Welcome to the North American Subaru Impreza Owners Club Tuesday September 18, 2018
Old 02-13-2018, 03:15 PM   #151
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Sorry but i dont see how a returnless system could deliver cooler fuel. Looking at an 08 Impreza 2.5i, the fuel dead ends in steel lines on top of the block, then the 2.5i takes in very little fuel, meanwhile the pump is pumping at 4bar with 90% of it recirculating round and round inside the tank waiting to go to the engine
no694terry is offline   Reply With Quote
Old 02-13-2018, 04:12 PM   #152
mrsaturn7085
Member#: 375462
2006 Impreza WRX STI
WR Blue
Without testing, it's all conjecture. I noted 'theoretically' for this reason. Unfortunately, the downsides of a dead-ended system are too much for me to bother rigging anything up with temperature measurement
mrsaturn7085 is offline   Reply With Quote
Old 02-13-2018, 04:28 PM   #153
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
ya who cares. moving on. Ive just been semi interested in all this since im coming up on running all new fuel lines in the tube chassis. Planning on -6an feed and 5/16" return. Just need to pick a filter
Old 02-14-2018, 12:02 AM   #154
Homemade WRX
Member#: 33782
96 3MI Racing LLC
search FIRST, then PM!!!
Originally Posted by Legacy_H6TT View Post
Haha, yeah I know NASCAR motors aren't low tech; flat plane cranks, EFI, 9000rpm+ redline! And seeing where you're located you have to appreciate my love of the sport #doitfordale
They're still crossplane and NASCAR has been doing their job of dialing them back in the from the 10k RPM peaks they had. They've been reeling the budget aspect of it back in a lot. We had flatplane only on the GT350R-C project. Then the FIA and IMSA side of my job was cool but also lame because of BOP. Great, we can make all of this power and save all this fuel but it'll only be so that we're penalized...great!!
With that being said, I've been focusing on intake manifold a bit too much and haven't touched my surge tank. I need to get back onto things. My bugeye DD is waiting to guinea pig.
Old 02-23-2018, 03:25 AM   #155
Legacy_H6TT
Member#: 137502
1990 Legacy GT-t
Blue over silver
True? I thought NASCAR did use a flat crank... my bad. That GT350 is cool though; not a huge Mustang fan but being able to pick one up for around $50k its certainly a future classic worth holding on to!
Legacy_H6TT is offline   Reply With Quote
Old 03-12-2018, 01:21 PM   #156
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
what yall think about AN fitting restriction. These -6an fittings have 7/32" ID's, my stock 5/16" hose barbs have bigger holes
Old 03-12-2018, 03:39 PM   #157
mrsaturn7085
Member#: 375462
WR Blue
6AN standard fitting (not hose) I.D. is 0.300"
6AN hoses are even larger at 0.340"
7/32" is 0.21875" (!!)
I don't know where you bought your fittings, but I'd be permanently scrapping whatever brand you saw a 7/32" orifice on something labeled 6AN...
Old 03-12-2018, 03:47 PM   #158
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
They're ICT Billet fittings i got from Summit Racing. I measured with a ruler at my desk, but its about 1/32" under a 1/4", the tube that goes inside the hose when assembling.
Old 07-13-2018, 12:48 AM   #159
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Just measured a few 6an fittings and they are about .27" ID, but their nipple has to go inside the line and still have a wall, which means it has to be smaller. It probably also varies depending on whether it's for ptfe or "normal" rubber fuel line. The ones I measured have the white swirly symbol on the sides, probably made by ICT (china?) and stamped by someone else. I have some russell fittings at work, for the rails. Will measure them when I get the chance.
I'm hoping to run ptfe wherever possible, but it's not very flexible so routing requires more precise measurement.
It's funny how critical we are being with the ID of the fuel line. If you look at the ID of the fuel pump you're running, you may be surprised how small it is. The ones with built in check valves in the nozzle though...
