Welcome to the North American Subaru Impreza Owners Club Wednesday May 22, 2019
Old 10-24-2001, 08:02 PM   #1
davesill
Member#: 10818
2002 WRX Wagon
WR Blue Pearl
Question Resting hand on shifter bad?
The owner's manual says that holding the shifter when you're not shifting can damage the transmission.
Could someone explain how?
I did that for years with my Merkur and Geo Metro and never had any trouble.
-Dave
davesill is offline   Reply With Quote
Old 10-24-2001, 08:05 PM   #2
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
It was my understanding that resting your hand on the shifter causes excess wear on the syncros and other portions of the transmission.
Also if you notice the rally drivers who use regular transmissions (vs a dog box or other $$$$ device) keep two hands on the wheel at all times, only removing a hand to shift or yank on the e-brake. Then the hand goes straight back to the wheel.
remarcable is offline   Reply With Quote
Old 10-24-2001, 08:15 PM   #3
jaebusak
Member#: 10332
I think keeping two hands on the wheel is for better control, not cuz they worry about the synchros. Somehow, I get the feeling if that was the kind of thing they worried aobut, they wouldn't be rallying...but anyway, I'm also a lil curious about whether just the weight of your hand is enough to put a significant amount of wear on the synchros?
jaebusak is offline   Reply With Quote
Old 10-24-2001, 08:17 PM   #4
Xio
Member#: 3805
2011 STi Sedan SWP
2011 Outback ABP
It causes wear on the shifter forks.
Xio is offline   Reply With Quote
Old 10-24-2001, 08:18 PM   #5
LordBass
Member#: 3266
2006 Jetta 2.0T 6MT
2009 Jamis Aurora Elite
I used to own a 93 Sentra SE-R, a car famous for its "fifth gear popout". This phenomenon was attributed to the driver holding his hand on the shifter, eventually bending the shift fork enough so it wouldn't stay in place.
Never heard of an other specific cars with this problem. Just don't rest your hand with too much pressure.
lb
www.trancelab.com
LordBass is offline   Reply With Quote
Old 10-24-2001, 08:18 PM   #6
Idjiit
Member#: 5310
2013 Sonic Turbo
Yes, holding on to the shifter will screw up your gears, been there done that. Think about it - the shifter is connected to the transmission at all times... If you put pressure on it, you're putting excess pressure on the transmission.
I had an old '84 GL Wagon that had screwed up gears - the mechanic blamed it on that kind of thing.
And yes, when you drive you should have both hands on the wheels unless you're shifting. It's the only way to get the most information out of the vehicle.
I've trained myself to drive strictlly two-handed over the past few months. After your muscles get used to it, there's no other way to drive.
Idjiit is offline   Reply With Quote
Old 10-24-2001, 08:19 PM   #7
Greg I
Member#: 384
2002 Acura RSX-S
Built rally gearboxes don't have synchros to worry about. Straight cut gears. Someone yell if I'm wrong.
Shift fork issue is what I heard. Plus it's a lazy habit. Both hands on the wheel for me.
gi.
Greg I is offline   Reply With Quote
Old 10-24-2001, 08:28 PM   #8
brunetmj
Member#: 8023
2019 Crosstrek
white
I am someone who tends to keep their hand on the shifter. Itís really a bad habit . I assume it is slowly wearing the connectors in the shifting linkage which in turn , over a period of time, makes it harder to shift properly. I donít really know. This was just an assumption.
brunetmj is offline   Reply With Quote
Old 10-24-2001, 08:33 PM   #9
SoLo OnE
Member#: 9941
www.djforums.com
One word.
Yes
SoLo OnE is offline   Reply With Quote
Old 10-24-2001, 08:44 PM   #10
Bauhaus
Wiped Out By KGB (For Good)
Member#: 9515
WR Blue
It would probably never do anything to bad to the car. I've done it for years as well...BUT I'm actually trying not to do it in this one. So I just lightly rest my fibngers on it.
Never knew there was so much of movement for poeple to drive with 2 hands. Wait, are you guys Driver's ed teachers?
Bauhaus is offline   Reply With Quote
Old 10-24-2001, 08:53 PM   #11
subywan
Member#: 11247
2002 Impreza 2.5TS
Blue Ridge Pearl
Talking They're not driver's ed teachers.....
but that is where they learned to drive.
subywan is offline   Reply With Quote
Old 10-24-2001, 09:23 PM   #12
SWITCH
Member#: 4848
2002 Impreza WRX
It definately does!
I had a 98 5-spd Chev blazer before my WRX and I constantly used the shifter for a handle while cornering. One day while in the middle of a shift the bushing in my shifter went on me. That was fun!
Now I'm both hands on the wheel. Plus I put in 5-points so I don't need to hold on to anything to keep me in place now.
SWITCH is offline   Reply With Quote
Old 10-24-2001, 09:40 PM   #13
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Default Watch almost any professional racer..
be-it drag racer, rallier, F1, CART, NASCAR, Touring Car, whatever. Two hands ALWAYS on the steering - hand on shifter only when needed to shift.
They do this for more of a "control" reason than "wear" reason - two hands on the wheel = better control over the vehicle.
Why do you think all of the new WRC cars, F1, CART, etc. have shifters that are either of paddle style or with the lever very close to the wheel? So that the driver can get their hand to and from the shifter with as little time as possible to maintain full control over their vehicle.
Oh yeah, here's one more reason -- it's just waaay more comfortable with two hands on the wheel @ 9 and 3 with elbows slightly bent. Gives me a sense of confidence and well connectedness to my car. Helped me avoid TWO near-accidents this week to!
