530
Vehicle:EA63 , EA81T, EJ20G, EJ205 |
#689 |
Member#: 410300
![]() Any part number for a jdm r160 rear diff cover gasket?
also can any usdm gc axle fit on the jdm r160 drive train? |
#690 |
Member#: 486698
![]() This thread is amazing. Saved my car multiple times
#691 |
Member#: 13530
![]() Looking for the correct part number for the front o2 sensor for a 1993 WRX Type-RA. I thought I had found the correct part, but the three-pin connector doesn't match the 4-pin connector on my engine harness.
HELP! |
#692 |
Member#: 393747
![]() If you don't have the JDM Subaru parts software, I recommend partsouq.com. You can enter your Japanese VIN (gc8-05###1) and it will pull up the parts for your vehicle.
I've been using this site for my current RHD Honda Element and for my RHD BP5 2.0GTspecB that's coming soon. Works for USDM and EDM cars as well. |
#693 |
Member#: 495280
![]() hi! do you have part number for the water pump?
(i am just ordering in amazon) here in my place there is no parts store that caters for old model subarus. car is: JDM sf5 forester. VIN:SF5-018862 APPLIED MODEL: SF5A53P TRIM CODE: 820 ENGINE TYPE: EJ20GDX1NY |
#694 | |
Member#: 93750
![]() Quote:
it shows three different part numbers for 1996;X2111AA040, 1997;X2111AA041, 1998;X2111AA042 but they're all the same just superseded each other . When that part number is plugged into subaru, the newest USDM part number replacement for it is 21111AA065. Price is $84 before shipping http://www.heubergersubaruparts.com/...21111aa065.htm . Amazon doesnt have the pump from what i can see |
#695 |
Member#: 496536
![]() ![]() Hey, all. I bought this GC8 half-cut with an EJ20G, and i'm wondering if there's an internet resource to buy the gaskets and other rebuild stuff for the JDM engine. All my familiar internet resources don't seem to have kits for the EJ20g that i can find. Also, i heard that 02-05 WRX head gaskets will work on the EJ20G, is that true? And if so, what other gaskets can translate over to the EJ20G from US motors? Any help is appreciated. Last edited by Darfin; 01-16-2019 at 03:09 AM. |
#696 |
Member#: 503570
E. Canada
Vehicle:1995 Subaru STI RA White |
![]() Anyone have numbers for Intake and Exhaust valves for a 1995 V1 STI RA? Bent valves in Cyl 3 and in abit of a bind. Seem to be having a hard time finding any accurate information on this Gen RA specifically.
#697 | |
Member#: 503570
E. Canada
![]() Quote:
#698 |
Member#: 506469
![]() I am working on an ej20k rebuild, but am having trouble finding piston rings. Will the usdm wrx or sti rings work?
#699 |
Member#: 133923
#700 |
Member#: 410300
![]() Hey guys i have a rhd ver4 98 sti, with no dccd. Looking for help with the front axles.
Are they the same as a usdm 98 impreza? |
EJ20G & EJ20K Parts | awdeclipseguy | 1993 - 2001 Impreza Specific Parts | 17 | 06-15-2009 08:04 PM |
EJ20G Gasket Part Numbers... | scoobydorift | Subaru Conversions | 13 | 02-14-2005 11:43 PM |
Official XT Oil Filter Part Number thread | BrysImpreza | Forester Forum | 8 | 10-30-2003 12:23 AM |
NAPA Part numbers- can we have a nice thread with numbers listed? | Tex-WReX2 | Service & Maintenance | 5 | 12-15-2001 10:21 AM |