Old 07-13-2018, 01:13 AM   #160
mrsaturn7085
Member#: 375462
WR Blue
As I said above:
Low-quality manufacturers definitely don't always hit these.
Old 07-13-2018, 01:39 AM   #161
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I will measure the Russell size change fittings at work tomorrow, but as I said...the type of fitting will determine the ID. Ptfe and push lock hoses are designed to seal differently and so are their respective fittings there is only so much room to have a structurally sound nipple and still keep the ID sufficient. Maybe someone will buy some generic fittings for ptfe, push lock and normal hose and post a visual comparison. All I have are some generic fasster ptfe and push lock fittings and a few Russell size conversion fittings. It's obviously easier to keep a larger ID on a fitting when it's the male end that screws into a female fitting, versus a nipple that has to be wedged inside a hose with a specific ID range. Typical rubber hose has a good bit of stretch compared to ptfe.
Old 07-13-2018, 02:04 PM   #162
mrsaturn7085
Member#: 375462
WR Blue
My point was that the AN fitting diameters are defined by the standard. Regardless of what you measure, the standard is the correct measurement and a good way to filter out low quality fittings.
When you are talking about the wall thickness, barb size, etc. you should note the AN standard still applies. If anything causes the ID to dip BELOW the minimum measurements, it is a choke point and would not meet the standard. Goodridge, Eaton (Aeroquip), and some smaller specialty brands ($$$) are the only ones I've seen consistently hit the AN sizing requirements. Earl's usually does... but the thing to note about Earl's - they private label a LOT of their parts, and rarely from the same manufacturer. Their QD fittings, for example, are manufactured by Staubli.
Old 07-14-2018, 07:40 AM   #163
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
I was pretty surprised how small the ID was on my 6an lines. Made me feel like I wasted money not just using stock 5/16 hose stuff
Old 07-14-2018, 03:04 PM   #164
VladiWrX
Member#: 145658
On my 10th scoob
and lovin it
UPDATE
Ok so I know it's been forever, and I have been following the thread without much posting because we weren't really making much progress, so here's where we're at now:
car 1) 2007 sti - the dw hardwire relay burned out for no apparent reason. car barely gets driven, maybe once in 2-3 weeks if that. contacted dw, they sent replacement. he's having me drop in ID1700's so that we can at least try to run the car on e85. He's also having me drop in Cobb Flex fuel and pressure kit soon. I know the hardwired dw300 on this car will still struggle past 450 so we're hoping for 450 until we figure out a double pumper setup.
car 2) 2015 sti - dropped in ID1300x and it seems to be doing decent at 430whp on the hardwired aem320 on e85. 80's IDC
car 3) 2014 sti - dropping in ID1700x right now, along with IAG rails, IAG -6an underhood fuel lines, perrin FPR, and going to hardwire the walbro450 and hope for 500-550whp on e85? until he can go radium double pumper setup and run lines from tank to underhood.
after the injector installs and everything underhood is taken care of on both cars, we'll start planning the in-tank upgrades as well as running lines. are my expectations for car 3 realistic?
here's a few pics
IMG_4735 by vladirsx, on FlickrIMG_4751 by vladirsx, on FlickrIMG_5192 by vladirsx, on FlickrIMG_5199 by vladirsx, on Flickr
VladiWrX is offline   Reply With Quote
Old 07-15-2018, 03:15 PM   #165
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
43 base + 28 psi boost + 10 psi pump back pressure you looking at ~ 80 psi fuel pressure at the pump.
80 psi on 450 will do 328 lph
ID1700 will need 320 lph to run up to 7500 rpm.
I would probably run 25 psi max boost on 450 with E80 and watch differential fuel pressure.
And get rid of Cobb AP its for noobs.
Bariga is offline   Reply With Quote
Old 07-15-2018, 06:05 PM   #166
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
probably only need 1200-1300 cc to hit 550 though.
