Welcome to the North American Subaru Impreza Owners Club Friday February 23, 2018
Old 09-13-2017, 06:23 PM   #1
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
Default Head Gasket for EJ253?
Hi Guys -
I have a 07 OBS with the EJ253 that has bad valve seals. I picked up a spare set of heads, had my machine shop go through them (valve job, new springs/seals/guides, and decking), and I sent the cams out to Delta for their torque grind.
I am trying to choose what head gasket to use. I don't want to use the OEM Subaru EJ253 gasket because it's still a ****ty single layer design. I'm looking at either the OEM Subaru EJ257 gasket (04 STi, don't have the PN atm), or the Cometic gasket for the EJ253 since both of these gaskets are MLS.
I understand the OEM Subaru EJ257 is thinner than the EJ253 gasket. Will this be an issue in terms of piston and/or valve clearance? Again, I'd prefer to use an OEM gasket, but if piston/valve clearance is an issue with the OEM Subaru STi gasket then I will go with the Cometic gasket.
03SubyWRX is offline   Reply With Quote
Old 09-15-2017, 06:22 PM   #2
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
Bump, looking for advice.
Old 09-15-2017, 07:24 PM   #3
Preludicrous
Member#: 334356
2006 2.5i Wagon
SRR
I'm pretty sure you can use the STi gaskets with no issue. It's been discussed in this forum before, you can probly find at least a couple threads about it.
Preludicrous is offline   Reply With Quote
Old 09-16-2017, 12:41 AM   #4
93stiImperza
Member#: 212172
01 RSTI
CFBlue IAG STAGE 4 BLOCK
For the ej253 oem headgasket they do make a updated 3 mil gasket. I was able to find update part# Just bout a set thru ebay a few months back for a side job. Or go with a felpro set they as make a et to.
93stiImperza is offline   Reply With Quote
Old 09-19-2017, 08:46 PM   #5
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
The Sti one should work. Part nr.... 642. That's the one I used when mine blew on my old EJ251 - it's a MSL design.
Bluefoton is offline   Reply With Quote
Old 09-20-2017, 04:09 AM   #6
terrainasaurus
Member#: 464727
2008 OB(Wan)S
OBP/DGM 2-toner
bump. me interest 2
terrainasaurus is offline   Reply With Quote
Old 09-21-2017, 12:14 AM   #7
jamal
Member#: 71875
Yeah use 11044aa642.
Newer ej25s, like 09+ have different passages in the heads so you need to use the 07+ sti gaskets. I think it's the same part number between the n/a and turbo cars anyway. ...770 I think.
jamal is offline   Reply With Quote
Old 09-22-2017, 11:24 PM   #8
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
Thanks for the help guys
Old 09-23-2017, 02:15 PM   #9
Bluefoton
Member#: 141373
2008 2.5i-hatch -
So the HG number changed in between EJ251 and EJ253 - and along with it, the "equivalent" Sti one?
I'll need a confirmation, since I'm mentally preparing myself for mine to fail....
Old 09-23-2017, 05:24 PM   #10
jamal
Member#: 71875
Well, the gasket did change, a bunch, now that I'm looking at the parts catalogs. Almost every year from 03-08 - 521, 631, 632, 633. But they all supersede to the same number - 11044AA633, up to the 2011 impreza, which I think was the last year of the EJ in them. And those gaskets have the older coolant passage holes, and still appear to be black/coated gaskets, not MLS like the turbo cars.
However, the outback uses part 11044AA770 for 2010, which is the same gasket as the 2008+ STI. It is the same thickness and construction as the 04-06 gasket but has different cooling holes (there was also an 07 sti only gasket).
So maybe the 2010 outback/legacy and impreza heads are a little different?
Anyway, I guess you would want to look at the heads to determine whether to use 642 or 770. It appears that any impreza 99-11 and legacy/ob 99-09 you would want 642. Then 2010+ legacy/outback with an EJ, use 770.
Old 09-23-2017, 05:56 PM   #11
kos
Member#: 118334
2006 CGM WRX
2005 Aspen White RS
FINALLY rebuilding my tired EJ253, 206,125 on it and its been long due for HGs. Going to go the 642 route.
kos is offline   Reply With Quote
Old 11-09-2017, 03:23 PM   #12
terrainasaurus
Member#: 464727
2008 OB(Wan)S
OBP/DGM 2-toner
Just making sure.. will the 11044aa642 work with a 2008 OBS? Cooling passageways will not be affected?
Old 11-12-2017, 10:36 AM   #13
Sir-Knight
Member#: 73636
2017 WRX base
Urban Grey
anecdotally, on my 07 2.5i I believe I had the equivalent year oem STI gasket put on when I had mine done at only 100k km. Since the block on the sti hasn't changed, I would assume that all sti gaskets would be the same in terms of coolant passages. My mechanic said I would be able to use the STI gasket without issue, as he had done several with it. For those in the NCR in canada, the mechanic was rocky. The gakset held up without further issue (no machining of the heads done), though I believe there was the typical sweat occuring.
Rocky noted my HG leak was on the passenger side, rather than the more common driver side.
Sir-Knight is offline   Reply With Quote