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 10-24-2001, 09:51 PM   #14
Valien
Member#: 8584
2002 WRB WRX.
04 Honda Odyssey!
yup...i do it.
bad habit that i'm working on breaking.
trying to keep the 2 hands on the wheel.
even when I had my AT Grand Prix I still kept my hand on the shifter thingy.
Two hands it'll be from now on! I do like the control of using 2 hands when driving.
~V
Valien is offline   Reply With Quote
Old 10-24-2001, 10:05 PM   #15
GRWRX
Member#: 4129
2002 WRX sedan
I heard it makes hair grow on your knuckles!
GRWRX is offline   Reply With Quote
Old 10-24-2001, 10:31 PM   #16
VanillaEps
Member#: 8271
2019 STi Limited
ISM
I've been doing that on my old car and once I heard about that I've trained myself not to....now I hold the e-brake......I always need something to rest my hands on.
VanillaEps is offline   Reply With Quote
Old 10-24-2001, 10:35 PM   #17
128d
Member#: 7792
2002 Prodrive
widebody Cosworth 2.5 6sp
I have done this with every car I have every owned or driven for that matter, and have not had one problem yet. Guess I'm just lucky.
128d is offline   Reply With Quote
Old 10-24-2001, 10:54 PM   #18
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Default Re: Resting hand on shifter bad?
-Dave
Because the shifter is a direct link to your transmission, putting any force (side-to-side, front-to-back, etc) will be bad for it, causing abnormal wear. You may not ever notice it, but why keep your hand there? It should be on the wheel and if not on the wheel, then comfortably at your side, ready to shift or assist with steering.
nhluhr is offline   Reply With Quote
Old 10-24-2001, 11:08 PM   #19
Seeing StaRS
Member#: 5294
I too trained myself to drive two handed over this past summer and I must agree there's no other way to drive. It almost seems scary to me thinking about driving with one hand on the wheel.
Two hands on wheel=better control. Just another step in fixing the nut behind the wheel.
Seeing StaRS is offline   Reply With Quote
Old 10-24-2001, 11:12 PM   #20
Sooberman
Member#: 5344
Location: Greenwood Lake, NY...where the heck is that?!? :P
2002 WRX WRagon
Platinum Slipper
Default Answer me this...
I thought the same thing, especially since I could move the shifter slightly forward or backward when in gear. (My friend even said to me 'isn't it funny that you can move the shifter a little and then feel the vibrating?) So I thought that play was the synchros.
Since then, I've changed the rubber sloppy shifter bushings with Kartboy bushings and now the shifter is pretty solidly in place with no free play. So the pressure asserted on the stock shifter is apparently going to the rubber bushing.
Now I don't think I "feel" the synchros when I place light pressure on the shifter, there's just no play.
Sooberman is offline   Reply With Quote
Old 10-24-2001, 11:57 PM   #21
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
Talking
Funny, I used to use my Escort's(floppy) shifter for a handle too. Then during an autocross, I went to shift to 2nd, and pulled the whole shifter/boot/lever off.... DOH! Eh, so much for American cars
SoobATV is offline   Reply With Quote
Old 10-25-2001, 12:12 AM   #22
stiguy555
Member#: 11190
1999 Impreza 2.5RS
SWITCH, amazing how a fairly new vehicle would have a bad problem like that. Oh wait, that was a GM. Not amazing really.
Its not your fault, GM has serious problems, thats all.
stiguy555 is offline   Reply With Quote
Old 10-25-2001, 06:33 PM   #23
davesill
Member#: 10818
2002 WRX Wagon
WR Blue Pearl
Hmm. I'm not convinced.
Several people have claimed that it causes wear on synchros or forks. Someone claimed it actually bends forks. Another said it ruined his bushings. There's not exactly widespread agreement here on the mechanism of the damage. Surely if transmissions can handle regular, vigorous shifting, they should have no trouble with a hand on the knob that's not applying force--and I'm not talking about holding the shifter for support during turns.
I'm also not terribly interested in the arguments for keeping both hands on the wheel. I'm a big boy, and I'm capable of deciding whether I want my hand on the wheel or the shifter. If it's so important to keep two hands on the wheel, I guess you should have an automatic.
So, lacking more convincing or authoritative information, I'm going to have to consider this one an old wive's tale--especially given my personal anecdotal evidence to the contrary.
-Dave
Old 10-25-2001, 06:53 PM   #24
Corn-Picker
Member#: 8679
2010 The most hated
vehicle on the internets
Dude, driving with one hand will catch up to you one day. You'll go around a corner, hit a pothole, and the wheel WILL rip itself out of your hand. By the time your regain control you will be in the next lane or off the road.
And yes, resting your hand on the shifter will screw it up eventually. Take a look at www.howstuffworks.com and look at manual transmissions. If you don't bend the gates, the synchros will have problems. The reason you see people saying so many different things about what happens from resting your hand on the shifter is because a lot of bad things can occur from resting your hand on the shifter
Corn-Picker is offline   Reply With Quote
Old 10-25-2001, 06:55 PM   #25
wrx182
Member#: 9531
2002 WRX Sport Wagon
while you drive / idle, you'll notice that the shift knob moves and vibrates...i suppose that holding it would restrain the vibrations and movements, causing wear on the parts that would normally be free to move by holding them in place.
wrx182 is offline   Reply With Quote
resting hand on shifter Subaru_Impreza General Community 25 11-09-2004 07:28 PM
hand on shifter? hugoshi Newbies & FAQs 26 06-29-2004 01:55 PM
Bad to rest hand on shifter? xtheviperx General Community 26 10-01-2003 07:43 PM
Resting hand on Auto bad? Scoobie Newbie Transmission (AT/MT) & Driveline 7 01-02-2002 01:14 AM
Hand on the shifter? smallschip General Forum Archive 21 01-10-2001 12:03 AM