I think I posted a 450 log in here somewhere running 1000's at 4bar with 2 bar of boost with stock lines. I'm at 100% duty cycle at 420whp on e80. But my tunes conservative and my motors not an effecient power maker
Old 07-16-2018, 02:35 AM   #167
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
you will be out of pump by 500 whp, in most cases differential fuel pressure will be dropping hard, and running a pump that is maxed out will lead to bad things as conditions change.
im not sure about fitment but DW400 looks promising
Old 07-16-2018, 07:02 AM   #168
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
at some point, probably when i upgrade injectors. I'll be putting in a surge tank. 450 to feed tank, a bosch 044 to feed rails.
Old 07-16-2018, 07:48 AM   #169
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
Default Simplest path to FUELING 500-550whp?? on E85
DW350 > Bosch 044 and the 350 is engineered to be a directed fitment replacement for the 044 meaning the 350 will fit hangers & tanks meant for the 044
Titter is offline   Reply With Quote
Old 07-16-2018, 08:06 AM   #170
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
theres just a part of me that dont like DW pumps. anytime i hear about wiring burning up or something is a DW related. Even on my brothers car, he had a 65c and burned up his bulk head connector. Maybe just coincidence but just how i feel
Old 07-16-2018, 12:36 PM   #171
mrsaturn7085
Member#: 375462
WR Blue
Taking an eye loupe to inspect a DW injector pintle was all it took me to return my DW parts and move along. The data they provide for their product is good, but the bar has been raised and I don't feel they've stepped up to the current level of quality out there.
Didn't we talk about all this a few months and pages back in this thread? As much as I like the 044 pumps, the only one I've really seen that seems like a solid across-the-board upgrade on paper is the AEM 400 pump.
Old 07-22-2018, 09:14 PM   #172
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Has anyone tried the Racetronix BCWS-001 tank bulkhead connector on their subaru?
https://www.racetronix.biz/search/se...words=bcws-001
I have a hanger for reference, but not sure there will be room with the oem connector and fuel lines in the way. Going to remove the feed outlet for a 8AN adapter, so that can be swiveled but I'm trying to avoid chopping the rest if possible. The racetronix connector has four 14 gauge wires which is plenty for even a dual pump setup. They say it's only 10mm diameter for the pass through section, but obviously the outer connector is a good bit larger. I will be using all four wires for my pump and leaving the oem connector for level duty.
Old 07-23-2018, 01:59 AM   #173
mrsaturn7085
Member#: 375462
WR Blue
It doesn't really look like the Racetronix connector is much smaller than the OEM part (?)
EDIT: misunderstood your question at first, but leaving the pictures for reference
Old 07-26-2018, 08:19 PM   #174
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I've attempted to purchase the racetronix part, but the site won't allow me to complete registration to buy, and there's no guest checkout even with paypal. I've messaged them twice with no reply. Doesn't seem like they have any online distributors and very few if any authorized retailers.
Old 08-11-2018, 07:11 PM   #175
VladiWrX
Member#: 145658
On my 10th scoob
and lovin it
Alright guys the 2014 car is getting a radium double pumper with twin AEM's and -8feed/-6return lines, so I'm no longer concerned with that car, will be able to hit it's 550-600whp goal without issue.
So now my only concern is the 2007. The surge tank setup posted above looks interesting, and something similar to what I'd like to do on the 2007. Fuel system on it currently:
ID1700s going in
perrin rails/braided lines
Tomei adjustable FPR
Cobb FF and Pressure kit
Which brings us back to pump/tank choices:
Currently it has the DW300 pump and hardwire kit. Obviously this won't work for 550 as we've concluded here already.
Just to remind everyone, simplicity is still the priority here. Currently eyeing the Radium and Full Blown double pumper hangers and retaining the OE lines from tank to bay for now. The other option being surge tank setup similar to the one posted above, and keep the current dw300 as a lifter pump for the surge tank.
What would be simplest and require the least work? Or should I do something uncommon like a large single pumper like the AEM400 or DW400 and stay super clean and simple?
